    Load Component and Rotation
    7 Posts 2 Posters 597 Views 2 Watching
    • pingpinkP Offline
      pingpink
      Hi ,
      I'm trying to load a sunshade component in " 4 sides of drawing edges " .
      I can do only one side. Anyone can give me any idea how can I load with a rotation in a code ?
      I want the code can apply around a building facade.
      require 'sketchup.rb'
         def insert_file_skp(sFile, point, sName)
         model = Sketchup.active_model
         pants_def = model.definitions.load sFile
         # Then define a location, and place our skp there.
         pants_location = point
         transform = Geom;;Transformation.new pants_location
         entities = Sketchup.active_model.active_entities
         instance = entities.add_instance pants_def, transform
         instance.name= sName
         return instance
      def move_compo(edge, compo)
        start_point = edge.start.position
        end_point = edge.end.position
        if start_point.x < end_point.x
          pt = start_point
        else
          pt = end_point
        p pt
        ## Z Scale 90 degrees
         cpt = compo.transformation.origin
        xscale = edge.length / 1.m
        tscale = Geom;;Transformation.scaling cpt, xscale, 1, 1
        compo.transform!(tscale)
        vector = pt - cpt
        tr = Geom;;Transformation.translation vector
        compo.transform!(tr)
      def insert_Sunshade_Curved
         model.start_operation( "Add Component", true)
         selection = model.selection
         selection.each{|entity|
         sFile = Sketchup.find_support_file "CurtainWall_Architect/Components/Sunshade/Sunshade_Curved.skp", "Plugins"
           if entity.class == Sketchup;;Edge
      	    edge = entity
      		line = edge.line #vector of edge
      		if (line[1].dot Z_AXIS).abs == 0.0
      		compo = insert_file_skp( sFile, Geom;;Point3d.new(0,0,0), "Sunshade-Curved")
         model.commit_operation
      • TIGT Online
        Your code inserts an instance at the origin, scales it to the edge.length and moved it to the edge.start.position.
        So far so good.
        Now in move_compo() you need to find the angle that the edge makes with the X_AXIS.
        I am typing this from memory, as I can't test it right now, so please be aware that you might need to spot typos and even flip some logic***
        vec = edge.line[1] ang = X_AXIS.angle_between(vec) ang = -ang if X_AXIS.cross(vec).z < 0***
        ***e.g. it might be > 0 ?
        Now rotate the instance about the edge.start.position
        trr = Geom::Transformation.rotation(edge.start.position, Z_AXIS, ang) compo.transform!(trr)
        That should rotate the instance onto its edge's line...
        • pingpinkP Offline
          pingpink
          Thank you so much !
          I try to solve form your suggestion It's rotate , but not place at the edges.
          I don't know why.
          transform = Geom::Transformation.new pants_location
          return instance
          #------------- Edit ----------------#
          [highlight=#ffff80:1fxmkzqh]vec = edge.line[1]
          ang = -ang if X_AXIS.cross(vec).z < 0[/highlight:1fxmkzqh]
          pt = start_point
          else
          pt = end_point
          p pt
          tscale = Geom::Transformation.scaling cpt, xscale, 1, 1
          vec = pt - cpt
          [highlight=#ffff80:1fxmkzqh]tr1 = Geom::Transformation.translation vec
          tr2 = Geom::Transformation.rotation(edge.start.position, Z_AXIS, ang)
          instance1 = compo.transform!(tr1)
          instance2 = compo.transform!(tr2)[/highlight:1fxmkzqh]
           if entity.class == Sketchup::Edge
              edge = entity
          		compo = insert_file_skp( sFile, Geom::Point3d.new(0,0,0), "Sunshade-Curved")
          Result
          • TIGT Online
            You want to move the compo that you have initially placed at the ORIGIN to the start of the edge ?
            So use
            vect = ORIGIN.vector_to(edge.start.position)
            Then use that to move it into place [and then do my rotation code...]
            tr1 = Geom::Transformation.translation(vect) tr2 = Geom::Transformation.rotation(edge.start.position, Z_AXIS, ang) compo.transform!(tr1) compo.transform!(tr2)
            Check my ..z < 0 works... it might need to be ..z > 0 ??
            I haven't managed to test any of this πŸ˜•
            Incidentally, you can combine transformations thus
            compo.transform!(tr2*tr1)
            once you know it's working right - note the order of the combination * - relocating to a point then rotating about that point, is likely to produce a different result compared to rotating about a point then relocating to that point...
            • pingpinkP Offline
              pingpink
              Thank you very much , TIG 😍
              Finally I can load , scale , and rotate sunshades from your advice !!!
              This code works very nice. z < 0 made the components run on the edges.
              [highlight=#ffff80:1zu9kjw1]vect = edge.line[1]
              ang = X_AXIS.angle_between(vect)
              ang = -ang if X_AXIS.cross(vect).z < 0[/highlight:1zu9kjw1]
              [highlight=#ffff80:1zu9kjw1]tr1 = Geom::Transformation.translation(vect)
              compo.transform!(tr2*tr1)[/highlight:1zu9kjw1]
              • TIGT Online
                Glad to help.
                I guessed at the right 'cross' result - it'd either be .z<0 or .z>0 !
                πŸ˜„
                • pingpinkP Offline
                  pingpink
                  I respect you !!! I'm a big fan of you. πŸ˜„
