    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • erikBE Offline
      erikB
      thanks for the update, great plugin I use it regularly.
      erikB
        tak2hata
        Thanks Hebeijianke and Oxer for uploading the translation files.
        Now I'm busy ,so I will update plugin including these translation files in the end of this week.
        Thank you very much!
        by TAK2HATA
          tak2hata
          Hi,All.
          I update to v2.0.5.
          Include new language file for Spanish and Chinese.
          Thanks Oxer and Hebeijianke!
          Enjoy!
          by TAK2HATA
            meoa
            Preview shows fur on the selected face but after clicking make fur, quite a number of it go off the selected face. The ones on the face are also scattered unevenly unlike the preview.
            Is this what should happen or am i doing something wrong ?
            Ok, sketchup just crashed. I tried it again and it seems to be fine now. Fur stays on the faces. I stil don't know what happened before and the cause.
              tak2hata
              Hi,meoa.
              I need more information for your problem.
              I can not know what happened, too.
              Please upload your model and the picture of the fur setting and selected face.
              Thanks.
              by TAK2HATA
                meoa
                @tak2hata said:
                Hi,meoa.
                Thanks.
                Sorry tak2hata, it was my mistake.
                I deleted geometry in a component and for some reason it did not rescale or i may have moved the axes by mistake so the component size was far larger than the content(space when you edit the component). Thus, the make fur moved the components further away than the size of the content which explains why they were off the face.
                make fur on the rectangle's surface using the component beside it
                  tak2hata
                  @meoa said:
                  @tak2hata said:
                  Hi,meoa.
                  Thanks.
                  Hi,meoa.
                  This problem is solved by yourself.
                  by TAK2HATA
                    menes
                    Hello there,
                    First thanks tak2hata for the wonderful plugin.
                    I'm trying long time now to use this for create a nice Olive tree.
                    While the plugin work perfectly for create the single element.
                    I can not in any way create the proper effect randomizing the element using the "leaf" mode.
                    any suggestion?
                    thanks
                    • srxS Offline
                      srx
                      Wonderful plugin. Here is Serbian translation. Just to feel the excitement of taking part in an international project 😄 .
                      fur_lang_srb.txt
                      www.saurus.rs
                        tak2hata
                        I upload to v2.0.6.
                        Include the language file for Serbian by SRX.Thanks!
                        Hi,menes.
                        I try it!
                        finished
                        component for leavs
                        Component for leaves lay along to X-Axis(RED) with litte slope.
                        And place it with large Z value of "direction" and "force" in fur dialog.
                        It make like this placement.
                        Thanks.
                        by TAK2HATA
                        • N Offline
                          nektares
                          i loved this plugin already, and now it´s even better! Arigato Gozaimasu Tak2Hata
                            menes
                            Thank you very much indeed! TAK2HATA
                            Will try and let you know
                              menes
                              Thanks TAK2HATA
                              You put me in the right way 😍 thank you!
                              My values were different
                              Main Detail
                              type : leaf top jitter :8
                              Density: 60.000 width jitter: 19
                              Max n. :60.000 stiffness jitter : 50
                              length :1 valid distance: 0,000
                              rootwidth : 0,200 direction (x): 0,000
                              stiffness : 1 direction (y): 0,000
                              divide :2 direction (z): 1
                              force (x):0
                              force (y):0,000
                              force (z):-30
                              now the only thing to try ,it's to avoid many leaves at the bottom of the branches and have more on the top.
                              • thkian92T Offline
                                thkian92
                                Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
                                  mwm5053
                                  Great plugin 👍 I updated to 2.0.6 but not getting sliders or realtime preview like video shows I get the older dialog style. I'm using latest SU8 Pro on Mac 10.7.5
                                  2011 iMac
                                  SU 2015 Pro, 2017 Make
                                  V2 Twilight
                                  macOS Sierra 10.12.5
                                    tak2hata
                                    Hi,Walt.
                                    I will test it on Mac.
                                    Please wait.
                                    Thanks.
                                    by TAK2HATA
                                      mwm5053
                                      2011 iMac
                                      V2 Twilight
                                        tak2hata
                                        Hi,Walt.
                                        I tested on mac.
                                        Screen shots here.
                                        files in plugin folder
                                        work fine on mac.
                                        I think the problem is folder.
                                        The webdialog lost the sight of "JS" folder or "CSS" folder.
                                        But I think no problem about the non-alphabetical character file names on mac.
                                        So please tell me your plugin folder.
                                        Thanks.
                                        by TAK2HATA
                                          mwm5053
                                          Path can be seen at bottom of screen shot.
                                          2011 iMac
                                          V2 Twilight
                                            tak2hata
                                            I think there is no problem.....
                                            The problem becomes the mystery.
                                            I will create test code for you.
                                            Please wait.
                                            by TAK2HATA
                                            • 32
                                            • 33
                                            • 3 / 33
