    Forcing a Screen Update during a Ruby script
    11 Posts 5 Posters 1.4k Views 5 Watching
      KevinKarney
      I am running a shadow modelling study covering a year . I use a simple plug-in script that increments the date by a day at a time. That all runs fine - the shadows move as expected.
      But while the script runs, I want to see the Shadows Info dialog refresh as the date changes. Presently the Shadows Info dialog only visibly updates when the script has completed.
      Anyone know of a way to force a screen refresh while a script is running ??
      Any help greatly appreciated... I have wasted too much time with this already!
      Best wishes
      Kevin Karney
      Best Regards
      Kevin Karney
        You might need to refactor your loop to use a timer. Timers allow for the rest of the system of do some work. Might just give it enough time to update the viewport.
        • Dan RathbunD Offline
          Dan Rathbun
          The Shadows dialog is actually an "inspector" toolwindow.
          So try this module function call:
          UI.refresh_inspectors()
          I'm not here much anymore.
            KevinKarney
            Dear Dan
            Many thanks for troubling to reply. But I am still stuck! The Inspector just updates when the loop is finished.
            require 'sketchup'
            UI.menu("PlugIns").add_item("Change Date") { change_date_loop }
            def change_date_by_one_day
            Sketchup.active_model.shadow_info["ShadowTime_time_t"] =
            Sketchup.active_model.shadow_info["ShadowTime_time_t"] + 606024
            shadowinfo = Sketchup.active_model.shadow_info
            refreshed_view = Sketchup.active_model.active_view.refresh
            def change_date_loop
            for the_step in 1..365
            sleep(0.025)
            Best Regards
            Kevin Karney
              Did you try with a timer?
              Or... Maybe the FrameAnimation class....
              Sent from my LT25i using Tapatalk 2
              • TIGT Online
                This works fine for me.
                The dialog updates and so does the view.
                The statusbar shows the day
                require('sketchup.rb')
                module TIG
                	UI.menu("PlugIns").add_item("All 365 Days"){self.change_date_loop()}
                	def self.change_date_loop()
                		model=Sketchup.active_model
                		365.times{|i|
                			sleep(0.025) ### change step time here
                			model.shadow_info["ShadowTime_time_t"]=model.shadow_info["ShadowTime_time_t"]+(60*60*24)
                			Sketchup.status_text="Day #{i+1}"
                		UI.beep ### when done
                  driven
                  only The statusbar text changes on a mac... nothing else
                  • TIGT Online
                    on my PC it works fine !
                    The shadow dialog changes and the screen image changes at each step...
                    If the OP had said they had a MAC we might have avoided a dead-end...
                    @driven: Can you make any variant of my PC-good code work?
                    Thought: If Users want us to help them efficiently, then they MUST add their Version and OS to their User-Profile... πŸ˜’
                      driven
                      I'll give it a go... I'm curious why it didn't work out of the box...
                      I often just try bits you and others post to see if they work on a mac.
                      Thought: If Users want us to help them efficiently, then they MUST add their Version and OS to their User-Profile... :roll:
                      I think the OP's on a PC, but filling in the profile would be useful,
                        driven
                        @Tig
                        this does it for the view
                                 model.active_view.refresh || Sketchup.active_model.active_view.invalidate
                        I'll try and find the dialog updater now...
                          This is the reason the Animation class is there for: http://www.sketchup.com/intl/en/developer/docs/ourdoc/animation.php
