    [Plugin] 3D Text Editor
    204 Posts 51 Posters 237.9k Views 50 Watching
      rv1974
      After some manual deleting\reinstalling I set the things right. No worries.
      P.S. Here are some points that could make this tool more efficient:
      1. make it non-modal (like windowizer 4 or profile builder), it'd speed up the editing of large number of components drastically.
      2. height and extrude values come true only after some editing.
      3. in complex models (with lot of nesting) the tool's snapping does not work correctly.
        Had no problems with native 3d text.
      4. After running TIG's 'uniquify' script some 3d text component look unchanged, but
        when one would try to edit the text it get mirrored (see attached). Donno where your this bug come from.
      KKKK.zip
        But, it's not modal... and whether it would be modal or not - how would that improve performance?
        @rv1974 said:
        1. height and extrude values come true only after some editing.
        This is fixed in the version that is plaiting moderation in EW.
        @rv1974 said:
        1. in complex models (with lot of nesting) the tool's snapping does not work correctly.
        Can you explain further to what isn't working correctly? What am I looking for to reproduce this?
        @rv1974 said:
        1. After running TIG's 'uniquify' script some 3d text component look unchanged, but
        I don't know what his uniquify script does... but if it doesn't preserve the transformation and orientation of the original component then it'll mess things up. When third party tools modify the text group it's hard to predict what will happen.
          JuanV.Soler
          Hi thomthom
          I think this is a great plugin that you could keep improving . There is trouble when changing heights that I workaround by clicking and unclicking the extrude buttom . My question is can it be possible to update a bunch of texts to a chosen one ? Sort of Matching Properties ?
          thankyou
            This bug has been fixed - but only released on Extension Warehouse. I've not gotten around to update my plugins to SCF's new PluginStore. For the time being - check EW for latest versions of my scripts.
            It's technically possible. But I cannot promise when/if. It's very busy at the moment.
              JuanV.Soler
              hi thomthom,
              there is something wrong when downloading TT_Lib² from Extension Warehouse , it does install but then in SketchUp it shows
                Perhaps you've got some files in Virtual Store? If you go to your Plugins folder - is there in Explorer a button that says "Compatibility Files"? (or similar in whatever language you might use)
                  JuanV.Soler
                  no , I haven´t . Nevermind , I managed to get it work again . Thanks
                    How? What fixed it?
                      JuanV.Soler
                      I avoided the message of the need to install the 2.8.3 version and just closed that window .
                      But where is that version ?
                      I tend to think that it is not in the Extension Warehouse for the moment .
                      The one to download must be a previous one or something .
                      Thus the message of updating and thus that the Editable 3D Text still works the same for me .
                      thanks
                        The version is there - and it has some important fixes for 3d text editor.
                        You might have to remove TT_Lib2 before reinstalling. There could be some files that are in use when SU tries to update.
                          JuanV.Soler
                          thomthom I have done it several times to no avail .
                          It remains a mystery to me .
                            Just to be sure - if you try this utility: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
                            And use "Check Virtual Store" - what happens then?
                            Also, what is the output of TT::Lib::VERSION if you type it into the Ruby Console?
                              But you still get the warning? Did you use the VirtualStore check utility?
                                JuanV.Soler
                                now that´s funny , it says :
                                so I do have installed the latest version after all
                                I have the virtualstore plugin installed in the folder but it does not show in Plugins SketchUp aplication so I cannot run it
                                  JuanV.Soler
                                  no more warnings no . I think that the trick was to ignore the first warning after installed
                                  As I edited my latest post : I have the virtualstore plugin installed in the folder but it does not show in Plugins SketchUp aplication so I cannot run it
                                    ? Really? No menu under the Plugins menu?
                                      JuanV.Soler
                                      no , no menu under the Plugins menu
                                        what happens if you type this into the ruby console: TT::Plugins::VirtualStore.check_virtualstore
                                          JuanV.Soler
                                          The **Text Editor**still works with the same workaround of unticking the extrude function to get the heights modified
                                            What does TT::Plugins::Editor3dText::PLUGIN_VERSION report.
                                            And what version of Internet Explorer do you have installed?
                                            (Lots of questions here - but I'm baffled by what is going on here. It should be working... :s )
                                            • 11
                                            • 4 / 11
