    Ruby script for selecting color
    62 Posts 4 Posters 4.2k Views 4 Watching
      @nithi09 said:
      It does not work. after first prompt nothing happening
      Without some clues how might I know what you have done ?
      After the first input where the user choses 'type' the while loop is where the inputboxes' results are added to the 'allresults' array.
      If you don't get something from the initial results then how do you expect later steps to happen ?
      • nithi09N Offline
        nithi09
        It's works I did it different way because I need width only here my code thanks for your help
        <span class="syntaxdefault"><br />require </span><span class="syntaxstring">'Sketchup.rb'<br /><br /></span><span class="syntaxdefault">class Testmenu<br /><br />def initialize</span><span class="syntaxkeyword">()<br /><br /></span><span class="syntaxdefault">    ents </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />    group </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group<br />    ents </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />    <br />    prompt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"Enter frontwall height; "</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Front wall custom height; "</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Enter backwall height; "</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"How many units on A wall; "</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    default </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"81\""</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"108\""</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"4"</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    list </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[[</span><span class="syntaxstring">"81\"|91\"|96 3/8\"|Custom height"</span><span class="syntaxkeyword">],</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> inputbox </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">prompt</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> default</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> list</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"A wall of Sunroom"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    <br />    return  if not result<br />    <br />    custom </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    <br />    if custom </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Custom height"<br /></span><span class="syntaxdefault">        <br />        front_height </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />        back_height </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />        num_unit </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">result</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i<br />        <br />    else<br />        front_height </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />        back_height </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />        num_unit </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">result</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_i<br />    end<br />    <br />    <br />    <br />    show_unit_number </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 1<br />    total_projection </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">0<br />    <br />    while num_unit </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> 0<br />    prom </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"A wall unit  #{show_unit_number};"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Door size; "</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Custom Door size;"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Window Size; "</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Custom Window size;"</span><span class="syntaxdefault">    </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    values </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"Door"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    list </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"Door|Window"</span><span class="syntaxkeyword">,[</span><span class="syntaxstring">"87\"|81\"|75\"|69\"|63\"|57\"|Custom Door"</span><span class="syntaxkeyword">],</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,[</span><span class="syntaxstring">"87\"|81\"|75\"|69\"|63\"|57\"|51\"|45\"|39\"|33\"|Custom Window"</span><span class="syntaxkeyword">],</span><span class="syntaxstring">""</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    result_2 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> inputbox </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">prom</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> values</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> list</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"A wall Door & Window"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    return nil if not result_2<br />        if result_2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Door"<br /></span><span class="syntaxdefault">                custom_door </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result_2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">            if custom_door </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Custom Door"<br /></span><span class="syntaxdefault">                door_width </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result_2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />                window_width </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0<br />            else<br />                door_width </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result_2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />                window_width </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0<br />            end<br />        <br />        elsif result_2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Window"<br /></span><span class="syntaxdefault">                custom_window </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result_2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">            if custom_window </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Custom Window"<br /></span><span class="syntaxdefault">                window_width </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result_2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">4</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />                door_width </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0<br />            else<br />                window_width </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> result_2</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />                door_width </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0<br />            end<br />        <br />        end<br />    <br />    num_unit </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> num_unit </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> 1<br />    show_unit_number </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> show_unit_number </span><span class="syntaxkeyword">+</span><span class="syntaxdefault">1<br />    <br />    projection </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> door_width </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> window_width    <br />    total_projection </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> projection </span><span class="syntaxkeyword">+</span><span class="syntaxdefault">total_projection<br />    end<br />    UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox </span><span class="syntaxstring">"Your room projection; #{total_projection}"<br /></span><span class="syntaxdefault">    <br />    if </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">back_height </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> front_height</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> total_projection</span><span class="syntaxkeyword">/</span><span class="syntaxdefault">12<br />        UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox </span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Minimum Roof pitch is 1/12 please increase back wall height"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        return Testmenu</span><span class="syntaxkeyword">.new<br /></span><span class="syntaxdefault">    end    <br /><br />    <br />end<br />end<br /><br />if </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">not $Testmenu_menu_loaded</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  <br />  UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Tools"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"TEST_MENU"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> Testmenu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">new </span><span class="syntaxkeyword">}</span><span class="syntaxdefault"> <br />  <br />  $Testmenu_menu_loaded </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> true<br />end<br /></span>
        • nithi09N Offline
          nithi09
          Hi TIG above code first messagebox if I use
          UI.messagebox "Your room projection: #{total_projection}", MB_OKCANCEL then if user press CANCEL button I need to start over again. I tried like this
          %(#FF0000)[if MB_OKCANCEL == 2
          return Testmenu.new
          end]but didn't work any Idea??
            You need to get a grasp of how references work...
            ` ok = UI.messagebox("Your room projection: #{total_projection}", MB_OKCANCEL)
            if ok == 2 ### pressed Cancel
            Testmenu.new()
            return
            end#if
            pressed OK`
            • nithi09N Offline
              nithi09
              Hi TIG
              How do I change font size and bold on sketchup default messagebox
              thanks
              • Dan RathbunD Offline
                Dan Rathbun
                You cannot. The API does not give this level of control.
                You can make a WebDialog that looks like a messagebox, and use CSS to control fontsize and bold, etc.
                I'm not here much anymore.
                • nithi09N Offline
                  nithi09
                  Ok thanks Dan
                  • nithi09N Offline
                    nithi09
                    Hi TIG if I want to add custom attribute to my door like partnumber how do I do in ruby
                    thanks
                      To set it
                      door.set_attribute('dynamic_attributes', 'partnumber', 1234)
                      To get it
                      door.get_attribute('dynamic_attributes', 'partnumber', nil)
                      If it's 'nil' then it has not been set...
                        Don't you have to make a call to the DC system to make the component update according to the new attribute?
                          Yes.
                          But that wasn't the question... 😉
                          At the end of the process call the redraw thus - the other examples around can fail...
                          dc_redraw(ent, true, false)
                          Where 'ent' is the reference to the 'door' dc...
                          def dc_redraw(ent, pbar_visible=true, undo=false)
                              ldc=$dc_observers.get_latest_class()
                              if undo
                                  ldc.method(;redraw_with_undo).call(ent, pbar_visible)
                              else
                                  ldc.determine_movetool_behaviors(ent)
                                  DCProgressBar;;clear()
                                  ldc.method(;redraw).call(ent, pbar_visible)
                                  ldc.refresh_dialogs()
                              Sketchup.active_model.active_view.refresh
                              rescue TypeError => e
                              # suppress nil to float conversion error that happens
                              # when redraw is called directly with true 2nd arg ?
                          end#def
                          • nithi09N Offline
                            nithi09
                            Hi TIG if I want to create component definition inside the group in this example component name like Triangle and Cube, Then area for Triangle and volume for Cube How do I do
                            thanks
                            @nithi09 said:
                            Hi TIG I didn't understand boundingbox method here is my code look at it. Also I attaching image of this
                            <span class="syntaxdefault"><br />require </span><span class="syntaxstring">'Sketchup.rb'<br /></span><span class="syntaxdefault">class Testbox<br />def initialize</span><span class="syntaxkeyword">()</span><span class="syntaxcomment">#testbox1 <br /></span><span class="syntaxdefault">           <br />        model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />        ent </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities <br />        </span><span class="syntaxcomment">#mats = model.materials<br /></span><span class="syntaxdefault">        </span><span class="syntaxcomment">#glass = mats.add "Glass"<br /></span><span class="syntaxdefault">        <br />        </span><span class="syntaxcomment">#ent = Sketchup.active_model.entites<br /></span><span class="syntaxdefault">        ent </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />        group </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group<br />        ent </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />        <br />        <br />        prompts </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"Width"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Depth"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Height"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Colour"</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">        defaults </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"6'"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"4'"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"5'"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">'Red'</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">        list </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[[</span><span class="syntaxstring">"6'|8'|10'|Custom"</span><span class="syntaxkeyword">],[</span><span class="syntaxstring">"2'|4'|1\""</span><span class="syntaxkeyword">],[</span><span class="syntaxstring">"5'|7'|9'"</span><span class="syntaxkeyword">],[</span><span class="syntaxstring">"Blue|Red|Green|White"</span><span class="syntaxkeyword">]]<br /></span><span class="syntaxdefault">        results </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> inputbox prompts</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> defaults</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> list</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Test_Box"<br /></span><span class="syntaxdefault">        return if not results<br />        <br />        w </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">        if w </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Custom"<br /></span><span class="syntaxdefault">        results_w </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> inputbox </span><span class="syntaxkeyword">([</span><span class="syntaxstring">"Enter Width;"</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"1'"</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Custom Size"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        return nil if not results_w<br />        w </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> results_w</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />        else<br />        w </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> w</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l<br />        end<br />        <br />        wid </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> w<br />        dep </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />        hei </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />        color </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">        <br />        pts </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">wid</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">wid</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]]<br /></span><span class="syntaxdefault">        back_wall </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[[-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,-</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],[-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,-</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">,(</span><span class="syntaxdefault">hei</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">)],[-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,(</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">),(</span><span class="syntaxdefault">hei</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">)],[-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,(</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">),</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]]</span><span class="syntaxdefault"> <br />        angle_ptr </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],[</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,(</span><span class="syntaxdefault">hei</span><span class="syntaxkeyword">/</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)],[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,-(</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">/</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)]]<br /></span><span class="syntaxdefault">        triangle </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face angle_ptr<br />        base </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face pts<br />        backwall </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face back_wall<br />        <br />        hei </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">-</span><span class="syntaxdefault">hei if </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dot</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Z_AXIS</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        <br />        base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> color        <br />        base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> color<br />        <br />        mat </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br />        mat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0.5<br />        <br />        base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">        base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull </span><span class="syntaxkeyword">-</span><span class="syntaxdefault">hei<br />        triangle</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull wid<br />        group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">      if face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">X_AXIS </span><span class="syntaxcomment">##&& face.normal==X_AXIS.reverse### == faces 'UP'... BUT you can use any vector to compare<br /></span><span class="syntaxdefault">        <br />        mats</span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add </span><span class="syntaxstring">"Color_Texture"<br /></span><span class="syntaxdefault">        mats</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">texture </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file </span><span class="syntaxstring">"panelskin1.jpg"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Plugins"<br /></span><span class="syntaxdefault">        mats</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">color </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> color<br />        face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> mats </span><span class="syntaxcomment">#"Magenta"<br /></span><span class="syntaxdefault">        face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material</span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Magenta"<br /></span><span class="syntaxdefault">        <br />        mat1 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br />        mat1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">5<br />        <br />        elsif<br />        face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">X_AXIS</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse<br />        </span><span class="syntaxcomment">#face.material= #"Magenta"<br /></span><span class="syntaxdefault">        mats</span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add </span><span class="syntaxstring">"Color_Texture"<br /></span><span class="syntaxdefault">        mats</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">texture </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file </span><span class="syntaxstring">"brick.jpg"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Plugins"<br /></span><span class="syntaxdefault">        </span><span class="syntaxcomment">#mats.color = color<br /></span><span class="syntaxdefault">        </span><span class="syntaxcomment">#face.material= mats<br /></span><span class="syntaxdefault">        face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material</span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> mats </span><span class="syntaxcomment">#"Magenta"<br /></span><span class="syntaxdefault">        </span><span class="syntaxcomment">#mat1 = face.material<br /></span><span class="syntaxdefault">        </span><span class="syntaxcomment">#mat1.alpha =0.5<br /></span><span class="syntaxdefault">        <br />        </span><span class="syntaxcomment">#break ### stop looking<br /></span><span class="syntaxdefault">      end<br />       <br />    </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">    <br />        <br /> end<br />end<br /><br /><br />if </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">not $Testbox_menu_loaded</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  <br />  UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Tools"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"TEST_BOX"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> Testbox</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">new </span><span class="syntaxkeyword">}</span><span class="syntaxdefault"> <br />  <br />  $Testbox_menu_loaded </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> true<br />end</span>
                              Iterate the definition's entities, collecting faces and their areas.
                              You then have the area of all faces inside it, it's always in sq".
                              Provided that you know the instance/its-container is not 'scaled' then that's it: otherwise you might need to get the scaling[s] and apply it to the area value ?
                              • nithi09N Offline
                                nithi09
                                Hi TIG I think my question is wrong way I asked. basically I want above code three group like "Triangle group", "cube group",and two together group call "sample group" each one has name, part number and so on.like when you click on lady in the model entity info definition name and clik on component attribute it gives lots of info name susan, description,color,and material.when I try do like this group.name = "somthing" and group.set_attribute('dynamic_attribute','volume',widdephei)it doesnot work. I look at group, component api is confusing me.could you explain me with sample code.
                                  OK.
                                  I think your question is, "How do I add an 'area' or 'volume' function to the DC code ?"
                                  There are already some threads about adding custom functions, so they can be used in formulas...
                                  There is an example of one for 'volume' already - here http://sketchucation.com/forums/viewtopic.php?p=464446#p464446
                                  You can add any 'attribute' to anything.
                                  The dictionary DC is "dynamic_attributes" [with a final S] - otherwise you are making a new dictionary with a slightly different name that the DC code ignores...
                                  • nithi09N Offline
                                    nithi09
                                    Hi TIG I have different question about sliding window. After draw window in the model go to component attribute under behavior onclick when I write ANIMATE("X",0,25) it window slides. how do I write in ruby script for in my model
                                    • nithi09N Offline
                                      nithi09
                                      Hi TIG I figure it out how to write animate. but I have a another question How do I make one group from bunch of small groups for example house has door group, window group, roof group (I mean door(),window(),roof()). now how do I do these three method in to one group? I need to make house group contain door group, window group, roof group. I search whole forum I could not find close to my situation. pls give me some Idea
                                      thanks
                                      • 3 / 4
