    Codec incompatible with video size selected? ERROR
    25 Posts 8 Posters 3.1k Views 8 Watching
      samyell77
      Just hope a reinstall will sort it out - will post back once I have some news.
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
        samyell77
        SU pro trial reinstalled, no plugins loaded and still no joy. Same error persists. 😞
        SU Pro 2016
        PC Windows 10
        16gb RAM
        • E Offline
          Ecuadorian
          I also consider it must be a bug. I have never seen anything like that before.
          I guess you'll have to manually export each image. 😕
          -Miguel Lescano
            samyell77
            Hi Gai,
            Are you able to move this to the bug forum just in case someone is inclined to look at it?
            SU Pro 2016
            PC Windows 10
            16gb RAM
              Macker
              Not sure how old this thread is but I've just encountered the exact same problem on a brand new (clean install) windows 8 machine.
              Should also note that the problem is specific to that computer, it renders fine on others.
              Check out my blog @ http://macviz.blogspot.co.uk
                samyell77
                Hi Macker,
                Cant remember exactly how I resolved it but have just checked my settings in export animation. I think I simply changed the codec to Microsoft Video 1 - thats what I have it set on now and am able to export. Try a few different codecs but that one works for me....
                although not sure this is best quality?
                Cheers
                SU Pro 2016
                PC Windows 10
                16gb RAM
                • W Offline
                  woldas
                  YES!! In the save animation dialog box you need to change to .avi format, than in settings change the codec to microsoft Viedo 1, set resolution, close settings box, change to format You desire e.g. .jpeg and VOILA...
                    DOD3R
                    Hi guys, me to i did encounter this thing on fresh SU8. my solution was to switch settings back to .avi change codec to full frames uncompressed, than changed back to .jpg. And i happily batch export scenes after that.
                      Shady Abdeltawab
                      Many Thanks, Guys
                      • andybotA Offline
                        andybot
                        HELLS TO THE YEAH! I had to reinstall and ran into this error. Thanks for the tip!
                        I ❤ Sketchucation
                        • 2 / 2
