    Ruby array to hash
    7 Posts 4 Posters 1.3k Views 4 Watching
      krisjaniszakis
      Hi is there a fast way or some ruby libraries how to convert array[] to hash{} ?
      Example of array[]:
      a=[] a << [test1, test2, test3, test4]
      How can I fill in hash{} with entity name and value?
        #hash_to_array... including nested hashes
            def h2a(h={})
                a=[]
                a=[*h] if h.is_a?(Hash)
                a.dup.each_with_index{|e, i|
                    a[i][1]=h2a(e[1]) if e[1].is_a?(Hash)
                return a
        #array_to_hash... including nested arrays
            def a2h(a=[])
                h={}
                a.each{|e| h[e[0]]=e[1] } if a.is_a?(Array)
                h.dup.each_with_index{|e, i|
                    h[e[0]]=a2h(e[1]) if e[1].is_a?(Array)
                return h
          What do you mean by the name and value of an entity?
          • Dan RathbunD Offline
            Dan Rathbun
            Assum,ing every component instance has a unique name assigned...
              model = Sketchup.active_model
              comps = model.entities.grep(Sketchup;;ComponentInstance)
              pairs = comps.map {|i| [i.name,i] }
              hash  = Hash[ *pairs.flatten! ]
            I'm not here much anymore.
              krisjaniszakis
              Thanks TIG your generous script prints out unique arrays and it is not realy the exact case.
              thomthom -> name, value
              h{"name" => value, "name" => value,}
              Looks like I havn't told all the details.
              1. I have multidimensional array[] in Ruby
              2. I want to send array[] to Webdialog using dialog.execute_script()
              3. I want to send to PHP and arrange and do stuf with array[]
              My array[] looks like this array[[value1, value2, value3,...],[value1, value2,...],...]
              Im trying to transform array[] to hash{}
              hash{0=>[0_0=>value1,0_1=>value2,0_2=>value3,...],1=>[1_0=>value1,1_1=>value2,...],...}
              maybe I don't need transform, maybe I can send directly from Ruby to PHP without sending to Webdialog ?
                My code makes an array into a hash and all its nested arrays into hashes too.
                And vice versa for hashes to arrays.
                It's specifically written to de-hash/re-hash hash data for use in attributes - which can contain arrays but not hashes...
                In you case you just need to make simpler versions that doesn't iterate through the array's/hash's contents...
                Also reading your OP and comments you could easily write all of this info directly into a hash initially and not worry about later manipulations πŸ˜•
                  krisjaniszakis
                  Thanks TIG it is a good point πŸ˜„
