    Making multiple holes in a cylinder
    8 Posts 4 Posters 774 Views 4 Watching
      GrahamForbes
      I need to make a filter box with endplate and cylindrical sides. Imagine a can of baked beans with many small holes in the end and cylindrical body. Endplate (flat surface) I have achived that, but how do I make maybe 100 holes in the cylindrical body. I can Intersect and I can use a second cylinder, making both groups, but it would be very time consuming and difficult to be accurate with either method. I have hundreds of these holes to make. HELP!!
        I can think of several options. You could make a small portion of the cylinder with just a few holes and then copy that to make an array or you could make your array of holes on a flat sheet and use Shape Bender to bend it or you could use a texture instead of "real" holes.
        From the lower left:
        A section with a couple of holes.
        Copied around the center in a radial array.
        Copied upward with a linear array.
        Unneeded faces and edges cleaned up as you go.
        • cottyC Offline
          cotty
          Following Daves suggestion, you can make a component of the little section and hide the lines around that part. This way, you can change the holes easily afterwards...
          my SketchUp gallery
            GrahamForbes
            [attachment=0:2vvs9p7k]<!-- ia0 -->Holes.png<!-- ia0 -->[/attachment:2vvs9p7k]
            Thanks Dave, I am working on this, shape bender seems a great option.Thks.
              GrahamForbes
              Again, great ideas, I shall try this one, many thanks Cotty.
                Thanks for that addition, Carsten. I should have included the component thing. That's what I did in my illustration, too.
                @grahamforbes said:
                ...shape bender seems a great option.Thks.
                Actually, it's not the best option for this application.
                • cottyC Offline
                  cotty
                  I was shure you did πŸ˜‰
                  my SketchUp gallery
                  • BoxB Offline
                    Shall we predict the problems he may have with using shapebender, it won't go all the way around, the holes distort.......
