    Weave Pattern Question
    5 Posts 4 Posters 442 Views 4 Watching
    • F Offline
      Futurepast
      Been playing with a weave for practice and came up with this simple weave but the gaps are too great between the fibers. Is there a method to tighten it up or is it easier to just start again? Just interested nothing critical πŸ˜„
      weave exorcise.skp
      • cottyC Offline
        cotty
        If you change to parallel view, you can notice that the fibers have diffent positions and it will be difficult to minimize the different gaps simultaneously. If the thickness of the fibers is not important, you can use the scale tool in one component to reduce the distance.
        my SketchUp gallery
        • gillesG Offline
          gilles
          You may find some interest there:
          http://sketchucation.com/forums/viewtopic.php?f=15&t=29342&hilit=parisian+fence
          • F Offline
            Futurepast
            gilles, VERY interesting thanks! Something new to learn πŸ˜„
              Mike, to answer your specific question, it wouldn't be an easy thing to adjust the spacing between the ribbons. It would require a change in the radius of the curves. The Scale tool could be used to squash things flatter but it would make the ribbons thinner, too.
              Are you thinking of a sort of panel of woven wood strips? If so I think the idea from the Parisian Fence is good. Make a small section that you can repeat and make that a component. Then copy that into an array. I do that for grilles. Here's a simple example.
              http://farm7.staticflickr.com/6023/5979597868_808f4b6fcc.jpg
              This grille is made of three different components, shown on the right. The faces that fall in the seams are deleted (magenta is the back face color for this example) and the seam lines on the horizontal surfaces are hidden.
