    Installation.problems with parametric_grid.rb
    4 Posts 3 Posters 413 Views 3 Watching
    • atelierpaarA Offline
      atelierpaar
      Hello every Body,
      I downloaded "parametric_grid.rb" and "parametric.rb" from sketchucation Plugin Store
      When starting SU I get the following Error 😮 :
      Fehler beim Laden der Datei parametric_grid.rb
      no such file to load -- ./parametric.rb
      So far I cant get the script to work. Anybody any idea whats going on here?
      Thanks for your comments
      Uli
        glro
        @atelierpaar said:
        Hello every Body,
        Uli
        did you check if "parametric.rb" is among your files in the plugins folder?
        • TIGT Online
          Some 'example' scripts made long ago by @Last need the helper file parametric.rb to function.
          Unfortunately the 'parametric_grid' example expects to be within a subfolder, so it 'requires' like this:
          require './parametric.rb'
          BUT it needs to read like this:
          require 'parametric.rb'
          to work when the parametric.rb file is in the same folder !
          You can edit the file so the error stops, or wait a moment while I update the script in the PluginStore and then get the new version...[mod=:2jkjx7sn]New 'parametric_grid' v1.0a version available now...[/mod:2jkjx7sn]
            atelierpaar
            thank you TIG, everything`s ok now,
            Uli
