    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.3k Views 170 Watching
      @arcad-uk said:
      Feels a lot faster 😎
      One problem, it is creating faces for switched off layers. πŸ˜•
      I'll look at addressing that ?
      Didn't it use to ?
        ArCAD-UK
        The previous version would only section what was visible so you could extract just parts of the model. What flagged it up for me was all my demolitions suddenly reappeared.
        My workflow is similar to Sonder's e.g. background and line work except I'm using fills in LO underneath the line work, is it possible for the glue function to work without faces?
        With your new version the defaults can't be edited, any chance of making it so all the Y/N options can be preset by the user as well as selecting <No Face>?
          404 Not Found
          (sketchucation.com)
          This v3.1 update now ignores objects that are hidden/on hidden layers πŸ˜„
          • G
            gbing
            Thank you TIG for all your awesome plugins!
              Here's v3.2
              http://sketchucation.com/forums/viewtopic.php?p=172583#p172583
              Fixed glitch with glued cut-faces not updating in convoluted nested contexts.
              The previous version would sometimes not update a cut if a 'geometry edit' had been done several contexts removed from the section-plane's context - although it dis affect what was cut by the plane itself - but now with v3.2 all glued section-planes will update whenever there's a relevant edit in any other context that might impinge on what a section-plane might cut...
                ArCAD-UK
                Awesome update. Thanks TIG πŸ€“ 😎
                Just a thought but if the section plane was placed on a layer other than Layer0 could SCF pick the layer name up and use it as the default whilst still offering the option to select a new or other layer?
                I'd like to set the edges on can I change the default from No?
                  The Section-Plane's layer will already be available on the drop-down list, with the new unique SCUT- specific layer being the first offered. I think it's best if each SCUT- is on its own SCUT- layer - that way allows you the best flexibility for views/scenes etc... BUT if you change it each time, you just have to manage thins differently...
                  Once you have set some defaults in the dialog they are remembered for that session...
                  However, I think you want to change the initial default settings for 'Hide' TO 'No'... πŸ˜•
                  If you DON'T hide edges the SCUT's edges will bleed through in views without an active section-plane and the SCUT's layer on - not much of an issue UNLESS the SCUT is on a shared layer ?
                  I'll issue an update that'll let you edit most of the dialog's initial default settings in the 'SectionCutFace_loader.rb' file file using a plain-text editor like Notepad...
                    ArCAD-UK
                    My work flow puts the sections with edges on separate scene managed layers, this allows me hide them in elevations and to use the 2D data for quick and accurate dimensioning in LO. Many LO users will be aware of the frustration of not being able to pick up points on a 3D model for dimensioning and tracing.
                    The point of picking up the section plane layer is to speed up the layer selection process when updating a cut and avoid unnecessary/accidental layers being created or having to scroll and hopefully pick the right layer associated with the section plane. It just seems a logical progression with the fantastic "Glue" option you introduced with v3.
                      Here's v3.3
                      The ../Plugins/SectionCutFace/SectionCutFace_loader.rb file now contains editable lists for changing default colors AND the dialog's initial default values.
                      Use Notepad.exe or a similar plain-text editor to set them differently as desired...
                        If you accept the default SCUT-12345 layer for the SCUT, then you'll still have the Section-Plane selected after the SCUT is added; you can simply use the Layer toolbar drop-down OR Entity Info to assign the Section-Plane to its matching SCUT's layer - the the two are then on the same uniquely named layer.
                        To find the layer of an SCUT later on you can select it and then Entity Info or the Layer toolbar drop-down will show it.
                        You can't change the layer of a SCUT that is Locked - BUT if it's not glued then you can un-lock, re-layer and re-lock.
                        You can't successfully change the layer of a SCUT that is Glued - again, it is locked, BUT even if if it were to be un-locked and re-layered - the next time it is updated by a change in the model, then it will reuse its preset layer set in the dialog when it was first created - reverting your changes!
                        So, if you want your Section-Plane and its SCUT to share a layer, then why no reassign the Plane to the SCUT's layer immediately after the SCUT is made?
                        Alternatively set the SCUT's layer to be the Plane's layer using the drop-down list of layers in the dialog...
                          ArCAD-UK
                          Aha β˜€ I've been making wrong assumption about your super glue.
                          Could you clarify the update process of a glued SCUT? Say I've created a SCUT for my model, I then go and change the size of an object within the cut plane what are the steps to getting it to update. I ask because I think I'm missing something simple.
                          πŸ‘ for the default edit.
                          • bmikeB
                            bmike
                            this looks great TIG. i'll have to try it - but i've been using a slightly modified version of your original and hate to part with it. (mainly defaults, etc...)
                            -mike
                              -mike
                              Make sure you keep a copy of the old rb version as the new rb file installed into Plugins will overwrite it...
                              The current version [v3.3] let's you edit the list of default 'colors' in the drop-down, and also set default behaviors - like default-color, and the other options which are defaulted to YES can be set to NO - although remember that options some are mutually exclusive, e.g. a 'Glued' SCUT has to be 'Locked' etc...
                                If the newly made SCUT is set to 'Glue', then whenever its linked Section-Pane is moved/rotated etc the SCUT faces will be reformed to suit the newly sliced objects. You'll need to complete the move etc so its faces are 'refreshed'.
                                Whenever the rest of the model is changed, then any Glued SCUTs - irrespective of their 'context' - are updated so their faces correctly reflect what they now intersect, following the changes to the model...
                                A non-Glued SCUT behaves just like the previous version's section-cuts - the SCUT has no link to the Section-Plane can be moved away from it, edited etc [provided it's unlocked]
                                • JQLJ
                                  JQL
                                  TIG,
                                  Excellent plugin got even better!!!
                                  However tried to edit SectionCutFace_loader.rb but had no success:
                                  • What is the name for I should use for Default color? I copied what you had in the list...
                                  • Why doesn't it change the default for hide edges?
                                  Best regards,
                                  JQL
                                  http://www.casca.pt/varios/sectioncutface.jpg
                                  www.casca.pt
                                  Visit us on facebook!
                                  • bmikeB
                                    bmike
                                    I'm not getting that behavior, I installed directly from the SU Plugin store, let it overwrite my old version. Lock toggle seems broken, and I don't get anything to update.
                                    YouTube (I'm on a Mac, up to date OS, SKPro2013):
                                    -Mike
                                      @JQL
                                      What you show should change the default material to 'nil' "<#{DEFAULT}>" and the @hide to NO ?
                                      It worked for me in testing...
                                      Something has come adrift in the rb>rbs processing πŸ˜•
                                      Wait for v3.4...
                                        ArCAD-UK
                                        If I move the section and create a new glued SCUT the old one is deleted πŸ‘ but as per Bmike's posts the SCUTs aren't updating automatically as suggested by your post even with a simple box.
                                        If there are a large number of sections in a file updating a SCUT after every geometric change may not be good for productivity, it would be better to have a "refresh cut" menu item.
                                          @bmike
                                          If you read the notes Lock = No only works if Glue = No
                                          If you set Glue Yes Lock is always set = Yes whatever you want to do.
                                          I am perplexed how you don't seem to get the cuts updating properly - many others do...
                                          Perhaps it's a MAC issue ?
                                          I'll be issuing a new version shortly, try that and report back...
                                          • bmikeB
                                            bmike
                                            @tig said:
                                            @bmike
                                            Sorry, I misinterpreted the Lock / Unlock, but it makes sense.
                                            I will try again, and when I see an update, I'll test.
                                            Odd, for sure.
                                            • 11
                                            • 12
                                            • 13
                                            • 28
                                            • 29
                                            • 11 / 29
