    [Plugin] GlobalMaterialChange v1.4 20110525
    32 Posts 17 Posters 41.2k Views 17 Watching
    • bagateloB
      bagatelo
      @ledisnomad said:
      I know this is an old thread, but I wanted to bring it back... I work on a team and our models get messy. We work on individual pieces, then reload the component in a base model. Even if materials are named the same thing, we get duplicates. After awhile, nobody knows what is what.
      The GlobalMaterialChange script works well to a certain point, but with our heavy model, doing a single swap can take 5 minutes. With over 70 materials, that's half a day's work. Anybody have a way to do this in batches? We could just delete all the materials and start again, but that's not a viable, reusable solution.
      Any thoughts?
      I think this is very useful:
      http://forums.sketchucation.com/viewtopic.php?f=323&t=26013
      If someone can consider my suggestion in last thread can be very better.
        dlong
        I can't tell who impresses me more: Google for letting the free Sketchup use these Ruby scripts, or TIG for coming up with EXACTLY what I needed for today. Thank you a million for a script that works exactly as advertised.
        I'm on a Mac and running the just-released 8.0.4810 and this script made it a snap to swap out a material. Thanks again.
          jster
          Thanks for the very useful tool!!
            Here's an update http://forums.sketchucation.com/viewtopic.php?p=96863#p96863
            If you run it without anything selected it will now change the materials of everything in the model, including inside ALL groups or definitions - even if they are unused [i.e no instances placed]...
            • irwanwrI
              irwanwr
              i just downloaded this plugin. i hope i know how to use it.
              thank you very much for this one. i've been looking for something like this quite a while.
              it might help me reduce file size significantly to save. 👍
                Also look for MaterialConsolidator and similar tools... 😉
                • irwanwrI
                  irwanwr
                  yes, of course. certainly. thank you 😄
                    Dimethil
                    I love this plugin, thanks.
                    (it saved my life ^^)
                    • DDrockD
                      DDrock
                      Sir let me know how to install it.. do i simply paste it sketchup folder?? dont have exact idea.. thank you
                        @ric
                        Find and read the several tutorials on how to install various kinds of Plugins.
                        http://sketchucation.com/resources/tutorials/37-beginner/108-installing-sketchup-plugins
                        There are other useful guides in that section too...
                        In synopsis...
                        A simple .rb [like this one] just needs to be put into the Plugins folder and SketchUp restarted.
                        Then you use it as instructed...
                        You will need to set your Plugins folder's security permissions to FULL [Properties>Security>Edit>FULL>Apply/OK] - by default Windows sets restricted permissions [for everyone, including admins] for all such folders with the Program Files folder.
                        FYI...
                        ZIPs need the files/subfolders extracting and moving into the folder keeping them in the same relative relationships...
                        RBZs need installing using >=v8 Preferences>Extensions>Install... button - if you don't have that button update your v8 to the newest release, OR get v2013?
                        You can rename a RBZ with a final .ZIP and treat it like a ZIP archive - IF you are a masochist !
                        OR even easier... ☀
                        Nearly all of the Plugins with threads on SketchUcation are available in the SketchUcation PluginStore - open its page through the Resources menu above... Get the RBZ and manually install it...
                        You can even install the SketchUcation Plugin Store Toolset from there [or from its own dedicated link] - this displays all of the available Plugins in a dialog within SketchUp and AutoInstalls them for you without you ever having to worry about where the Plugins folder is etc... [provided of course that you have set permissions to FULL!]
                          A little Question 😄
                          When you apply a Texture to the "external" faces of a component the instances are not changed!
                          http://sketchucation.com/forums/download/file.php?id=129376&t=1
                          When you apply a Texture "inside" a component (or an instance) all faces of Components are changed!
                          http://sketchucation.com/forums/download/file.php?id=129377&t=1
                          How automate the process when you Pick the texture of the "external" face of the component for have the second result ?
                            mprose7
                            Is there chance to add auto function which would change all 'mat1', 'mat2', 'mat3' to 'mat', since sketchup automaticly add number to 'mat' if i import models with identical named mats but changed color. example: i copy window from other model, it has material named glass, but it is a bit more blue than glass from scene and now i have material glass and glass1 in scene...
                              If you run this code snippet in the Ruby Console, then all matching materials are equalized 'by name'.
                              So in the example patt='glass' - it then resets the RGBA/texture of 'glass1', 'glass2' etc.
                              Then you can use my MaterialConsolidator plugin to compact all of the model's materials which have exact matching RGBA/texture into just one material...
                              http://sketchucation.com/pluginstore?pln=materialconsolidator
                              # !!! Use with care - all materials starting with 'patt' take its color/transparency/texture/size etc.
                              patt='glass' #change as desired
                              model=Sketchup.active_model
                              mats=model.materials
                              mat=mats[patt]
                              unless mat; puts "NO material named '#{patt}'"; return nil; end
                              col=mat.color
                              r=col.red
                              g=col.green
                              b=col.blue
                              c=Sketchup;;Color.new(r,g,b)
                              a=mat.alpha
                              t=mat.texture
                              model.start_operation('mat_equalizer',true)
                              if t; f=File.join(Sketchup.temp_dir,File.basename(t.filename)); t.write(f); h=t.height;w=t.width ;end
                              mats.each{|m|p m.name; next unless m.name=~/^#{patt}/; m.color=c;m.alpha=a; if t; m.texture=f; m.texture.size=[w,h]; end }
                              model.commit_operation
                              #use material consolidator to get just one material after this...
                                mprose7
                                Is there any option to automate this process - can script automaticaly search materials like glass, glass1, glass2; chrome, chrome1, plastic, plastic1, etc
                                And then consolidate with consolidate plugin??
                                • JClementsJ
                                  JClements
                                  November 20,2022
                                  It has been a while since the last posting and SU2022 is the current version.
                                  Any reason this should not work or is there anything in the current ruby version that could improve the performance of the plugin?
                                  I have found that it does not seem to work properly if the selection of objects contains copies of groups or components. This behavior occurred in tests with both SU2017 and SU2022.
                                  Please see the attached example which I used for testing.
                                  test (Su 2017).skp
                                    Copies of groups are pretty much like copies of component-instances, BUT if you edit [open] a copy of a group then SketchUp always automatically makes it unique [even if you do nothing in the edit-context] - this is unlike a component-edit operation... with components you must choose to 'make unique' which will then limit any changes you make to only that new definition's instances' entities.
                                    Any materials edited inside an edit-context are shown in all of the instances of that component - so if you only want to change one of them you must choose 'make unique' from that instance's context-menu before choosing to edit it...
                                    This is unlike if you add materials to the 'container' itself [i.e. group or component-instance] then these are only applied to just those specific 'containers', however, unlike textured materials on faces, you cannot 'adjust' textured materials on 'containers' using the native context-menu item. But solid colors work fine... This limits the usefulness of this approach as with roof tiles or sidings etc you probably want to adjust the textures location of orientation etc...
                                    • JClementsJ
                                      JClements
                                      So why do you think this characteristic of copied groups was implemented by SU in the 1st place? What is the benefit for modeling process? This behavior feels more like a bug rather than a benefit.
                                      Is there anything that can be done in ruby to simulate the process opening and editing groups so that the copies are “unique”
 circumventing the manual process?
                                        'Make unique' is accessible through the API thus...
                                        This works on groups in each separate entities context...
                                        model = Sketchup.active_model
                                        model.start_operation('Uniquify Groups', true)
                                        model.active_entities.grep(Sketchup;;Group).each{|g| g.definition.instances.length > 1}.each{|g| g.make_unique }
                                        To process all groups [inside every context or nested inside components or other groups]...
                                        model.start_operation('Uniquify All Groups', true)
                                        model.definitions.each{|d| d.group? && d.instances.length > 1 }.each{|g| g.instances.each{|g| g.make_unique } }
                                        Copy/paste code into the Ruby Console and press enter...
                                        It's one-step undo-able through the Edit menu.
                                        • JClementsJ
                                          JClements
                                          Thank ,you TiG that worked!
                                          Any chance of incorporating the code into GlobalMaterialChange2.rbz ?
                                          And/or a separate Plugin for displaying an option (such as "GroupCopy UnInstanting") in the Context Menu that would appear if objects are selected?
                                          It come in handy for other issues that might happen with copied groups.
                                          P.S.
                                          Your previous post regarding editing a group, gave me an idea of how to make it easier to manually open multiple occurrences of groups containing materials.
                                          I gave all groups containing materials an Instant Name that included the text "....(with material)". Then, by opening the Outliner, and searching for "(with material)" and double-clicking on each find to open and close the group. It was a fairy quick process compared to opening each group in the modeling window.
                                          If a group's instant is properly named then all is good, BUT it takes discipline when creating groups in the first place.
                                          • 2 / 2
