    SOLVED by TIG - How can I select all vertical faces?
    7 Posts 4 Posters 830 Views 4 Watching
      JGA
      I have created a basic 3D model of an area, to show a new housing development in context.
      I would like a way to quickly select all vertical faces, so I can paint on a colour for walls, then pick all sloping faces to apply a roof material.
      I can't figure out a way to do tis with the default SKUP tools - is there a plugin available that can do the trick?
      I've tried ThomThoms Selection Tools (v.2.2), it can select almost everything but what I'm looking for!
      Regards,
      JGA
      • TIGT Online
        These one-liners will do this kind of thing...
        Type or easier Copy+Paste into the Ruby Console +<enter>
        ALL vertical faces in selection
        s=Sketchup.active_model.selection;a=s.to_a;s.clear;a.grep(Sketchup;;Face).each{|f|s.add(f)if f.normal.z==0}
        ALL horizontal [up] faces in selection
        s=Sketchup.active_model.selection;a=s.to_a;s.clear;a.grep(Sketchup;;Face).each{|f|s.add(f)if f.normal.z==1}
        ALL sloping [up] faces in selection
        s=Sketchup.active_model.selection;a=s.to_a;s.clear;a.grep(Sketchup;;Face).each{|f|s.add(f)if f.normal.z>0 && f.normal.z<1}
        To do it for all active_entities [no preselection].
        ALL vertical faces in active_entities
        m=Sketchup.active_model;s=m.selection;s.clear;m.active_entities.grep(Sketchup;;Face).each{|f|s.add(f)if f.normal.z==0}
        ALL horizontal [up] faces in active_entities
        m=Sketchup.active_model;s=m.selection;s.clear;m.active_entities.grep(Sketchup;;Face).each{|f|s.add(f)if f.normal.z==1}
        ALL sloping [up] faces in active_entities
        m=Sketchup.active_model;s=m.selection;s.clear;m.active_entities.grep(Sketchup;;Face).each{|f|s.add(f)if f.normal.z>0 && f.normal.z<1}
          JGA
          TIG,
          Thanks very much.
          I've just tested them & all but one work perfectly. The "ALL sloping [up] faces in selection" doesn't pick up a slope in the selection, but the "ALL sloping [up] faces in active_entities" does.
          Thanks again.
          Regards,
          JGA
          • TIGT Online
            @JGA
            There was a typo in the 'faulty' line of code.
            I've corrected it in the original post - if you want to re-get it...
            I typed all of those one-liners from memory, without any testing - so we were lucky that only one had a typo ! πŸ˜‰
              JGA
              TIG,
              That's just showing off now... πŸ˜›
              Just tested - works perfectly, thanks again.
              Regards,
              JGA
                And you can blend these lines also with Inverse Selection by TIG! πŸ˜‰
                • hdpvH Offline
                  hdpv
                  You can test my plugin
                  http://extensions.sketchup.com/en/content/s4u_selectool
                  Suforyou
                  http://www.sketchupforyou.com
