    Flipping my drawing right side up
    4 Posts 4 Posters 395 Views 4 Watching
    • E Offline
      eric80
      Not quite sure how I did it but I've drawn my house on Sketch up upside down.
      any suggestions on how to get it right side up without redrawing the whole house?
      that asked.
      my 3D text shows upside down but my regular text shows correctly!?
      I've attached my drawing for your perusal.
      notice the front door. regular text then in front of the door 3D text.
      comox exterior.skp
      • Rafferty94R Offline
        Rafferty94
        If is all in a component just scale it through the center line to -1
        • Wo3DanW Offline
          Wo3Dan
          If you scale the house by -1 you'll end up with a mirrored model of your house.
          Use [Ctrl] and [A] to select all and then rotate the entire selection 180 degrees about the green axis.
          Your house model will stay "un-mirrored", yet blue axis will point up again as should.
          Suggestion: Save a (first) scene with a perspective overview. At some point you somehow rotated your model. This scene will instantly "tell" you if things got mixed up again.
          • BoxB Offline
            It might help with your orientation and sense of scale if you use one of the templates that have ground, sky and a person in it.
