    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 137.8k Views 37 Watching
      Oh wait... I might have confused myself.
      ugh... it's been so long since I worked on this project... 😞
      I think you might be right... 😳
      • brookefoxB
        brookefox
        So I thought did not need the rounding and set it to 360 so as to avoid (further, excessive) rounding, you are saying to set it lower, say 359, because the routine does not like 360?
        ~ Brooke
          slugnic
          is this project completely dead? or did Modelur take its place?? cheers
            It is ... very very dormant ... πŸ˜‰
              jermboy27
              Can you please add road signs in the UK in this plug-in?
                That's a bit vague request. Add road sign - how, and by what rules?
                Or are you looking for a library of components?
                  jermboy27
                  By the Sketch-up road sign plug-in rules in any country you choose.
                    This is still too vague. What rules are these?
                    In any case - creating the signs for all the signs in the world - even just one is a bit of a task. But if you wan't to suggest it as a plugin you really need to be more spesific to what it would be used for and how it is supposed to work.
                    • guanjinG
                      guanjin
                      Good tool to do the planning useful, there is a problem, you can not change the road style
                        shodi21
                        you could just type in 1234 main street like anyone else...
                          Ash.
                          I do realise this is kind of dead but did it stop working with SU 2015 because I installed it correctly the city generator is displayed in tools but the street generator isn't showing. So I can't do anything.
                            I don't think SU2015 should cause this extension to break. What was the last SketchUp version you used? If you used it on SU2014 I would have expected it to work on SU2015.
                              Ash.
                              Well I must confess this is the first time I'm using this plugin. The city generator shows up in my installed extensions but the street generator does not. Also what's the difference between the extension manager and the plugin manager in The SketchUcation plugin, because in extensions TT_libΒ² is disabled and in Plugins it's enabled. And I can't seem to activate it in extensions. See screenshot, also for the city generator, this is as far as I can get. Don't get a submenu.
                              http://imgur.com/JXp0Zlw
                                The image doesn't seem to load for me.
                                  Ash.
                                  That's weird it's an imgur image. Seems to load fine here: http://i.imgur.com/JXp0Zlw.jpg?1
                                    How did you install Street Generator? To what location?
                                      Ash.
                                      C:\Users<username>\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins I extracted citygen folder and citygen ruby here and the streetgen folder and ruby in the citygen folder. As it should?
                                        That does sound right... hm...
                                        and no errors upon startup?
                                          Ash.
                                          Nothing, I tried on a different computer that has more or less the same plugins but SketchUp 2014 and with same result no submenu showing.
                                            Hmm... I'd have to dig deeper.
                                            (I'm sorry to be slow to respond, but I'm living out of a hotel until the end of Feb. Business trip. Really poor WiFi quality... grumble)
                                            • 6 / 7
