    Codec incompatible with video size selected? ERROR
    25 Posts 8 Posters 4.0k Views 8 Watching
      What I meant was to export the animation to a series of stills (jpg or png). Just select the suitable file format in the animation export window. Then you can put the whole thing together in any video editor.
      I know it's just a "workaround" for the time being but you may be at lest export what you need to. Just make sure to export the images into a separate folder (they can easily "populate" your desktop)
        samyell77
        Sorry Gai - thats what Ive actually been trying to do. Export jpg or tif files to use in a printed document. In my screen shots jpg has been selected as the output format. Im not trying to make an animation just using the 'animation export' to allow me to export every scene (without transitions) as a jpg. So if I have 10 scenes I get 10 jpgs or tifs to use in indesign.
        Have tried this with the avi export to to see if it will work as a self contained animation but still no dice - same error message!
        Cheers
        SU Pro 2016
        Dell Precision M4800
        PC Windows 10
        Intel Core i7-4900MQ @ 2.80ghz
        Nvidia Quadro K2100M
        16gb RAM
          Sorry but then I am completely stumped. IMO if on exports to image sequence, the codecs should not even be involved at all.
          I can move the topic to the SU bugs subforum (not that I would hope that anyone will look into it in these days of moving SU from Google to Trimble though)
            samyell77
            Yup - figured that would probably be the case. 😠
            Thanks tho Gai
            SU Pro 2016
            PC Windows 10
            16gb RAM
              samyell77
              Just hope a reinstall will sort it out - will post back once I have some news.
              SU Pro 2016
              PC Windows 10
              16gb RAM
                samyell77
                SU pro trial reinstalled, no plugins loaded and still no joy. Same error persists. 😞
                SU Pro 2016
                PC Windows 10
                16gb RAM
                • E Offline
                  Ecuadorian
                  I also consider it must be a bug. I have never seen anything like that before.
                  I guess you'll have to manually export each image. 😕
                  -Miguel Lescano
                    samyell77
                    Hi Gai,
                    Are you able to move this to the bug forum just in case someone is inclined to look at it?
                    SU Pro 2016
                    PC Windows 10
                    16gb RAM
                      Macker
                      Not sure how old this thread is but I've just encountered the exact same problem on a brand new (clean install) windows 8 machine.
                      Should also note that the problem is specific to that computer, it renders fine on others.
                      Check out my blog @ http://macviz.blogspot.co.uk
                        samyell77
                        Hi Macker,
                        Cant remember exactly how I resolved it but have just checked my settings in export animation. I think I simply changed the codec to Microsoft Video 1 - thats what I have it set on now and am able to export. Try a few different codecs but that one works for me....
                        although not sure this is best quality?
                        Cheers
                        SU Pro 2016
                        PC Windows 10
                        16gb RAM
                        • W Offline
                          woldas
                          YES!! In the save animation dialog box you need to change to .avi format, than in settings change the codec to microsoft Viedo 1, set resolution, close settings box, change to format You desire e.g. .jpeg and VOILA...
                            DOD3R
                            Hi guys, me to i did encounter this thing on fresh SU8. my solution was to switch settings back to .avi change codec to full frames uncompressed, than changed back to .jpg. And i happily batch export scenes after that.
                              Shady Abdeltawab
                              Many Thanks, Guys
                              • andybotA Offline
                                andybot
                                HELLS TO THE YEAH! I had to reinstall and ran into this error. Thanks for the tip!
                                I ❤ Sketchucation
                                • 2 / 2
