    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.3k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      BOOM !
      Choose what layer to render ! πŸ‘
      [screenr:t24aadah]OHcH[/screenr:t24aadah]
      Works with Vray, Maxwell, Kerkythea and Indigo. I'm working with Tomasz to get Thea to support this feature.
      It still needs some finishing, but the release is not far πŸ˜‰
      • ToboboT Offline
        Tobobo
        @jiminy-billy-bob said:
        BOOM !
        Well done!!! I cant wait to have a crack πŸ‘
        Toby
        Philippians 4:13
          jiminy-billy-bob
          New version 0.4 beta !
          Changelog :
          • Adds the ability to choose which layers to render (Works with Vray, Maxwell, Indigo, and Kerkythea)
          • Fix bug when having too many layers
          • The dialog now remembers its size and position when closed
          • Fix focus jumping at the top of the dialog
          Download in the plugin store !
            kirill2008
            I won't be original, just want to say: it is a great plugin! πŸ‘ Many thanks for it!
              jiminy-billy-bob
              @kirill2008 said:
              I won't be original
              You don't have to, it's always nice to hear that πŸ˜‰
              • U Offline
                Ulimann
                Hallo Jiminy
                Great plugin , installed the update and get the resulting screen on activation.
                I am running Windows 7 64 SU 8 PRO.
                  jiminy-billy-bob
                  Can you delete everything concerning Layers Panel in your plugin folder, and reinstall it ?
                  Plugins/jbb_layers_panel.rb
                  • U Offline
                    Ulimann
                    Thanks for the quick reply,did as you suggested its up and running.
                    • sadyoS Offline
                      sadyo
                      Great Plugin... (y)
                      waiting for Render feature to work with Thea Render
                        jiminy-billy-bob
                        Actually, if it works with Thea on day, it'll behave differently. You will probably have an option directly inside Thea allowing you to choose if you want to render with Layers Panel feature or not. But you won't render from within Layers Panel as you do with Vray/Maxwell/etc. This is due to the way Thea is designed. I can't trigger the render from my plugin.
                        I gave evrything to Tomasz to make it work, the ball is on his side now πŸ˜‰ So if you badly want this feature, you should get in touch with him !
                        • doush-007D Offline
                          doush-007
                          Great plugin...it must absolutely replaced the layer window in the next version of sketchup..thanks a lot for this plugin 😍
                          • JQLJ Offline
                            JQL
                            Jiminy great plugin and great news on Thea!
                            Is it possible that my layer groups have been wiped out after a purge?
                            Best regards,
                            JQL
                            www.casca.pt
                            Visit us on facebook!
                              jiminy-billy-bob
                              That's not possible with a purge. But it may be something else... I have no idea what, though. Did you do anything unusual around the time the group were wiped ?
                              • Gordon GreenwoodG Offline
                                Gordon Greenwood
                                any idea when this wizzy plugin will be available to OSX
                                lucky I have windows laptop
                                Gordon
                                Changelog :
                                0.4
                                0.3.2
                                • Fix bugsplat when deleteing/purging layers with Outliner opened
                                • New naming conventions (For the Extension Warehouse)
                                0.3.1
                                • Fix group names disappearing
                                0.3
                                • Locking layers (Works only when purging or deleting from the plugin's menu)
                                • Ability to add a layer only visible in the current scene (New pop-up menu when holding the "Add layer" button)
                                • Layers Panel is now a toolwindow, but you can't dock nor collapse it
                                • Two different delete buttons, for better performance (The red cross deletes the layer content, the green arrow moves the content to the default layer)
                                • Several bug fix
                                0.2
                                • Fix bug with existing layers
                                Hi guys !
                                After several alpha versions, here is the first working beta version of my first plugin : Layers Panel.
                                It basically replaces Sketchup's layers window. It reproduces every features of it, except layer colors (for now), and adds the ability to group layers, sort them, hide/collapse groups, etc. More features are coming (Locking layers, etc)
                                It was designed to be very similar to Photoshop's layers panel, as I use it a lot and find it very handy.
                                http://i.imgur.com/HZ33BBS.png
                                Warnings
                                • Some people got corrupted files using this plugin, so be carefull, backup your work, and use at your own risk !
                                • Remember it's still a beta version, so it certainly has bugs, and it may produce bugsplats.
                                • It updates the active scene (updates only layers) every time you affect a layer(Hide/show it, rename it, add/remove one). It is the only way some things can work.
                                • Although the undo/redo support was improved a lot since the alpha versions, sometimes it still messes up (rarely), which prevents you to redo some operations.
                                • By using this plugin, you agree to send completely anonymous data, used to improve it.
                                It does not work on OSX !
                                Recommended : Windows Vista-7-8, Sketchup 8-2013, Internet Explorer 9-10-11.
                                The way you sort/nest layers is simple, just grab the handle on the left of a layer/group, and drop it where you want. To choose the depth of the nesting, move the layer to the right or the left, like this :
                                http://i.imgur.com/V0xmVeD.jpg
                                Here is a short video showing how the plugin works :
                                [screenr:20b91oce]drOH[/screenr:20b91oce]
                                Download
                                Directly on the PluginStore :
                                SketchUp Plugins | PluginStore | SketchUcation
                                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                (sketchucation.com)
                                Your feedback would be very appreciated, improvement ideas, features, etc...
                                If you encounter any bug, please tell me, with instructions to who reproduce it. And please include your OS, SU version, and IE version.
                                Hope you'll like it ! πŸ˜„
                                Donate...
                                  jiminy-billy-bob
                                  When it's done πŸ˜„
                                  BTW : I don't think it was necessary to quote the whole original post.
                                  • Bob JamesB Offline
                                    Bob James
                                    I really hesitate to bring up a problem with this fantastic plugin, but, repeatably, when I try to change the name of a layer or group the change won't work. If I change the name in SU's layer tool it changes the name in both SU and in the plugin.
                                    Is there any way you can add the ability to alphabetize the groups and then the layers within a group?
                                      jiminy-billy-bob
                                      I added a potential fix for the next version.
                                      Does it happen every time you try to rename these particular layers/groups ? Even after restarting Sketchup ? Do you use special characters ?
                                      What are your Windows and IE versions ?
                                        Bob James
                                        Yes. Any layer or group.
                                        Yes
                                        No
                                        Win 7
                                        IE 10
                                        Of possible significance: These are models that already had many layers, but the inability to change the names happens on both "old" layers and new.
                                        Is this in reference to alphabetizing?
                                          jiminy-billy-bob
                                          Does it happen to one (or several) particular layer/group while all the other layers in the file can be renamed fine ?
                                          • irwanwrI Offline
                                            irwanwr
                                            Internet Explorer 9 and above?
                                            So, it wont work with Windows XP then?
                                            • 11
                                            • 33
                                            • 34
                                            • 9 / 34
