    1.5k Posts 471 Posters 3.4m Views 470 Watching
      @ericchan74 said:
      I am on mac os X (10.8.4)
      EDIT - I have found a way to fix this. Change the .zip file downloaded from here and change the parameter to .rbz and then copy/place the file to sketchup plugin folder. Open sketchup and from Preference / Extensions / Install extension - locate .rbz file from plugin folder and woala!! RoundCorner tick box should appear which means installed! From there, go to View/ tool palettes/ RoundCorner to open up tool bar.
      Not sure if this is the proper way to install but worked for me on MAC.
      You could have skipped the part about placing the rbz file into the Plugins folder and used Install Extension just the same. Better would be to install the Sketcucation PluginStore and install it automatically. Did you make sure to also get the most recent LibFredo6 files?
        dorindranca
        hello
        please help
        round corner not working
        I installed libfredo6-49 but asked me to create a folder but still working out DEFPARAM_DIR
        thanks
        sorry my English
          Please read the first three lines of the first post of this thread. It tells you exactly why you are getting this error. You need to set full permissions for the Plugins folder.
            antoineb89
            Hey there sketchupers,
            I am trying to use the roundcorners plugin, but it doesnt seem to work. I can see the icons and everything but when i click on it nothing happens. Hopefully one of u have a solution for this!
            Thanks in advance!
              If you open the Ruby Console, do you get any errors?
                dannykil
                Many on work computers do not have the user permissions to modify the Plugins folder to "full permissions", and company policy will not allow the IT Administrator to grant this level of permissions.
                On my work computer / network, just copy / pasting into the plugins folder requires that I type in a once per occurence User Account Control username and password (but this works for installing many plugins).
                Same for any rbz plugin installation from within Sketchup.
                Round Corner appears not to work unless you truly have the User Permissions modify the permississions of the plugin folder.
                I don't and can't get this permissions level, and so Round Corner doesn't work for me.
                Many other plugins install and work just fine without this permissions requirement.
                  That's not the fault of the plugin. The plugin requires user inputs that must be written to a file for the script to use when it does its thing. The reason the plugin won't work is that it needs to write that file into a folder within the Plugins folder which is closed to it.
                    Fredo is looking into alternative places to write these preference files. Windows makes it hard to write to the Program Files folder because it wants only application installers to write there.
                      am2222
                      Today I tried your plugin ..It is great but I face problems with it.When I use your plugin it works fine and make round corners but after when I click on another tool (no matters which tool..Some times after deselected object) SU crashes and show bug screen..I cant see what is written in rubby console ..I really need your plugin please help me about that
                      I am on win 7 and SU 2013.Is there any Chance to have confilict with other plugins?
                        Yes, there are some plugins that have been known to cause SketchUp to crash. Do you have the V-ray plugin? That is a common culprit. Also some of the BIM plugins create problems.
                          am2222
                          Yes I have vray 1.6 installed..Is there any way to findout which plugin makes problem?
                            Well, considering that the Vray plugin has been notorious for causing SketchUp to crash, I'd start with it. Disable it by either changing its extension (maybe to .rb!) or removing it altogether from the Plugins folder. Then try running SketchUp and especially RoundCorner. If SketchUp doesn't crash, you've found the cause.
                              VfS is known to cause problems. And VfS 1.6 is in active beta - so one can expect bugs to be present. Disable it while you model and enable it when you need to render.
                                am2222
                                Thanks a lot for your helps.I disabled it and works great
                                  I use my V-Ray Tools plugin to load it on deman when I need it for that session.
                                    am2222
                                    Thanks for your sugestion..I will test your plugin..
                                    Why this forum doesnt have any thanks button? 😐
                                    • caculoC Offline
                                      caculo
                                      Finally I did it!!!! It's working on my Sketchup 2013. You must grant full access to ALL user but also to "ALL APPLICATION PACKAGES".
                                      http://t.imgbox.com/adbHazv0.jpg
                                        Perhaps if you have "ALL APPLICATION PACKAGES" as a user. I don't have that on any of the three machines I use for SketchUp.
                                          Me neither.
                                            Or maybe it's a Windows 8 thing...?
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 74 / 74
