    How can anyone possibly use layout
    layout
    79 Posts 15 Posters 14.6k Views 15 Watching
    • KrisidiousK Offline
      Krisidious
      That's a nice set Francois but those 3D raster images are pretty nasty... hard to believe they don't have a vector export for that software.
      I'm still not seeing anything you can't do in SU/LO. they have recently added hidden background edges to Layout, however they don't stick around in vector or vector/raster hybrid.
      The biggest limits I find in layout is the connection to BIM type info that others have like Autocad and such. Like others have said here, I've moved further and further away from over detailing. My sections are actually quite simplistic, I don't do dimensions on them or even callouts very often. And no one ever questions it... I've found that professionals in the respective fields usually know what they're doing and what's going on.
      By: Kristoff Rand
        sonder
        I agree with Kristoff. If anything, some of those complex details would be more clear in 3d. I've found this to be especially be true for flashing details.
        I do understand the dilemma though, of trying to convert all your 2d work to 3d. That was still probably the biggest hurdle for me. That's all in the past now though and I have no intentions of returning to 2d detailing.
        • RichardR Offline
          Richard
          I think the first point of not seeing anything that can't be done in LO is countered by the second!
          BUILTBRAND.COM.AU
          • pbacotP Offline
            Just because you could do it doesn't make it practical.
            As for the BIM. Eh. Wouldn't effect my work enough any time soon to make it decisive. I can wait... the parametric effects are attractive though.
              Krisidious
              Was his drawing using BIM info for notes and such? I didn't know if it was or not.
              and no, the capability to do something does not make it practical.
              By: Kristoff Rand
              • pbacotP Offline
                I dunno. You mentioned BIM. I am just adding debate fodder. I'd like to try to use SU-LO more myself.
                • F Offline
                  frv
                  Hi Kristoff,
                  don't know what you mean by raster images and vector software. The 3D's are made in Sketchup. Just added there to give some idea.
                  We sometimes receive 3D dwg files made by the subcontractor for the steel work. We just import them in Sketchup on top of our 3D models in different colors. That's how we check for crashes between construction elements. Basically that is some form of BIM.
                  In Holland the way we work is not really BIM. The way contracts are set makes it basically impossible to do actual BIM. In other words, to have a true information model shared by all parties involved is not possible. Other parties are involved to late in the process to get them all working on the same model. And then there is the question of liability. Nobody wants to share anything unless properly paid for and without any guarantees on the work delivered. That will change over time as well but for the next few decade's I don't see that happen.
                  I understand everything could be done in Layout. But I have never seen anybody do what we need to do in Layout, neither have I been able to get it done myself. I am afraid that Sonder in Holland would have to go back to either draw in 2D or have to buy Revit. I know a few offices who do all in Revit. They are now either bankrupt or admit the work takes over 5 times more effort. Sometimes when a project actually pushes through they get a bit of profit from all the work involved to sweat the details and I mean all the details done in 3D. Imagine the average office here sees only 1 out 10 project built. The rest is all cancelled sooner or later hoping as much of the work will be paid for.
                  Its not a question if 3D will be the future. I have no doubt that within 5 to 10 years 2D drafting is done for. Student will even not know how to do 2D. But I am not convinced with what I see here however well done, that what we need to do can be done with Layout. Vectorworks also has a workflow in 3D with all sorts of BIM functionality. It works all right if you spend enough time.
                  I was at a lecture on BIM were a middle sized Dutch office showed their work done for BIM projects all in 3D and rather detailed in Vectorworks. Half of what I saw I could have done easily in Sketchup and maybe Layout. Last I heard of them a month ago was that they too have gone bankrupt, 14 people now unemployed. A client we worked for, one of the biggest firms here (160 architects) was very much into Revit. Last year they went bankrupt. The list goes on and the latest market research showed almost 70% of architects (since 2008) in Holland are now unemployed.
                  This is how it is these days here. Its stalls progress a little I would say. One or two projects that somehow does not work out so well means the end of it, not for us but likely for all offices here in the Netherlands.
                  Apart from OMA (Koolhaas) of course. I think they do their design work with hand sketches and have the technical work done externally. Also a development I see happening. The total separation between design and engineering. Webdesign is already like that. Top designers work in Photoshop or Indesign while a small team of IT specialists program the html code. Compare that to architects working in Rhino, Z-brush, Modo and so on while a team of engineers are doing the Revit models after the design work has been done.
                  Francois
                    Krisidious
                    As far as the Raster I was speaking of specifically and only page 12. I thought it was so pixilated because you had mentioned earlier that rhino or visualarq didn't have 3D vector lines.
                    2D is much faster... I face that a lot in my business. I could be drawing my houses quicker in 2D and saving time and money. However, I really enjoy doing the 3D and frankly I'm not willing to give up that work/enjoyment level. I really hate drafting... Ok, maybe I don't hate it, but I don't love it.
                    Some might think I'm selling or defending SU/Layout, actually what I'm doing is defending my choice of software as being the most efficient and cost effective method of accomplishing my goal. To admit that some other program does it better would mean I had wasted a lot of time... Deep inside I want to know if there is something better, but I'm afraid to find out there is.
                    By: Kristoff Rand
                    • arail1A Offline
                      arail1
                      I think that comment may have come from me and therefore I should clarify a bit: Rhino is a very complex program and has a number of different output functions (wireframe, shaded, rendered, technical, pen, etc.) most of which you can customize - rather like Styles in SketchUp. Some of the output variations are vector based. The point that I was making is that there is not an easy way to output vector perspective with dimensions. If you do a 4 viewport layout (top, side, detail, perspective) you'll see the dimensions in the orthographic views but not in the perspective view. There are workarounds for this but they are just that - workarounds, which I translate as: "obstacles to a clean, fast workflow."
                      Furthermore, Rhino lacks the hybrid mode of vector / raster that Layout has (which is the one function that frequently brings me back to LO). Rhino, like many of the big 3D modeling applications, is putting a lot of effort into a built in rendering engine that works inside of the main application. But going forward, I find myself having less and less interest in photo realistic work. The various graphical styles that are present in this thread are, to my eye, more interesting and more useful to the complex process of transitioning from design to fabrication than any attempt to mimic photography could be. Fortunately, Rhino is also investing a lot of energy in expanding the NPR possibilities in the program.
                      • F Offline
                        frv
                        To Kristoff,
                        after 25 years working with CAD I know that any choice is the wrong choice. It all changes all the time. Ten years from now nobody works with Revit or Sketchup anymore. Most of us will not even be able to open the files we have made up till now. I know architects, retired who can no longer open their files of ten years back.
                        But, about waisting time, people who drove a T-ford never waisted any time, they went from A to B just as we do.
                        To Arail1,
                        photorealistic renders from Sketchup work is used here daily to help with design decisions. Its just great to see what a design actually looks like. We have come to the point that there is basically no difference anymore between the rendering and the built result. Our customers love it (the few ones we still have .. 😉
                        I added a small render we made of the project I showed the 2D work at first. I loved the way I could discuss the color of the front door. We used Accoya with a certain type of wood stain. This house is being built now. The bricks I photographed from a house in Belgium and texture mapped them in Sketchup for render. We order the same bricks for this project. Then I used a specific textured coating on the steel beam I saw used in a new museum in Antwerpen. I also changed the steel beam from UNP to UPE with a more straight appearance. All this I could test and see photorealisticly almost in real time in Sketchup. I must say that photorealistic rendering is a lot of fun while working on details and design especially because clients get more involved in this part of the work. They sometimes even spend a little more for more quality because they can actually see why and how.
                        Reading the response on my original question it came to my mind that what we are really doing is using a 3D model to make 2D images either in perspective view or cross sections, elevations and so on. Its actually rather backwards.
                        Imagine a contractor being send your detailed Sketchup model. On his iPad he can with a fingertip click on a beam and the location pops up, the number of components and how the beam should be coated along with the dimensions. Imagine he now touches the button for a render to see what the coating would look like. Imagine a reference to a manufacturers website showing prices and alternative profiles. He would just be browsing your model checking the specs and dimensions. He could with a swipe of his fingers cross section the model or use Google Street view to look at elevations.
                        Imagine this can already be done if Trimble instead of going back in time would move fore ward. Forget Revit, Layout, Vectorworks and whatever silly app. They all set you back with enormous amounts of extra work that is hardly paid for. We need an application that can read Sketchup models properly and in a way that a contractor can get his information directly out of the model.
                        I hope my fantasy will come true otherwise we will all be forced to work as idiots communicating with silly static images totally waisting all the energy that went into the original 3D model.
                        I think the whole BIM thing is a marketing hoax. We still think people want 2D drawings automatically generated by a 3D model just because the model can not be read by the people on the building site.
                        A while back I needed to send an engineer a dwg file so he could get the dimension of the site. I send him the file after he replied. Where are the dimensions, you forgot to put them in. I told him he can just measure in the open file any dimension he needs.....
                        Francois
                        ps, sorry for the long text.
                        front elevation - front door
                        • arail1A Offline
                          arail1
                          frv -
                          Maybe it's because I was a builder before I moved to architectural / product visualization that I find the photo real to be the least engaging of the tasks I'm responsible for.
                          The attached image is a rendered SketchUp model for a series of large industrial fans (well over 10' tall - think Steam Punk without the fancy dials and knobs) that were the backdrop for a clothing display.
                          The client loved it, I got paid, but I dreaded having to do more of them. There's something so mechanical, almost deadening about the process of imitating a photograph. It's rather like being an artist and knowing before you start what a painting is going to look like when it's finished.
                          Now, the technical drawings, the CNC files, the whole graphical structure that converts these images into something that the shop can build - that I don't find deadening.
                            kwistenbiebel
                            @frv,
                            Aside of the topic: I like the project's render and the explanation that goes with it.
                            Also makes me want to see the detail solution to insulate the UPN 😄. 'Koudebrug'?
                            In Belgium I used to work with Vectorworks and Sketchup too.
                            The reason is I could keep focus on the design that way cause both pieces of software are just easy.
                            Now that I worked for 5 years in Australia, I witness how much energy here goes into 'pulling things of' in Revit.
                            The focus on design is almost lost as everybody seems to waste all their energy in getting the bloody software to work properly for them....and it hardly ever does.
                            Revit really puts a downer on the the architect's profession ...unless you have the personality that likes the software more than making good design.
                            And yes, Layout is not ready for production (yet).
                            The lag in updating , not enough 2D tools etc....
                            • F Offline
                              frv
                              Arial1,
                              A 3D model properly textured can be shown photorealisticly rather simple in Sketchup & the many rendertool available. We use Maxwell and the renders are constantly used to alter design decisions. But I love photography and could not imagine designing anything without looking at it before its built as realisticly as possible. You don't need to be an artist or make artistic attempts to just want to see how things look.
                              Hi Kwistenbiebel,
                              I have some friends, architects who use Revit as well. They hate it, they battle through projects just to get some basic stuff done. Revit is far from finished and the only reason people use it is because it seems to be in demand by clients. I think if it was cheap nobody used it. Once you invest in it your lost.
                              The offices here that are somehow productive with it only do engineering with Revit. Architectural engineering.
                              Designers don't work with Revit at architectural offices. They use pen and paper or dedicated CAD apps like Modo, Sketchup, Form Z, Rhino etc. So, in our profession its now about a choice. Are you going to do design or architectural engineering. We are designers doing a lot of engineering. Our tools are much more flexible than Revit will ever be.
                              On the UPE beam. The wall is 450 mm thick. The outerwall 115 mm brick, then 35 mm air, 150 mm insulation and the innerwall 150 mm baring brick. So the UPE is on the outside of the thermal barrier. This is a standard Dutch detail.
                                sonder
                                All I can say is wow. Thank god I don't live in Holland. Extremely backwards place if folks are stuck in the world of 2d! Based on everything said here, I can't even begin to comprehend why your contractors are incapable of understanding drawings that represent reality and prefer the abstract nature of 2d drawings. Hopefully that will change in your future and they grow to understand the value of 3d as they have in my area.
                                  kwistenbiebel
                                  Hi frv,
                                  Thank you for the little technical detail explanation.
                                  Yes, with a thick wall build up as you explain, it seems easy to keep the beam in front of the insulation in the wall cavity, avoiding a thermal break. Wall cavity measurements have increased since I worked in Europe 😄. Good evolution.
                                  Australia has very poor thermal insulation standards, especially here in West Australia it's a joke.
                                  I totally resonate with the distinction you make between software for arch engineering and design.
                                  Revit works (kind of) for architectural engineering, while software for architectural design is more of an undefined open market.
                                  Also, Revit has serious implications for staff that is being hired.
                                  I regularly see architectural graduates being hired for their Revit skills, not for their architectural design skills.
                                  That's just wrong.
                                  In the 'olden' days (mmmm showing my age now 😄), it didn't matter as much if you know Autocad or not... the amount of training needed was 'manageable' and not a culprit when hiring people.
                                  Revit is a different ball game. Even people using Revit for more than 5 years encounter moments when they struggle to figure out ways to do things....
                                  I kind of hope Revit will soon be cut out of architectural practices.
                                  It is indeed a money making hoax to some extents.
                                    congellous
                                    I have been a sketch-up evangelist for many years. I found this thread because I was about to ditch layout all together and go back to hand drawings or anything, morse code ! .... after trying simple room annotation and it's 25mb and I've got 4 floors left to add !!! I know all the tricks used it for years blah blah, however, as much as it's better than the last version, I have upgraded from a 2008 macbook intel duo to a Macbook pro super duper cat and it's only just about quicker in the basic operations albeit quicker in refreshing a skp model etc. Somewhere along the line the basic code of Skp and layout is going to need a revamp, like the man said - it's not a modern CAD experience.
                                    Some of the comments are so partisan, we need to complain about it's shortfalls, I've invested a lot of time and money and on the whole it's been amazing using sketch-up but it's usability in a "pro" situation is being put to the test more and more and any investment needs to go into the central usage rather than funky tools.
                                      congellous
                                      I just ran a test on the same file one in 2013 pro and layout against Skp 8 pro and layout and its much faster on the old system ! Add to this that the 2013 machine is 6 years newer, double ram, 4 times faster on geek bench tests. It runs much slower in general outside of the auto render....
                                        sonder
                                        I wish I could help you out. The key is finding the right method that works. When you do, it is remarkable how fast a complete set of 3d construction documents can be prepared. I'm on my ninth custom home this year with very detailed drawing sets - typically 50-60 sheets. 6 of those designs are already well under way in construction. All of them are fairly complex as well.
                                        One of these days, I am hopeful to really document my approach in more detail, not just to help out those struggling, but to hopefully find someone that expands it much further.
                                        If it helps any, I spend 90% of my time in Sketchup, and only 10% in layout. It's all in the prep time, so that you utilize Layout only for what it is intended......presentation.
                                        • 4 / 4
