    V-Ray 1.6 beta stopped loading ? [Solved]
    renderpluginsextensions
    3 Posts 2 Posters 473 Views 2 Watching
      sherwood11
      V-Ray 1.6 beta for Sketchup was working fine . . .
      Today, I tried loading V-Ray 1.6 beta for Sketchup with Sketchucation Plugins Manager v.1.2.0 (as usual) and I got this message in the lower window :
      *The webpage cannot be found
      HTTP 404
      Most likely causes:
      There might be a typing error in the address.
      If you clicked on a link, it may be out of date.
      What you can try:
      Retype the address.
       Go back to the previous page.
       Go to  and look for the information you want.
      More information
      This error (HTTP 404 Not Found) means that this program was able to connect to the website, but the page you wanted was not found. It's possible that the webpage is temporarily unavailable. Alternatively, the website might have changed or removed the webpage.*
      I also tried loading it manually without using the Sketchucation Plugins Manager. I removed
      the exclamation at the end of the file 'vfs.rb' (e.g. vfs.rb! ) and reloaded Sketchup.
      I don't see it under View > Toolbars to open the toolbar
      I don't see it under the Tools menu
      I don't see it under the Plugins menu
      I don't see it under the Draw menu
      Whats going on ? . . . Any thoughts would be appreciated.
      • dkendigD Offline
        dkendig
        I don't know what the SketchUcation Plugins Manager is, but you can enable or disable V-Ray for SketchUp through the Window->Preferences->Extensions dialog. Just check or uncheck V-Ray for SketchUp.
        Devin Kendig
        Developer
          sherwood11
          Thanks Devin πŸ‘
          That was the problem, your solution worked.
          ( e.g. Window->Preferences->Extensions dialog. Just check or uncheck V-Ray for SketchUp )
          'SketchUcation Plugins Manager' is a 'plugin' that helps manage 'extensions' and 'plugins'.
          Initially, I enabled V-Ray through the Window->Preferences->Extensions dialog.
          Some how, down-the-line, the extension status changed and I didn't realize it.
          Appreciate your help,
          Sherwood
