    [Plugin] Hole Punching Tool
    200 Posts 43 Posters 259.0k Views 43 Watching
      Your window has its insertion-point [axes] on its back corner, not the front - where it might normally be put.
      It also is placed onto the wall's inner-face - not its outer-face - so there's nothing to be punched, as it punches backwards from the component, expecting to meet an inner-face.
      If you move the instance onto the outer-face and reglue it to that, then it will punch a hole through both faces of the wall, although at that point the window is then balanced on the very front of the wall.
      May I suggest that you relocate the window's axes so that it cuts any wall at the correct place, when you insert it on the outer face, as intended by the entire concept of 'cutting-components'.
      Also having a cutting-component made of lots and lots of subcomponents will take ages to work out the cutting/punching 'hole'.
      Try exploding nested geometry to speed it up.
      Basically you are making your cutting-component too complex and with strangely placed axes...
      • U
        UncleMonkey
        Many thanks, TIG! I had completely forgotten how axes placement affects cutting and punching. I am thinking that as a general rule, it might be best to start out with punching components reduced to the perimeter only, and when they're placed to my satisfaction, open one to edit all and then insert the subcomponents. (My reason for wanting to keep them unexploded is so I can get an easy count of how many to put in my BoQ.)
        The amount and quality of effort you and others like you (Gaeius, for example) put into helping us struggling beginners is probably the best thing about SketchUp. Thanks again!
        David
          Here's v2.2 http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
          Fixed rare DefnsObserver Bugplat! onQuit with some DC coded edits.
          • B
            baiduaiya
            Thanks TIG.
            • pbacotP
              I would like to use this tool, but other than a couple successes, my experience so far has been about 50/50 the window moves to the inner wall or SU crashes.
              hole punch test.skp
                @Peter
                I can get it to flip faces, but only if I put the cutting window component neat the top of the wall, and the inner wall-face has a lower top.
                This means that the hole/reveals cut are incomplete and something goes wrong...
                I'll look at it sometime when I am less busy... but meanwhile try and check that the hole the component will cut falls fully onto the inner wall-face...
                • JQLJ
                  JQL
                  Dear TIG,
                  I'm divided between using Hole Punch tool or Double Cutting Components to create openings.
                  I've attached an image and .skp with details:
                  http://www.casca.pt/varios/holepunchtool.jpg
                  If Hole Punch Tool could automatically create steps 4 and 5 on image, we could have the best of both worlds.
                  If by any chance you were able to adapt the observers(!?) you use to connect faces and components, and make them connect both components as in step 7,then Hole Punch Tool would be, in my modest opinion, a revolution in the way people model windows in Sketchup.
                  Of course I'm totally incapable of coding, so I'll be looking forward for your reply... ansiously!
                  Best regards,
                  JQL
                  Sketchup File Used for "wishlist"
                  www.casca.pt
                  Visit us on facebook!
                    Here's an update http://sketchucation.com/forums/viewtopic.php?p=271170#p271170
                    It cuts through multi-leaf walls and also into groups onto which a cutting instance is glued [but do NOT copy grouped punched-components because the reveals will not remain inside the group!]
                    • JQLJ
                      JQL
                      Tig,
                      I'm sorry for being so persistent but, would it be possible if the plugin would turn the created hole into a "hole cutting component" too? It could then be glued to the opposite face of the wall and be easily manipulated...
                      Thanks for your unbelievable work and sharing! Best regards,
                      JQL
                      www.casca.pt
                        ArCAD-UK
                        Hi Tig, just downloaded 2.4 via the SCF loader and auto installed. Worked straight off and everything running as exected, but after closing SU and then restarting I get an immediate bugsplat. I've removed the HPT ruby and SU works (double checked). I see others don't have a problem with SU 2013 pro; where do I start to find the conflict as I would like this in my tool chest?
                        I've attached my plug list just in case you recognise the culprit πŸ˜’
                        Ruby plug list
                          I have the same OS/SUp-version and most of those plugins [and many others] loading without issues with the operation of the HPtool, during a session and on a reopening of any SKP - either containing HP-compos or not etc ?
                          I am sure it is none of my/SketcUcation plugins, and also the su_, twighlight, tt_ and the two profile-builder files seem safe.
                          Start by looking at the other ??
                          I am puzzled. πŸ˜•
                          Sounds like an observers clash...
                          Ensure that you have the latest version of all of these scripts installed...
                          Then if it still splats...
                          Then use the SketchUcation Plugin Store toolset's Plugins Manager to disable half of the plugins listed.
                          it's easiest to do it in alphabetical-order list, so you can keep track of what you are changing...
                          Reinstate the HPtool [.rb file]...
                          Restart and see if it works.
                          If so, swap the loaded/enabled & disabled 'halves' over [obviously leaving HPtool enabled - also never disable deBabelizer - that is used by HPtool and perhaps some other files...].
                          Restart SketchUp and see if that now splats.
                          If it splats, then we have the culprit in the loaded/enabled set.
                          Temporarily rename the HPtool .rb file in the Plugins golder with a final '!' [to disable it].
                          Restart and try disabling half of what's still enabled [leaving the HPtool enabled] and restart.
                          If it splats then the culprit is still loading, repeat as above disabling half at a time until you zoom in on the culprit.
                          If it does NOT splat then the culprit is in the partial set you last disabled, so re-enable half of those, restart to test etc...
                          Repeat till the culprit is found.
                          If there's not one I am stumped !
                          It should only take a few iterations to find what's clashing...
                          Let me know what's causing the issue ?
                          Then we can look to correct it...
                            ArCAD-UK
                            Hi Tig, I should have guessed the conflict is in add_hidden_layer which is quite useful but it was also a legacy file from here... http://sketchuptips.blogspot.de/2007/08/add-hidden-layer.html. Between the two HPT wins but it would be nice if AHL could be fixed easily.
                              Jim's AHL is an old script [~6yrs] - it does some pretty simple stuff but has no observers, or other on-load code at all, except for setting up it's item in the menu.***
                              I am at a loss to see what is happening to cause such a clash/splat... πŸ˜•
                              The HPT has no layer manipulations and nothing that I can see to clash at all...
                              When I add AHL to my Plugins folder and restart SketchUp I get no issues at all when opening SKPs - without without HP-compos etc !!
                              As an alternative - there might be a similar tool within Didier Bur's 'Layer Manager'?
                              Here are some possible 'fixes' for AHL - which of course I can't test because I can't get it to break ! πŸ˜’
                              Try these in this order until you get a resolution ???
                              ***The menu item creation is set up somewhat oddly:
                              unless file_loaded?( "add_hidden_layer.rb" )
                                  UI.menu.add_item("Add Hidden Layer") {AddHiddenLayer.start}
                                  file_loaded("add_hidden_layer.rb")
                              so try rewriting it as:
                              unless file_loaded?(__FILE__)
                                  UI.menu("Plugins").add_item("Add Hidden Layer"){AddHiddenLayer.start()}
                              file_loaded(__FILE__)
                              Then restart SketchUp and see if it starts OK with AHL & HPT loaded...
                              Since AHL loads after HPL try renaming its .rb file with a leading # so that it loads beforehand - this might avoid the issue...
                                ArCAD-UK
                                πŸ˜’ Apparently a completely fresh COLD boot this morning and everything is running again with both the hacked and original versions of AHL πŸ˜• Thanks for the help.
                                Another excellent tool from the Master! 😍
                                  ArCAD-UK
                                  Hi Tig, I was playing with this last night testing the boundaries. One thing that πŸ˜• me is I can create cutting components with complex geometry including projecting groups with faces flush with the cutting plane, but as long as there is an ungrouped "loop" of edges SU cuts as expected. In HPT as has been previously mentioned such a component can cause unexpected displacement if there are groups/components projecting from the cut plane.
                                  I appreciate the "fix", I was just wondering if the HPT would benefit from a requirement for a single loop on the cutting plane and ignore all other group/component and non-cutplane entities which would be more in line with the native SU cutting process?
                                    ArCAD-UK
                                    Hi TIG, I get regular bug splats if the Outliner is fully open e.g. displaying contents. Is there a fix or is this an SU problem? I've noticed with a number of plugs that the Outliner window goes manic with some processes but they don't always splat.
                                      It's a know issue with any heavily processed tool.
                                      Recommended that the Outliner is closed or at least rolled up when going intensive operations...
                                        moonray
                                        PLEASE HELP!
                                        Hole punch menu does not appear after plugin installation and requred objects and component peparation. All required folders are ok. 😒
                                        SKETCHUP 2013
                                          @moonray
                                          Let's assume you've installed it properly.
                                          There is NO Plugins-menu item or toolbar.
                                          If you right-click the context-menu has a submenu for the tool.
                                          Some items are enabled/disabled - depending on what is selected.
                                          If you have a component-instance selected that is gluing/cutting and glued to a face then you get the Punch option etc...
                                          Can you post a simple example SKP so that we can see what you have done...
                                          If you have not installed it properly, then you won't get the tool appearing in SketchUp at all.
                                          How did you install it exactly ? πŸ˜•
                                          Your post suggests that the file/subfolder have installed correctly into the Plugins folder... but this might be an illusion...
                                          Can you post a screen-shot of the folder, including its top bars in Windows Explorer...
                                          If you have limited access rights to your Plugins folder Windows can leave you thinking it's installed, but it's not! Limited security permissions is the default for folders inside the Program Files tree - it needs adjusting to allow you to add/manage plugins...
                                          A button/link in the window's top-bars saying 'Compatibility Files...' is a give away...
                                          To set up you Plugins folder correctly...
                                          As an admin [if you are not already one change your status in the Users Control Panel.
                                          Find the Plugins folder and select it
                                          Right-click
                                          Context-menu
                                          Properties
                                          Security
                                          Edit...
                                          set permissions to FULL [read/write] for all users/groups listed
                                          Apply/OK
                                          Also select the SketchUp.exe file [in the same folder] and in the same way...
                                          Properties
                                          Compatibility
                                          Tick the bottom check-box 'Run this Application as Administrator'
                                          Now you can add/manage your Plugins... β˜€
                                            moonray
                                            Thank you for reply!
                                            Yes understand that it is should be ncontext menu (not simple)
                                            I have changed permitions to maximum rights both of exe file and plugins folder but
                                            I still haven't found what I am looking for.
                                            Please see my attached screens and the file.
                                            scene and screenshots of folders
                                            • 8 / 10
