    Game running half the speed in SU 2013 vs SU 8
    27 Posts 6 Posters 2.1k Views 6 Watching
    • renderizaR Offline
      renderiza
      @anton_s said:
      I didn't meant it seriously, I just meant it the ironic funny way... Like there were topics like "Does Trimble Listen", or πŸ˜† Or what does Trimble actually listen for? 🀣 But, I do love Trimble, I love the way they upgraded SU2013 to newer window Framework. It was actually what I wanted 😍
      Understood! πŸ‘ I do like ironic & funny comments a lot its just that sometimes I am little slow with them. 🀣
      @chris fullmer said:
      @Anton - yup, we're here listening! Trying to respond as best I can. thanks for pinning down the potential bottlenecks. I'll try to run some tests on them today and see if I can verify that I see the same behavior as you.
      Chris Fullmer it means a lot that you are not only listening but also joining the conversation. I am very happy we got you as a Trimbler! πŸ‘
      @driven said:
      yep...
      what else is taken away then???
      Not very happy to find out that some existing features for SU8 free version are being disabled for Make. 😒
      Idea should be to limit Make with new never before seen features so that people will be all over Pro version. That way it will not seam like a cheap marketing trick to bring people over to Pro version.
      There will always be bad apples working for Trimble but I have hopes since we got people like Chris Fullmer trying to do the right thing. πŸ’š
      Cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        dacastror
        How is configured by default "Sketchup 2013"?
        I've noticed that changing this setting has strong effects on plugins that provide some kind of animation.
        In Sketchup 8 an option that works best for me, is as follows
        I do not know how it is in 2013
        (google translate)
        • Chris FullmerC Offline
          Ok here is the snippet I ran from a multi-line webconsole:
          model = Sketchup.active_model
          sel = model.selection
          gc = sel[0]
          t = Geom;;Transformation.new([1.0,0.0,0.0,0.0,0.0,1.0,0.0,0.0,0.0,0.0,1.0,0.0,0.0,1.0,0.0,1.0])
          puts ""
          stime = Time.now
          model.start_operation("no fast", false)
          100000.times do
          gc.transform! t#.inverse
          model.commit_operation
          puts "Transform Slow = " + (Time.now-stime).to_s
          stime = Time.now
          model.start_operation("fast", true)
          100000.times do
          puts "Transform Fast = " + (Time.now-stime).to_s
          stime = Time.now
          model.start_operation("slow inverse", false)
          1000000.times do
          t.inverse
          puts "Invert Transformation = " + (Time.now-stime).to_s
          stime = Time.now
          model.start_operation("slow", false)
          100000.times do
          gc.transform! t.inverse
          puts "Combined Slow = " + (Time.now-stime).to_s
          stime = Time.now
          100000.times do
          puts "Combined Fast = " + (Time.now-stime).to_s
          Here are the results from 3 rounds of tests:
          SU 8
          ` Transform Slow = 7.457
          Transform Fast = 1.429
          Invert Transformation = 0.55
          Combined Slow = 7.442
          Combined Fast = 1.437
          Transform Slow = 7.391
          Transform Fast = 1.446
          Invert Transformation = 0.555
          Combined Slow = 7.458
          Transform Slow = 7.43
          Transform Fast = 1.431
          Invert Transformation = 0.553
          Combined Slow = 7.479
          Combined Fast = 1.456`
          SU 2013
          ` Transform Slow = 0.789
          Transform Fast = 0.42
          Invert Transformation = 0.529
          Combined Slow = 0.841
          Combined Fast = 0.422
          Transform Slow = 0.779
          Transform Fast = 0.419
          Invert Transformation = 0.53
          Combined Fast = 0.419
          Transform Slow = 0.806
          Transform Fast = 0.421
          Invert Transformation = 0.532
          Combined Slow = 0.834
          Combined Fast = 0.42`
          So without the go_faster flag, I'm seeing SU 2013 doing the transformations about 10 times faster than it was in SU 8. Its even going about twice as fast as SU 8 with the go_faster flag.
          Su 2013 appears to be about three times faster than 8 was when using the go_faster flag.
          The transformation.inverse does not seem to have changed from SU 8 to 2013. I'm realizing I deleted the test from these results, but I had tested it with and without the go_faster flag and saw no difference. I could update it to do that again if it would help.
          Does anyone see any holes in these tests? I could easily have overlooked something.
            Anton_S
            Your amazing Chris πŸ‘
            Adding model.start_operation('KeyScene', true) when the user clicks the start button and calling model.commit_operation when user clicks the reset button seems to increase performance dramatically!
            I take all my thoughts back, and do say that Trimble SU2013 is an extreme progression!!!
            Thank you SketchUp Team!
            Thank you Trimble!
            Thank you Chris!
              renderiza
              Here is how it looks on SketchUp 2013 Make
              But! If I change that default setting that option is gone and the only way I can get back to it is if I reinstall again which is little weird.
              Thanks for does tests its really good to know 2013 is faster giving your results. I am still confused as to way in my game the SketchUp 2013 version runs very slow compared to SketchUp 8.
              Sounds like you made KeyScene work much faster...but was it faster than version 8?
              Also I am not sure how can I add model.start_operation in Resballiza game to see if it will make it faster. Can you help me in that regards?
              I am so thankful to all of you great job so far!
                Anton_S
                Yes, it's a little faster on SU2013 than on SU8
                I sent you a PM with a fixed copy of both KeyScene and Resballiza πŸ‘
                  driven
                  @Chris,
                  can you test on mac as well?
                  my results don't look so great.
                  EDIT: reformatted to make it clearer...
                  run on both versions with Sketchup.plugins_disabled? => true then false
                  simple cube, grouped:
                  %(#0000FF)[v2013 mac plugins turned off
                  Transform Slow = 4.051424
                  Transform Fast = 0.689763
                  Invert Transformation = 0.682962
                  Combined Slow = 4.149032
                  Combined Fast = 0.685753
                  nil
                  true
                  v2013 mac plugins turned on
                  Transform Slow = 4.684443
                  Transform Fast = 1.141925
                  Invert Transformation = 0.87607
                  Combined Slow = 4.773361
                  Combined Fast = 1.152288
                  nil
                  false]
                  %(#8000BF)[v8 mac
                  Transform Slow = 2.187031
                  Transform Fast = 0.795604
                  Invert Transformation = 0.809627
                  Combined Slow = 2.293091
                  Combined Fast = 0.784819
                  nil
                  true
                  v8 mac
                  Transform Slow = 2.299228
                  Transform Fast = 0.805798
                  Invert Transformation = 0.985101
                  Combined Slow = 2.456473
                  Combined Fast = 0.818888
                  nil
                  false]
                    renderiza
                    Magnificent! 😍
                    Now Resballiza is way faster than before in SketchUp 2013!
                    SketchUp 8 runs little bit faster still but not by much...I will study ways of optimazing code to make it faster but as is right now it is playable. πŸ’š
                    Again thanks Anton_S and Chris Fullmer for all the help! πŸ‘
                      Awesome, glad its improved! Thanks for working that into his code Anton, great!
                      @John - I have not yet tried it on Mac. I'll see if I get a chance here soon.
                        Anton_S
                        @renderiza said:
                        SketchUp 8 runs little bit faster still but not by much...I will study ways of optimizing code to make it faster but as is right now it is playable.
                        Sounds great, I will be the tester πŸ˜„
                        It was interesting, I never actually knew that setting the second parameter of model.start_operation to true would actually improve the performance. That is an important parameter to know, especially when your dealing with geometry plugins.
                        • 2 / 2
