    Cant install sketchup 2013 upgrade!!! HELP
    8 Posts 4 Posters 4.6k Views 4 Watching
      samyell77
      Im having lots of problems trying to install Sketchup 2013 Version 13.0.4xxx
      I have downloaded the MSI file but am getting an error message every time I try to install. I believe this is a problem that others are having but haven't seen a solution as yet.
      I was only able to install the SU 2013 v 13.0.3xxx from the MSI file (the .exe thinks Im not running windows 7 which I definitely am). There doesn't appear to be a .msi file for the 13.0.4 version? Can this be made available as SU is crashing every 10 mins and is impossible to work with.
      Please take a look at this post from one of IT support guys with more tech detail on it. No one has come back to him with a solution and the MIS file suggested is still for version 13.0.3xxx .....!
      Google Product Forums
      (productforums.google.com)
      Am thinking about downgrading to SU 8 as SU 13 is pretty much useless at the moment - not what I paid for!
      Any help much appreciated.
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
      • ely862meE
        ely862me
        Hi !
        I haven't heard of anything like this yet . Please be patient as I am sure soon enough someone will tell you what is wrong .
        Have you tried to perform a clean install(uninstall sketchup 2013 and reinstall it) ? I am using win 7 64bit and everything works well .
        Elisei (sketchupper)
        Come and See EliseiDesign
          samyell77
          Yes - have uninstalled and reinstalled twice and no dice! Really struggling and getting crashes all over the place.
          Was able to find the .msi for the 13.0.3 upgrade but not the 13.0.4...
          Figure it should be an easy fix ......
          SU Pro 2016
          PC Windows 10
          16gb RAM
            Andrew, thank you for taking the time to post that explanation. It's very clear.
            A question comes to mind, then. If the user downloads the file, such as "SketchUpProWEN.exe" and changes its name to "SketchUpProWEN(1).exe" or something before trying to install it, would that get around the problem with installing and the PCA?
              samyell77
              Hi AndrewS - I have scan read your post but will come back to read in more detail later. Thanks for the explanation tho - much appreciated. I have now been sent a link to the .msi for version 13.0.4xxx and have installed with no issues.
              I put this issue to the sketchup help page (sketchup pro support) and received an email within 24 hours so very pleased with that! Quote and link to file below if anyone needs it....
              Thanks for your note. Sorry about the problems you're experiencing and for the incorrect link to the MSI file. We've fixed that link now, but you can follow the link below to obtain the proper (current) MSI file you need:
              http://dl.trimble.com/sketchup/2013/en/SketchUpPro-2013-0-4124-EN.msi
              Regarding the .exe file thinking you are on Windows XP, following the steps below should resolve that problem:
              1. Right-click the SketchUp installer icon
              2. Choose Properties
              3. Choose the Compatibility tab
              4. Click the box for "Run in ... compatibility mode"
              5. Choose Windows 7 from the drop-down list
              Sam
              SU Pro 2016
              PC Windows 10
              16gb RAM
                samyell77
                AndrewS - just read your explanation. As DaveR said, very clear so thanks for that.
                Sam
                SU Pro 2016
                PC Windows 10
                16gb RAM
                • AndrewSA
                  AndrewS
                  @samyell77 said:
                  Hello,
                  This is a known problem that we're working to prevent in a forthcoming release. In the meantime, see below for a procedure to correct this yourself.
                  Explanation:
                  Believe it or not, the code within our installers that checks the operating system version is correct. The problem is that although you have Windows 7, when the SketchUp installer performs its version inquiry, Windows lies and says you're running Windows XP SP 2. Since our installer wants you to have at least XP SP 3 or newer, it exits without installing.
                  This is the correct behavior in the event that your operating system really is too old, but in your case, we have to stop Windows 7 from lying so you don't get that message anymore.
                  [highlight=#ffff00:l0lymucg]Fix Procedure:[/highlight:l0lymucg]
                  *If you are running Windows Vista, 7 or 8 and are told it's not new enough for SketchUp 2013 to install.
                  1. Download the SketchUp EXE installer.
                  2. Locate the SketchUp EXE installer on disk. Its name will be something like "SketchUpProWEN.exe" and should be in your "Downloads" folder.
                  3. Right-click on the installer EXE and choose "Properties".
                  4. In the properties window, select the tab marked "Compatibility".
                  5. Notice the checkbox setting labeled "Run this program in compatibility mode for:", followed by a dropdown box that probably shows "Windows XP SP2". This is the offending setting that causes Windows to lie to the SketchUp installer.
                  6. Disable compatibility mode by un-checking that setting.
                  • If the checkbox is grayed out (disabled) and cannot be changed, do as follows:
                  • Click on the button "Change settings for all users".
                  • Disable compatibility mode by un-checking the setting.
                  • Click "OK" to close the "Compatibility for all users" window.
                  1. After compatibility mode is disabled, click "OK" to close the properties window and return to Windows Explorer.
                  2. Double-click on the EXE to launch the installer.
                  Although you were able to work around it before using the MSI installer, that is definitely not the preferred method. Please follow the procedure above instead, as it actually fixes the root cause of the issue.
                  I hope this helps you and anyone else who stumbles onto this thread.
                  Thanks,
                  Andrew
                  Andrew S.
                  SketchUp Release Engineer
                  • AndrewSA
                    AndrewS
                    Hey everyone!
                    Until now, I knew the basic nature of how this problem occurs. We noticed and investigated it during SketchUp 2013 development, even going so far as to implement a fix we thought would prevent it from ever happening again. Imagine my surprise at seeing it once or twice during the beta period and now continuing to get support inquiries about it. With no apparent pattern to who sees it or why, I just couldn't figure out its random persistence...until now.
                    After thinking about it some more this afternoon, I just had an epiphany about exactly what's causing this behavior. Although the only method for preventing this is not something I can readily implement, I'm thrilled to have figured out the root cause of this problem's continued appearance, despite our previous countermeasures.
                    A (typically) lengthy explanation follows.
                    Background
                    When Windows Vista was released, Microsoft changed enough of the Windows internals to break backward compatibility with many legacy programs. This compelled them to create a "compatibility mode" to help users install and run programs made for older versions of Windows under Vista. When in compatibility mode, Windows changes its behavior to mimic an older operating system in an effort to play nicely with software that would not work otherwise. This feature continues in Windows 7 and 8 today and can be very helpful when dealing with software that wasn't explicitly written for newer OSes. An important component of compatibility mode is the "Program Compatibility Assistant" (PCA), a system process which operates in the background to discover and correct incidents of program incompatibility. Think of it as a troubleshooter that keeps an eye on things and gets involved to automatically fix perceived compatibility issues in legacy programs when they arise.
                    However, if a program was actually written for compatibility with the OS you're running, it's important that the PCA never get involved because enabling legacy compatibility mode for a program that doesn't need it might cause more problems than it solves. An example of such a problem is that which started this thread, where our perfectly Windows-7-compatible installer is being mistakenly launched in compatibility mode and behaves incorrectly as a result. In order to prevent the PCA from interfering unnecessarily, a newly created EXE must include a "manifest" file that explicitly declares which operating systems it was targeted to support.
                    How the PCA works
                    The PCA works by monitoring certain attributes of a program's execution. If you launch a program that does not include a manifest stating compatibility with the OS you're running, then the PCA will monitor that program and try to determine if it ever misbehaves. If it detects misbehavior at any time while monitored, then when the application terminates, it will pop up a dialog to ask if you might like to try re-running it in compatibility mode instead. If you ever happen to choose "yes", then the file and path name of the application in question is added to the registry in a section marking those files which should always be run in compatibility mode and then it sets the flag on the file with a default value. After that, unless the "compatibility mode" option is manually disabled, the program will forevermore be launched in a context where Windows masquerades as an older operating system than it actually is. In the cases that concern us, the PCA chooses a compatibility mode for Windows XP SP2, which is older than the SketchUp 2013 installer allows, thereby causing it to abort installation.
                    Here's the curious part
                    The SketchUp 2013 installer was explicitly written to include "Windows Vista" and "Windows 7" compatibility statements in the application manifest. Therefore, the PCA service ignores it and will never get involved with our installer on those OSes. That means the Windows 7 PCA isn't responsible for having enabled compatibility mode on that file. Given also that we have yet to find a case of a user going out of their way to invoke compatibility mode and also cannot find any group policies that could be responsible for blindly enabling compatibility mode for the entire system, why then do we see that the tell-tale compatibility setting is enabled and causing installation problems for some of our users?
                    And now the twist
                    This is the part I just realized this afternoon that solves the mystery.
                    None of this is actually a problem with SketchUp 2013. It's actually SketchUp 8's fault.
                    SketchUp 8 vs. PCA
                    The SketchUp 8 installer does not contain the application manifest to declare its compatibility with Windows Vista or Windows 7. It isn't that the SketchUp 8 installer is incompatible, but just that the need for a manifest was not known to us back in the time of SketchUp 8, so we never took the proper steps to include it. As a result, when running the SketchUp 8 installer, it's monitored by the PCA and as explained above, if any "misbehavior" is detected, the PCA will pop up a dialog to tell you that it thinks the installer may have failed prematurely due to a compatibility problem and ask if you wish to possibly try it in compatibility mode instead.
                    Why does the PCA think the SketchUp 8 installer misbehaved? Well, the PCA detects that the program is an installer and therefore assumes if it completes correctly, the "Add/Remove Programs" (aka "Programs and Features") menu will necessarily be changed if the installer runs correctly to completion. Therefore if for any reason the "Add/Remove Programs" menu remains unchanged when an installer exits, the PCA thinks it misbehaved. Upgrade scenarios and even launching the installer and clicking "cancel" are both circumstances in which the installer will exit without changing the "Add/Remove Programs" list, so those are cases where the PCA will probably show up, even though nothing actually went wrong. Then if you happen to dismiss the dialog without reading it (such as by clicking too fast or hitting "Enter" for some reason), the default choice is to affirm that the installation was a failure. Then the file gets marked as needing to run in compatibility mode in the future.
                    I've saved the best part for last
                    Here's where it all comes together. You may have noticed that whenever we launch new versions of SketchUp, they're always available at the same web address and are always named something generic like "SketchUpProWEN.exe" or "SketchUpMFR.dmg". There are numerous reasons why we do this which I won't get into, but this is a critical factor in explaining how the SketchUp 2013 installer is being sabotaged by SketchUp 8.
                    If at any time you downloaded and ran a SketchUp 8 installer by a name like the one above (aka SketchUp 8 M4 or M5, before we launched 2013) and for any reason had the PCA dialog pop up and then ever clicked "yes" when asked if Windows should use compatibility mode for that program, the PCA recorded that file's name in the Windows registry with a note to say that it should always be opened in a default compatibility mode for (Windows XP SP2).
                    Some time later, you realized your download folder was getting full and confusing, so you either deleted the old SketchUp 8 installer, or renamed it so you could better tell what it was.
                    Fast forward to today.
                    If you download SketchUp 2013, you're going to get a file named exactly like the one you got for SketchUp 8, saved to the exact same place as the old one--your downloads folder. Now, when you double-click to launch it, the PCA rears its ugly head and BOOM, you're stuck in Windows XP SP2 compatibility mode for the SketchUp 2013 installer, even though none of us intended it to be so.
                    • It doesn't matter that this is a brand new file that you've never had on your computer before.
                    • It doesn't matter that the contents of this file are nothing like the old SU 8 installer that caused compatibility problems in the past.
                    • It doesn't matter that we've included the correct application manifest inside of this installer, declaring that it's perfectly Windows 7 compatible.
                    • It doesn't matter that you either deleted or renamed the old SketchUp 8 installer and it might not even be anywhere on your computer anymore.
                    You see, Windows couldn't care less that we've done so much to differentiate this new installer from the trouble-making SU8 installer. The only thing it cares about is that there's a registry entry for a file by that name which stipulates that it must run in compatibility mode. That fact alone puts the scarlet letter on your newly downloaded installer, forcing you into an undesired compatibility mode that SketchUp 2013 doesn't support. It's absolutely ridiculous. If this "feature" were integrated directly into NTFS (imparted at the filesystem level instead of in the registry), or at least if the registry were updated to track any time a tagged file is moved or renamed, neither the installation problem nor this thread would ever have existed)!
                    Mitigation
                    If your registry contains a compatibility mode flag for a given file, there are only two ways to prevent it from causing a problem. Either you can follow the procedure mentioned in the previous post and turn off compatibility mode for the file, or you can rename it to fool the registry into forgetting about the compatibility mode.
                    Really, that's all? Just rename the file Yep.
                    Correction
                    I've come back to edit my original post on this point in order to correct an invalid assumption I made regarding the rename procedure. When I first made this post, it was entirely theoretical; I hadn't been able to verify any of the points I stated above. It just suddenly made such undeniable sense of what was previously such a baffling problem that I was certain this newly discovered explanation was correct. Well, I miscalculated one point.
                    I expected that if I were to tag file as needing a compatibility mode and then rename it, the registry would be updated to follow the file by the new name, meaning that simply renaming a file would never clear the flag. I likewise thought deletion of a file should clear the compatibility flag and assumed the observed behavior of persistence was merely an unintended bug. After all, hadn't anyone considered what would happen if a generic file like "setup.exe" ever got tagged with the compatibility flag? It would affect every file by that name thereafter and cause anarchy! It just seemed obvious that the only way to implement a reliable strategy for implementing compatibility mode would involve updating the flag updated with filesystem changes. But evidently Microsoft and I define "obvious" differently.
                    Once I finally had a chance to directly test all of these theories, I found that renaming a file actually does clear the flag, which means rename and delete are both working as intended and my guess on that point was wrong. To prevent confusion for future readers, this section is updated to remove those misunderstandings and explain things as they really are.
                    I contend that Microsoft failed to fully consider all of these possibilities in designing the compatibility mode features. But then again, I'm biased by the fact that this entire problem would never have existed if not for the failure to make the compatibility flag follow the file across renames and deletes.
                    Download Improvements
                    Now that I've taken you through the whole explanation about how this problem came about, there's just one last point to make about how we should handle this in the future. A straightforward solution on our end is to change the download name of the files we serve so that the name is different from anything it was in SketchUp 8, thereby preventing the sabotage. Then the next problem to tackle becomes the fact that for numerous reasons that shall remain unexplained, despite being straightforward, it's nevertheless difficult, time-consuming and un-fun to make changes in all the places that have to be coordinated to keep our whole download system working correctly. Yuck.
                    That's all, Folks!
                    I hope this helps anyone who runs across this problem again. And know that we will try to find a good solution to this so it won't keep happening forever.
                    Comments and questions are welcome.
                    Cheers!
                    Andrew
                    Andrew S.
