    Webdialog connect to PHP
    13 Posts 4 Posters 2.6k Views 4 Watching
      hm.. well, at least AJAX will work. I've used that myself.
      • G
        Gábor
        There is an other possible hack - however more complicated - to use GET variables instead of POST:
        • You open index.php in your webdialog.
        • index.php contains the Javascript to get the Ruby variables
        • You make a Javascript redirect with the variables appended to the URL as GET variables.
        • You have the GET variables available at the .php side.
        Not a usual solution but works.
        • K
          krisjaniszakis
          Thanks I thought about it too, but could you pleas post small code example ?
          • G
            Gábor
            @krisjaniszakis said:
            ...could you pleas post small code example ?
            A possible exampele for myfile.php:
            <?php if(isset($_GET['v'])) ; ?>
            	The variable; <?php echo $_GET['v']; ?>
            <?php else ; ?>
            <html>
            	<head>
            		<script type="text/javascipt">
            			var v=[ your function to get the ruby variables ];
            			function myredirect() {
            				window.location='http://myserver.com/myfile.php?v=' + v;
            			window.onload=myredirect();
            		</sript>
            	</head>
            	<body>
            	</body>
            </html>
            <?php endif; ?>
            • jiminy-billy-bobJ
              jiminy-billy-bob
              Something like
              First page, js :
              window.location.href = "http://www.domain.com/page.php?param=foo"
              Second page, php :
              <?php echo $_GET['param']; ?>
              (Returns "foo")
              EDIT : Well, too slow 😄
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Gábor's exemple is similar to the behavior of an HTTP redirect (window.location.replace("");)
                While mine is similar to the behavior of clicking on a link (window.location.href = "";)
                Depends on what you want to do.
                • K
                  krisjaniszakis
                  Thanks Gábor and jiminy-billy-bob I combined both scripts and now understand how to do it 😄
                  Does some one know how big(length) array ("v") I can send through ?
                    That would be limited by the URL scheme. I cannot remember the maximum size...
                    • G
                      Gábor
                      Don't forget to urlencode/urldecode the variable if it contains special characters...
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        http://stackoverflow.com/a/7725515
                        But big data like this you should go with POST instead of GET
