Push/Pull without internal faces
Gâday everyone, this is really a suggestion or ârequestâ for an extension.
It would be very easy to make, and likely be used by absolutely everyone. Itâs amazing this hasnât been built before! Or if it has, we canât find it!
The idea is that, when you use a new Push/Pull tool, any âinternalâ faces created in the process would be deleted or culled automatically. The new Push/Pull tool would push / pull as usual, but the original face from which the tool was launched, would be removed afterwards automatically.
Scroll down for an image demonstrating the issue...
Actually, three years ago, a forum conversation started about this, link below, where one of the best and most prolific plugin makers I know of, said: âa plugin could be made fairly easily to re-create the push-pull tool, so that it does not add internal faces when push-pullingâ.
Quote: http://sketchucation.com/forums/viewtopic.php?f=79&t=25856#p222556
Topic: http://sketchucation.com/forums/viewtopic.php?f=79&t=25856As he says there: âhaving to delete each internal face is a major showstopperâ. And it is! If youâre modelling complex geometry, where you push-pull hundreds of times across the model to add edge-loop detail where needed, then removing the âinternal facesâ from every push-pull breaks the SketchUp modellersâ workflow!
Quote: http://sketchucation.com/forums/viewtopic.php?f=79&t=25856#p223169But sadly, this plugin maker, who I quote, never made this plugin - I recently asked him.
Why do we need this plugin?
There are lots of reasons! But hereâs just a few:
Lots of other 3D software suites refuse to deal with SketchUp models, when they contain âinternal facesâ. The other software suites say that these objects are ânon-manifoldâ - they may say something like âat least one edge in the mesh is shared by more than two facesâ or equivalent.
Why run a âCleanUpâ process, after modelling badly, when we could create clean meshes to begin with?! If youâre push-pulling, why not push-pull in the way that you need to from the start, rather than push-pull in a bad way, and then be forced to correct all the errors afterwards?
Many of the various âCleanUpâ plugins donât actually detect / delete the âinternal facesâ. And, even if they did, why not just push-pull, without creating the internal faces, from the start?
All of the plugins that do remove internal faces, also canât help but remove other faces that you will not want removed.How could it work?
The new Push/Pull tool would push-pull as usual, but the original face from which the push/pull was launched, would be removed afterwards. It would only remove faces if they were âinsideâ a mesh.
The regular Push/Pull tool to behave as it normally would, and not be changed.
In practice...
By adding a new Push/Pull tool that works in this different way, the modeller could choose whether and when they they want internal faces created. If they do, theyâd continue to use the regular Push/Pull tool. But, if they donât, theyâd use this new Push/Pull tool! Users could assign a new hotkey to access to the tool from the toolbar quickly, maybe one right next to the P key.
The regular Push/Pull icon could be used for the new tool, but with a little â-Fâ or âEâ somewhere in the icon, just indicating that the tool will subtract the âinternal faceâ or only add edges.
Illustrating the issue...
It already exists.
JPP by Fredo
Or in Artisan
There is also a PushPull multiple inside the toolbarr Projection by Didier Bur!
And there is Remove internal faces by Wikii
With your input, this post could be even better đ
