    Measures dissapear in Hybrid mode in SU PRO 2013 !!?
    layout
    15 Posts 3 Posters 1.4k Views 3 Watching
    • ipsketchpiI
      ipsketchpi
      @juanv.soler said:
      open them again in 2.013 and save them in save as by clicking the Layout files drop menu in Layout 3 (version 😎
      Thanks.. good idea.. will help for a moment.
      /IP
        Maybe it's too late but why not just put the dimensions in in LO?
        • ipsketchpiI
          ipsketchpi
          I work these way and it looks like SU2013PRO has a problem here in Hybrid mode. I noticed that dimensions dissapier in oll vievs except front view... where hybrid works well.
          In SU8PRO there are no such problems.... will it be fixed? (question to SU team)
          /IP
          • ipsketchpiI
            ipsketchpi
            How to use my SU 2013 PRO Maintenance & support number and where to get fast help?
            /IP
              You probably ought to go to sketchup.com and make contact there.
              • ipsketchpiI
                ipsketchpi
                I think its some programm failure...? these problem is on all side views in Hibrid mode...strange... I tried to contact them but no feedback...? I just get some feedback request on my mail for maintenece support quality which I have not received..? strange... maybe they do not send answers back to e-mail and maybe I should look for answers on some specifix web page..?
                /IP
                  There is an eight hour time difference between you and them. They do have to sleep sometimes. πŸ˜’
                  • ipsketchpiI
                    ipsketchpi
                    ok πŸ˜‰
                    /IP
                      You didn't answer why you won't place the dimensions in LO. You can make much better looking dimensions if you use LayOut's dimension tool.
                      • ipsketchpiI
                        ipsketchpi
                        1. I cant snap on layout precisely (our I do not know how). Especially for small details.
                        2. I do not know how to put on new patterns. BAsically I need to redraw all contours to use patterns from layout.
                        If I could ... I would be happy to do these in Layout.
                        /IP
                          As for precisely snapping dimensions, there's no trick. Make sure you have Object Snap enabled (Under the Arrange menu)
                          I don't know what you mean by putting on new patterns. Could you explain it?
                          • ipsketchpiI
                            ipsketchpi
                            What I know is that to use these pattarns I must draw in layout. And then its very timefull. I must open plann in layout and then draw on top of it new plan ant then I can use patterns.... is that right???? maybe I do not know ..?
                            Then Snap. If I want to snap nice somewhere its a huge risk I will snap in wrong place. On big plann risk is mall, but on small furniture details ets... its big. When I place dimensions in SU, I can zoom wery close snap dimention then return back save csene with dimentions ( i usually make several scenes- one side view, one top..etc) Then I open these scenes and make Hybrid render.
                            I make all section cuts also in SU too. Maybe I can send you some SU file... you will see how I do these and maybe will help to fin better ways. But I work these way already 3 years... final result is nice.. but I wouuld like to do it right way of course
                            /IP
                              I still don't understand what patterns you are talking about. Do you mean patterns for templates to cut out pieces of wood? You don't have to draw them in LayOut. Just use SketchUp for that. Create a scene for the pattern in SketchUp and make a viewport at the proper scale in LO.
                              As to dimensions, you write about a risk as if someone's life is hanging on it. There is no problem dimensioning small things accurately and precisely. I create plans for furniture and other woodworking projects all the time using LayOut. I don't have any problem using the Dimensioning tool in LO for this.
                              Post the LO file or send it in a PM if you wish. I can get to the Sketchup file from there.
