    [Plugin] Mirror
    211 Posts 72 Posters 474.0k Views 72 Watching
    • P
      photon2
      Wow great plugin, Thanks!
      • F
        function
        is there a way to turn off the prompt at the end of the command, so it never erases original geometry?
        • mitcorbM
          mitcorb
          There probably is. You would have to study the Ruby code and maybe comment out the line(s) that generates it. Conceptually, this would be simple. But I will bet that while you comment out one thing, you might "punch a hole in the bottom of the boat". The author could probably point you to it.
            You can edit the code so it does whatever you want...
            The closing code that asks the question and makes the erase is easily disabled with a leading #
            if UI.messagebox("Erase Original Selection ? ",MB_YESNO,"")==6 ### 6=YES 7=NO
                        copy_group.erase! if copy_group.valid?
                  	else ### NO
                        copy_group.explode if copy_group.valid?
            	        @faces=[]
            	        ents.each{|e|@faces << e if e.valid? && e.class==Sketchup;;Face}
            			self.gluer(sents)
            			@ss.clear
                        sents.each{|e|@ss.add(e) if e.valid?}
                	end#if
            becomes
            #if UI.messagebox("Erase Original Selection ? ",MB_YESNO,"")==6 ### 6=YES 7=NO
                        #copy_group.erase! if copy_group.valid?
                  	#else ### NO
            	        @faces=[]
            			self.gluer(sents)
            			@ss.clear
                	#end#if
            BUT if you want to Mirror and NOT keep the original selected object[s] then how would you do it ?
            Clicking on Yes/No [or just pressing the Y or the N key] is hardly a hardship ?
            • KrisidiousK
              Krisidious
              I never use the delete afterwards either. Mirror is normally my symmetry tool. One of the most necessary tools in computer aided architectural drafting in my opinion. The dialog is not a hardship. But I will probably disable it. When I need to remove a previously mirrored object I'll just delete it. I would say that the delete feature is more needed than not. It's quite traditional in the sense of autocad.
              By: Kristoff Rand
                @Kris
                You are right - I added that final dialog to make the Mirror tool match most CAD applications, which will prompt you after doing the Mirror to Erase/Keep the original selection.
                Feel free to customize it as you will 😕
                • bmikeB
                  bmike
                  Agree with this... maybe 1 in 10 do I delete the object.
                  • F
                    function
                    Thanks for showing where to comment out, I was blowing it up dissecting it!
                    • P
                      PropshopRD
                      I can't see the plug any where in my Tool menu.
                      I had followed the instructions as you set, but I can't find it!
                      Any suggestion?
                      Thx
                        Any suggestion?
                        Thx
                        When it has been correctly installed the tool appears in the Plugins menu, a Toolbar [which you might need to (re)activate] if the plugin's image file is also in the Plugins folder AND the right-click context-menu, when there's a suitable selection... As 'Mirror Selection...'
                        This suggests you might have simply put the ZIP-extracted folder OR the RBZ archive into the Plugins folder, and not 'installed' it correctly ??
                        Or perhaps you don't have FULL Properties>Security>Edit permissions to the Plugins folder itself and so Windows itself is messing you up, by letting you think you have put the files into the Plugins folder, but actually a VirtualStore has been used...
                        So... 'how' exactly have you installed this plugin ?
                        There is [was] a ZIP version around... BUT I recommend that you always use the equivalent latest RBZ archive that is download-able from the SCF PluginStore [linked] - or accessed via the Resources menu above.
                        Install it using the Preferences > Extensions > Install... button [or even better, when the 'Plugin Store toolset' v1.3~ is launched very shortly, you could use its Installer from the ../Plugins/SketchUcation submenu]
                        OR why not just use the latest 'Plugin Store toolset' for your Plugins - to AutoInstall, Manage, and much more... all done from within SketchUp itself...
                        These tools will AutoInstall plugins for you, and can warn about incorrect permissions etc too...
                        Then there's no need to try and do it manually and make mistakes... 😕
                        • RefkaR
                          Refka
                          Dear Mr Tig / Frank Wiesner
                          I have mirror plug in v3.1 revisi 21 Feb 2007 ,i want ask to you sir..
                          Can i edit the script and change it ^_^ .. but for history and ownership remains in the source
                          I hope you are willing,cause i really love it for this tool.. ^_^
                          • RefkaR
                            Refka
                            Sir can i change toolbar name n language.. history n ownership still in source.. ^_^ i have mirror versi 3.1 - 21 feb 2007
                            Plizzz.. ^_^
                              @Refka
                              I recommend you get the latest version of the tool [v3.8], which has many fixes and improvements over the last 6 years ! ...
                              If you want to customize the tool's text output into your own language then please feel free to edit the relevant lines in the script and then use it as you wish.
                              To edit a .rb file you need a plain-text editor like Notepad.exe.
                              Notepad++ is far superior and you can assign syntax highlighting to file-types so '' & "" strings will display in distinctive colors making it easier to edit the file...
                              If you are saving a copy please ensure its encoding is 'UTF-8 without BOM' [aka 'ANSI as UTF-8']...
                              Remember, never use a wordprocessor - that will break the file's encoding.
                              Because of the mottled history of this tool, which some years ago I 'took over' and subsequently rewrote its 'methods' entirely, there has never been a definitive (c) statement in the header. However, I think an implied statement like this:
                              (c) Copyright 2013 TIG.
                              Permission to use, copy, modify, and distribute this software for any purpose and without fee is hereby granted, provided that the above copyright notice appears in all copies.
                              THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                              would be deemed to apply...
                              So you are pretty much free to use it either as is, or modified for your own use, at your own risk...
                              Of course we must assume that you do not plan to sell this modified version, or distribute it widely, and that you will leave credit to the author[s] in the header text...
                              Please do not post modified versions here as it will confuse other users... 🤓
                              • F
                                flyashy
                                Hi TIG,
                                Is it possible to build in a 45 degree inference? It would be such an improvement on the workflow. I do a lot of mirroring at right angles and right now I have to use the protractor tool beforehand to mirror at right angles. I do have the rotation snap enabled in options but the plugin does not seem to use the inference.
                                Thanks.
                                • RefkaR
                                  Refka
                                  tx a lot sir..
                                  • rishikeshavateR
                                    rishikeshavate
                                    Hi guys,
                                    I installed the plugin but it is not working. I can see the plugin in tool bar, in plugin menu and in context menu.
                                    when i select the object and use mirror selection in either way i can not proceed further becoz the next steps (1, 2, 3 selection) is not displaying.
                                    also my statues bar does not show any massage.
                                    Plz Help me guyes.
                                    Thanx
                                      How did you install it [tell us steps, please] ?
                                      Next open the Ruby Console open...
                                      Any error messages when you try to use the Mirror tool ?
                                      This tool is used many hundreds of times a week without issues, so something somewhere is wrong... 😕
                                      I'm wondering if you have another rogue plugin loading that messes with base classes like 'group' and thereby messes up Mirror's legit work...
                                      If you have SketchyPhysics, older-Podium, some newer-'BIM' tools etc try disabling those, restart and try Mirror... Let us know if you find the culprit... There is a 'quarantine' list...
                                      • cottyC
                                        cotty
                                        http://sketchucation.com/forums/viewtopic.php?f=323&t=47371
                                        my SketchUp gallery
                                        • rishikeshavateR
                                          rishikeshavate
                                          @ Tig
                                          Hi Tig.Thanx for ur reply.
                                          I installed it using sketchucation plugin store from sketchup. I installed without any error. also i can see the plugin in plugin, context menu also i can see tool bar for it.
                                          I have SketchyBevel and SketchyFDD installed on my PC. Is sketchy plugin messes with Mirror?
                                          will try after disabling sketchy plugins?
                                            I don't think either of those mess with other plugins, but you never know... so try disabling them and see if Mirror then works...
                                            Do you get any error messages in the Ruby Console when using Mirror ??
                                            Clearly something is wrong because hundreds of users use Mirror hundreds of times every day, and have no issues - so you must have some specific thing causing this...
                                            I would like to 'get to the bottom of it' 😒
                                            • 11
                                            • 7 / 11
