    Any smokers here? Wanna quit?
    822 Posts 42 Posters 356.4k Views 42 Watching
    • stefanqS Offline
      stefanq
      Cheers Oli, I didn't noticed any major difference, but I'm cutting the nicotine quickly, I'm on 8mg right now, so is hard to be objective. I'm using 2.5 ohm resistance right now, because the 1.8 ones ware out of stock. I believe because 1.8 is better. The ones with experience said that 1.8 will give you more vapour, better TH but lower flavour. 2.5 is better at flavour and will protect your battery better. Personally, if I have to choose right now, I'll be for 1.8 if I could find them. But remember, and sorry for repeating myself, I'm cutting the nicotine, and to be honest, I feel like I need to vape more often.
      Regarding rebuilding them, I used 1.5 kanthal and I felt less burned taste. Today I did another one, but without double legs. Looks like original one. I used 1.5 wire , 6 turns, held the silica and the wire over a flame, then I put it in the resistance body, did a dry burn, put 2 pieces of 1 mm silica above (very important for flavour) and that was all. I don't find my measuring device so again, I need to borrow one from a neighbour to see how many ohms did I get. Just to be in a safe zone, but I'm aiming 1.8- 2 at maximum.
      As a side note, I would not bother making them, but I bought all that wire and stuff. They are sooo inexpensive, peanuts like you said.
      So, did you try it? The Evod? I'm pretty happy with them, the oldest one is almost 3 weeks now, and is doing fine. I did cracked one around the mouthpiece, but was my fault, trying to clean the shirt out of him, stuffing some ears stick in it... but amazingly, it still no leaking.
      Sorry for not being able to give you a strait answer.
      Cheers,
      Stefan
      • stefanqS Offline
        stefanq
        I would love to buy something like that, but they aren't for evods...
        This is...almost beautiful πŸ˜†
        • olisheaO Offline
          olishea
          haha it's like barbed wire. thanks for all that buddy! I think I'll just get them to buy the coils!! The EGO is set to 1.8 so I guess using a 1.8 coil for the EVOD works nicely. I've been using 0.16 nichrome for the kayfun, you tried something thinner? or is 1.5 kanthal the norm for an EVOD?
          Great work cutting down the nicotine. I'm on 11mg now, I'm gonna move onto 6mg and then 0mg eventually. I don't wanna be dependent on nicotine all my life, but for now I'm happy.
          Yeah I tried the EVOD. I much prefer it over the EGO atomizer, it's more consistent and durable. You need to draw back a bit more but I like that. If I need a small vape setup my choice would be EVOD atomizer for sure. Good, consistent flavour! I like the battery below too, fits perfect compared to a slight difference with the EGO battery.
          Stainless steel battery and stainless EVOD look great by the way. In fact I'd say it's one of the best looking combos.
          http://www.ivapour-elixir.co.uk/media/catalog/product/cache/3/image/9df78eab33525d08d6e5fb8d27136e95/i/m/img_1190.jpg
          oli
          • olisheaO Offline
            olishea
            It probably doesn't help that you have to make a really tiny coil too! Yeah I don't like the sound of inhaling burning rubber πŸ˜† unless of course it's from my rear wheels. πŸ˜‰
            I find it really easy to make coils with my Kayfun now. It was a nuisance at first but I can make them consistently between 2.4 and 2.5 ohms. Worth it for the flavour, everything tastes great with this atty, really enjoying it. A kayfun works best when between 6 and 8 watts...I just change the voltage according to my atomizer resistance using Ohm's Law Calculator. Sounds complex but it's easy. Over time a coil gets more resistive so I increase voltage after a week or so.
            http://www.ohmslawcalculator.com/ohms_law_calculator.php
            There are now variable wattage mods that do this calculation for you...you just set the wattage. Svoemesto are due to release one called the Semovar which looks interesting. But I think I've spent enough and I'm more than happy with the Provari. πŸ˜†
            Thanks again Stefan. πŸ‘ And keep it up!
            oli
            • stefanqS Offline
              stefanq
              Hello Oli, I'm using kanthal because it seams to be preferred over the nichrome by most of the "guru's" in the forum I just joined. They say nichrome is less resistive, and not so durable as kanthal is. Most of them use 0.2 kanthal, and 2 mm silica when they aim a 1.8-2.5 ohm resistance. That's why I bought that, but I wanted 0.15 wire as well.
              I was telling you to just buy pins, because is just to much hassle to make a perfect one.
              I made mine to look just perfect, nice raps perfect distance between them, but it didn't worked. The wire burned that rubber/silicon gasket that keeps the wires apart. The original resistance that came with the Evod, looked like like a 0.20 wire. Maybe 0.18. The ones that I bought on-line are 2.5 and the wire looks thinner. I'm not sure is kanthal, in fact I bet is nichrome. You could try to make one, if you have the nerves, just be sure to be rubber smoke free. It's definitely toxic.
              Regards,
              Stefan
              • stefanqS Offline
                stefanq
                Hey, do you guys signed up for some beta testing new devices, so you all are talking in some closed topic, or what?
                Just kidding
                Just found a store today, from my favourite on-line shop. It was right there, under my eyes. I found that guy vaping. That was a great first impression. The shop was pour, little space, not so many products, (no mods for example), but it did had what I had in mind to buy: Some new juice that I wanted to try, and some coils for my Evods atomizers. I was using Dekang only, so I tried the juice they made "in the house". Is fantastic. It is full VG, but way more tasteful. I had some red-bull and some apricot flavours. Red-bull is almost like real thing, and the apricot one......WOW I just love it. I think I found a fruity flavour that I'll be using from now. They said the tabaco flavours are way beyond any liquids on the market. So, it was a great day for me, I just have to find a way to promote this guy, because ( and he didn't told me directly) is not easy for him. Buy the way, his prices was as on the on-line shop. I asked about Mods, and we had a very nice chat. I'm really thinking to buy a Mod lately, but honestly, I don't afford a Provari, I can't justify that to my wife right now. I was looking at one particular Mod, (mechanic), buid buy a guy from my country, which cost just 50 euro or so. It's called NOVA V2 Hybrid by CipCig . Check the review, if you have the time, because, I think the guy wanted to say that this is the best vaping device. I don't know....just watch.
                Unfortunately, this guy can't handle very well the amount of orders that he must deliver, so the waiting list for his device is closed.
                And by the way, I'm 45 days smoking free, but who's counting! 😍
                • soloS Offline
                  Seven weeks tobacco free, vaping and loving it. I have now vaped at restaurants, at a Rodriguez concert, while watching Star Trek at the movies this weekend, at a baseball game last night, this is fantastic, I'd vape in church if I ever went to one.
                  • olisheaO Offline
                    olishea
                    πŸ˜† πŸ˜† you got balls man. but why not? hehe nicely done on the 7 weeks pete. πŸ‘
                    I'm glad you like the VG based liquids Stefan. I enjoy them more too, I like a smooth drag not a strong throat hit. I just can't use PG based liquids in my Kayfun, they taste too harsh. In an EVOD or EGO there isn't much difference but I must get 5x more vapour from VG based liquids. That's what I like, tasty thick clouds!
                    I've been looking for a reliable UK or US manufactured VG based brand but I just don't know where to look, there are so many!! It seems as soon as they say "made in UK" they double the price! πŸ˜† I'm currently using a lovely VG based blueberry flavour at 16mg. The 11mg version is PG based for some reason, so really I need to change brands to reduce my nicotine.
                    Yeah it's annoying about the waiting list for the vape you mentioned. You would think the manufacturer would jump at the chance at mass production but it seems people just don't have any backing. It's difficult to buy any top-end rebuildable atty, they get sold out immediately. I had to wait a few weeks for my Kayfun.
                    With regards to Provari, there are plenty of mods that do the same job, it's just a very polished example with great build quality. They are around Β£170 in the UK which is double the price I believe they should be.
                    oli
                    • olisheaO Offline
                      olishea
                      how's everyone doing?
                      I bumped into a friend I haven't seen in a year and first thing he said was, "Have you been going to the gym, or dieting or something?".....to which I replied, "no, why?", he then said, "I dunno you just look healthier, if that makes sense," then it clicked, "Oh I quit smoking a few months back, it must be that and thanks for the boost mate!"
                      It made my day! 😍
                      I've cut back down to 11mg nicotine E-Liquids now, still going strong. I tried bubblegum and strawberry flavours but found them to be rather sickly. Still on blueberry flavour until I find something better.
                      Stefan I tried the 1.8ohm coils in the EVOD and I gotta say they are better than the 2.5ohm coils. It's a subtle difference but I definitely prefer the 1.8, they always get sold-out first over here too.
                      I really do recommend the Kanger EVOD to anyone who wants a small vape setup; the coils last a long time, cheap to replace and give a great vaping experience. I still prefer my Kayfun 3.1 obviously but if you want a small vape when out and about, the EVOD is hard to beat and one of the best looking atomizers IMO.
                      oli
                      • stefanqS Offline
                        stefanq
                        Cheers everyone! I'm doing fine, thanks for asking Oli. 8 weeks, no smoking....WOW! I had to check the calendar, I've forgotten already. But that's a good sign, right? I didn't tried a cigarette ever since, not even one puff. I don't crave, and I'm not curious.
                        I tried several liquids (brands) and I have a new favourite, LiQua, american blend, 18-12 mg. I'm not sure I can go with 12 mg nicotine from now on, because sometimes, I just need more. Then I use 18 mg. My Evods are going strong, even the cracked one. I can't find 1.8 ohm resistance, but my supplier said only 1.8 and 2.2 are shipping in the next transport, so it will be better. I'm active on a forum, here in my country, and this guys seams obviously concerned about all the news regarding banning ET smoking around the world. They say will buy buckets of liquid base and flavours, if some imminent kind of restrictions are going to happen . Until then, I'll enjoy my vapours.
                        Clouds of tasting vapours for everybody!
                        Edit:
                        Pete, are these tanks available for you? That's what I call "pimp my vivi nova"
                        • soloS Offline
                          Yes they are, I have 3 of them, I'm using one at the moment
                          • olisheaO Offline
                            olishea
                            I don't think they will ban e-cigs in EU, rather they will heavily tax them. We live in a sick, sick world if they allow cancer sticks to be sold but restrict the possible solution. I hear the EU are proposing to reduce E-liquid nicotine to 4mg maximum, I just don't see the point. I do, however, think they will be banned in public places....just because they can! πŸ˜†
                            oli
                            • soloS Offline
                              Saw this online, cannot vouch for it's accuracy, interesting however.
                              • olisheaO Offline
                                olishea
                                roll on 15 years because I've quit for life!
                                They don't mention how much improvement you get to smell and taste; I could hardly smell anything when I was smoking, now I'm like a dog!!
                                The rule of thumb I was told....it takes half the time to recover from the total time you've been smoking. So if you've been smoking for 10 years, it takes 5 years to recover completely. 30 years smoking, 15 years to recover etc.
                                I don't know how true that is, but it seems likely. I used to think once the damage is done, it's done, but that isn't the case.
                                oli
                                • BoxB Offline
                                  If didn't realise it made you so flexible, if you keep doing that they'll put a lampshade around your neck!
                                  • olisheaO Offline
                                    olishea
                                    let them do it!!
                                    http://1.bp.blogspot.com/-KYaOs8RsOfs/UTD_0yYz51I/AAAAAAAAAYc/WKseCa4fxoY/s1600/cone-of-happiness-dog-meme1.png
                                    oli
                                    • olisheaO Offline
                                      olishea
                                      Pete is that the vivi nova 2? supposed to produce more vapour and better flavour than the first version as it's dual coiled. gotta try one some time.
                                      I had to go back up to 16mg nicotine E-Liquid. The 11mg just wasn't cutting it, started getting a bit fidgety.
                                      The liquid I buy is great but the supplier is a total moron. It takes almost 2 weeks to receive a delivery! Still looking for a reliable UK supplier with nice flavours. I even have to email the owner with my invoice to ensure it actually goes through, he promised me some free E-Liquid after the delay in delivery last time but I doubt it will happen.
                                      Cloud 9 Vaping are supposed to be stocking more varied flavours in the future so they will be my go-to guys, quality service every time, just a shame they don't yet have the flavours I want.
                                      oli
                                      • soloS Offline
                                        Yes it is, I just bought a set of 10 atomizers (dual coil) for $ 3.15 each atomizer, I use the 2.8 ohm and set my power on the Provari at 4.6, I find that the best setting for huge vapor , full flavor and they last long.
                                        • olisheaO Offline
                                          olishea
                                          lol $3.15!! in UK they retail at around Β£10 each!! do you have to replace the whole unit or do you just buy new coils? I also have my provari at around 4.6, I find anything less than 4 is pretty pointless and over 5 is too harsh.
                                          oli
                                          • soloS Offline
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 41
                                            • 42
                                            • 14 / 42
