    Safe place to store user-defined parameters
    114 Posts 9 Posters 24.4k Views 9 Watching
      Also, you should use ENV["LOCALAPPDATA"] || ENV["APPDATA"] so you can support XP at no extra effort πŸ˜„
      What folders does this yield on XP? Under Win7 it's both in the user directory.
      • fredo6F
        I will use the parent of ENV["TMPDIR"] only on Mac. Apparently, this directory has a long cryptic name, which I assume will only contain valid characters.
        On Windows, this is more of a problem is ENV["LOCALAPPDATA"] cannot be manipulated from Ruby dues to non Ascii characters. It's not only for creating subfolders there, but also to manage filepaths of files to be created and updated.
        The best I can do is to check if the username contains non-ascii characters and then simplify the name to Ascii, and create a folder with that simplified name in C:\users. This really becomes convoluted!!
        There must be a trick however, because when Sketchup installs, it sets the default file locations pointing to the "MyDocuments" folder, whose name also contains the username (something like C:\Userfiles\<username>\Documents\). But maybe these locations are not used from Ruby.
          Creating random folder directly in the location where user folders are? I don't think people would too happy about this. I'd like to explore if we can get the 8.3 filename for the appdata folder.
          Correct - SketchUp itself has no problems with Unicode paths. It's the Ruby 1.8 core.
          • fredo6F
            Actually as I use both, LOCALAPPDATA first and then APPDATA.
            For info, on WindowsXP, ENV["APPDATA"] is defined and uses the old Windows user directory in the form of C:\Documents and Settings\<username>\Application Data.
              Got a full list of ENV variables under XP?
              Btw- if I recall correctly "Documents and Settings" is localized to the user's language, isn't it? (without the shim that Vista,Win7, win8 uses)
              • fredo6F
                We could also substitute <username> in the paths by
                • Default on Win7, Vista, Win8
                • All users on XP
                At least this will avoid the problem of unicode in the username.
                  • All users on XP
                  And the setting would not be per-use - but per computer. ...which might not be a big issue since the plugin folder is shared by all users.
                  But again I raise my concern that XP paths might be translated. "All users" I think is "Alle brukere" in Norwegian XP. (I can dig out my old XP machine and test.)
                    driven
                    Just found a BIG PROBLEM with the 'TIG' and new 'FREDO' path trick on my mac.
                    My User 'private' settings for 'BOTH' are now available to any account on my computer or connected to my network.
                    By stepping up stream, external to ENV["TMPDIR"] you are bypassing the LOCK to other user accounts and network traffic.
                    So my SFC Password Cookie and my Fredo settings are usable from any account, I do not expect a Plugin to share this type of information with the world.
                    Please move these back into User Space asap.
                    This could be a huge problem on a work or university network...
                      slbaumgartner
                      Confirm: the parent of ENV[TMPDIR] has permissions drwxr-xr-x on my Mac - that means it is readable by anyone, though only the owner (me) can write new files there. ENV[TMPDIR] itself is drwx------, which means it is inaccessible to anyone but me. This is not a big deal if you are the only user on your computer, but a serious issue if anyone else has access.
                      Steve
                      • fredo6F
                        I think I will default to the old method of DEFPARAM_Dir in the SU Plugins directory πŸ˜› 😒
                          Using Win32 API calls I've been able to get short (DOS 8.3 style) path name to appdata. I need to run some tests to make sure it works under XP etc.
                          • fredo6F
                            Trying to recap
                            1) On Windows
                            For the non-ascii username, we have a much more general problem, because Temp directory and very likely any files (skp, materials), are going to be stamped with the username in the file paths. So nothing will work. For instance, I prepare the HTML files of webdialog boxes in the Temp directory. This is also where I put some traces.
                            --> I will ignore this until Sketchup moves to Ruby 1.9.2 which solves the problem (or thomthom to find a solution!). Too bad for users having a non-ascii name!
                            For parameters, the usage of LOCALAPPDATA and APPDATA is OK. It is based on users and should correspond to writable areas
                            --> I will use this method
                            2) on Mac
                            For the non-ascii username, apparently there is no issue with non-ascii usernames (to be confirmed), but anyway, the Temp dir is independent, writable and only visible to users. In addition, the ~/ notation allows avoiding having the user name in the path
                            --> NO issue there
                            For parameters, there are visibility issues with the parent folder of ENV["TMPDIR"]. So the method cannot be used.
                            --> I will use driven's method based on a root directory ~/Library/Application Support/ with a hidden folder "LIBFREDO6_DATA_Dir" under which I will create the files and subfolders.
                            It's interesting to see that we have had a long debate on a basic question which we should expect to be covered by Sketchup itself. I think we should formulate it clearly for the Trimble SU team to address it in SU 2014.
                              As for OSX, what about this:
                              plugin_path = Sketchup.find_support_file('Plugins') path = File.join( plugin_path, '..', '..' ) File.expand_path( path )
                              Making some assumption here, but tested under SU8 and SU2013 on OSX 10.8.3:
                              /Library/Application Support/Google SketchUp 8 /Users/thomas/Library/Application Support/SketchUp 2013
                                @fredo6 said:
                                1) On Windows
                                On my Win7 systems I tried, the TEMP/TMP ENV variables returned a short (DOS 8.3 style) path name. These short paths was writable with Ruby 1.8 as the system resolved their real paths. (I assume because the short paths where given to the ANSI version of the system file functions which in turn handled it.)
                                There also include username in the path and may be non-writable. In fact - you are more likely to get issues here because the ENV variable doesn't return a short path - but a path string with replaced characters.
                                @fredo6 said:
                                2) on Mac
                                --> NO issue there
                                Unicode filenames works under OSX with Ruby 1.8 because the file system functions calls handles UTF-8 strings.
                                What about under '~\Library\Application Support\SketchUp 2013' ? That way the data is isolated from version to version.
                                • fredo6F
                                  On my Windows 7,
                                  ENV["TMP"] --> C:\Users\Fred\AppData\Local\Temp
                                  ENV["LOCALAPPDATA"] --> C:\Users\Fred\AppData\Local
                                  So I don't see the short Dos 8.3 notation on my PC
                                  Anyway, since the releasing of my scripts I have been using ENV["TMP"] and I never came across a user having problem with non-ascii username. So maybe very few users do set up their PC with a non-ascii username
                                  On Mac,
                                  It seems SU 13 plugins is installed under ~/Library/Application Support/SketchUP 2013/Sketchup/Plugins.
                                  So I still have a problem to understand
                                  • why we could create a directory from Ruby under ~/Library/Application Support
                                  • and why it fails when you create it in ~/Library/Application Support/SketchUP 2013/Sketchup/Plugins (i.e. the failure reported on DEFPARAM_Dir creation)
                                    driven
                                    The problem is when Sketchup.find_support_file('Plugins') returns the non-user Library
                                    the only way to be sure you have a User writable Plugins Folder is
                                    userPlugins = (File.dirname(File.expand_path(Sketchup.find_support_file("OldColors")))) <<  ("/Plugins")
                                    Dir.mkdir(userPlugins ) unless File.exist?(userPlugins )
                                    This empty Folder OldColors is in every version since v5 at least, it's not dynamically created like Shortcuts.plist nor movable like AutoSave
                                    SU on mac has always been able to have 2 'Plugins' paths, it was mix and match that messed things up...
                                      @fredo6 said:
                                      On my Windows 7,
                                      Because your username "Fred" is compatible with the 8.3 annotation. If however the username is "tæst" the the returned value would be:
                                      ENV["TMP"] --> C:\Users\TST~1\AppData\Local\Temp ENV["LOCALAPPDATA"] --> C:\Users\T'st\AppData\Local
                                      As demonstrated by this example: http://sketchucation.com/forums/viewtopic.php?f=180&t=52730&start=60#p482159
                                      So ENV["LOCALAPPDATA"] is not safe and will fail.
                                      That's because ENV["TMP"] returns the path in the short 8.3 format.
                                      I've managed to make Win32 API system calls to get the appdata folder in this format. But I don't see any other way to get this path. For me it's not a big deal because I already ship D. Berger's Win32::API class wrapped under the TT:: namespace in TT_Lib2. But it's not an ideal solution for everyone as it requires bundling a third party library.
                                      • fredo6F
                                        Thomthom,
                                        Thanks really for all your efforts.
                                        On Win7, LOCALAPPDATA seems to be simply the parent of the Temp folder.
                                        So maybe the solution is to use for local data File.dirname ENV["TMP"], which hopefully will preserve the 8.3 notation.
                                        It may even work on Windows XP
                                        [EDIT]from Internet googling, it seems that the temp directory on Xp is %SystemDrive%\Documents and Settings{username}\Local Settings\Temp.
                                        On Windows Vista, 7, 8, the directory is %SystemDrive%\Users{username}\AppData\Local\Temp
                                        So the method File.dirname ENV["TEMP"] would work on both Widnows systems, provided this call File.dirname preserves the Dos8.3 notation.
                                          Under XP:
                                          ` ENV['LOCALAPPDATA']
                                          nil
                                          ENV['APPDATA']
                                          C:\Documents and Settings\XPMUser\Application Data`
                                          However - APPDATA != Local AppData - so it's not the correct fallback to make.
                                          ENV variable:
                                          ENV.to_hash { "PROCESSOR_ARCHITECTURE"=>"x86", "HOMEDRIVE"=>"C:", "APPDATA"=>"C:\\Documents and Settings\\XPMUser\\Application Data", "USERPROFILE"=>"C:\\Documents and Settings\\XPMUser", "TMP"=>"C:\\DOCUME~1\\XPMUser\\LOCALS~1\\Temp", "SESSIONNAME"=>"Console", "ProgramFiles"=>"C:\\Program Files", "PROCESSOR_REVISION"=>"1707", "PROCESSOR_LEVEL"=>"6", "CommonProgramFiles"=>"C:\\Program Files\\Common Files", "USERNAME"=>"XPMUser", "PROCESSOR_IDENTIFIER"=>"x86 Family 6 Model 23 Stepping 7, GenuineIntel", "OS"=>"Windows_NT", "FP_NO_HOST_CHECK"=>"NO", "CLIENTNAME"=>"Console", "windir"=>"C:\\WINDOWS", "SystemRoot"=>"C:\\WINDOWS", "PATHEXT"=>".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH", "ALLUSERSPROFILE"=>"C:\\Documents and Settings\\All Users", "USERDOMAIN"=>"VIRTUALXP-IE8", "NUMBER_OF_PROCESSORS"=>"1", "HOMEPATH"=>"\\Documents and Settings\\XPMUser", "TEMP"=>"C:\\DOCUME~1\\XPMUser\\LOCALS~1\\Temp", "SystemDrive"=>"C:", "Path"=>"C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\Program Files\\TortoiseHg\\", "LOGONSERVER"=>"\\\\VIRTUALXP-IE8", "ComSpec"=>"C:\\WINDOWS\\system32\\cmd.exe", "COMPUTERNAME"=>"VIRTUALXP-IE8" }
                                          When I make Win32 calls to get the path from the system I get:
                                          TT::Win32.get_folder_path_ansi( TT::Win32::CSIDL_LOCAL_APPDATA ) C:\Documents and Settings\XPMUser\Local Settings\Application Data
                                          That is the full path. But not that this is an English XP version and the user is "XPMUser" which all contains ASCII characters. When the OS language changes or username changes to contain non-ASCII characters it will fail.
                                          The 8.3 version of the path - that seem to work better for Ruby 1.8 is:
                                          TT::Win32.get_short_folder_path_ansi( TT::Win32::CSIDL_LOCAL_APPDATA ) C:\DOCUME~1\XPMUser\LOCALS~1\APPLIC~1
                                          But one cannot hard code these either.
                                          And the different folder structure also means one cannot go from TEMP path to the local appdata path.
                                          • fredo6F
                                            Forget LOCALAPPDATA and APPDATA.
                                            What I say is that, if ENV["TEMP"] return a DOS8.3 notation, and if File.dirname keeps this Dos8.3 notation, then the root to store the data can be File.dirname(ENV["TEMP"].
                                            It happens that:
                                            • On Win7, Vista, Win8, the path calculated with this method will be equivalent to ENV["LOCALAPPDATA"]
                                            • on WinXP, I am pretty sure that the DOS8.3 notation C:\\DOCUME~1\\XPMUser\\LOCALS~1 is equivalent to the long notation C:\Documents and Settings\XPMUser\Application Data, which is precisely ENV["APPDATA"]
                                            • 5 / 6
