    Webdialog connect to PHP
    13 Posts 4 Posters 2.2k Views 4 Watching
      krisjaniszakis
      Have some one tried to send data from Webdialog to PHP.
      How to do it ?
      I found that post_url could help but it doesnt.
      data << [aa,bb,11,22] dlg = UI::WebDialog.new dlg.post_url("http://localhost/sketch/index.php",data)
        You could make an AJAX request.
        http://api.jquery.com/category/ajax/
        Btw, what happens when you use #post_url?
          krisjaniszakis
          It gives me blank page and doesn't transfer
          data
          array to that page 😞
          I will try to look at AJAX thanks.
            hm.. well, at least AJAX will work. I've used that myself.
              Gábor
              There is an other possible hack - however more complicated - to use GET variables instead of POST:
              • You open index.php in your webdialog.
              • index.php contains the Javascript to get the Ruby variables
              • You make a Javascript redirect with the variables appended to the URL as GET variables.
              • You have the GET variables available at the .php side.
              Not a usual solution but works.
                krisjaniszakis
                Thanks I thought about it too, but could you pleas post small code example ?
                  Gábor
                  @krisjaniszakis said:
                  ...could you pleas post small code example ?
                  A possible exampele for myfile.php:
                  <?php if(isset($_GET['v'])) ; ?>
                  	The variable; <?php echo $_GET['v']; ?>
                  <?php else ; ?>
                  <html>
                  	<head>
                  		<script type="text/javascipt">
                  			var v=[ your function to get the ruby variables ];
                  			function myredirect() {
                  				window.location='http://myserver.com/myfile.php?v=' + v;
                  			window.onload=myredirect();
                  		</sript>
                  	</head>
                  	<body>
                  	</body>
                  </html>
                  <?php endif; ?>
                  • jiminy-billy-bobJ Offline
                    jiminy-billy-bob
                    Something like
                    First page, js :
                    window.location.href = "http://www.domain.com/page.php?param=foo"
                    Second page, php :
                    <?php echo $_GET['param']; ?>
                    (Returns "foo")
                    EDIT : Well, too slow 😄
                      jiminy-billy-bob
                      Gábor's exemple is similar to the behavior of an HTTP redirect (window.location.replace("");)
                      While mine is similar to the behavior of clicking on a link (window.location.href = "";)
                      Depends on what you want to do.
                        krisjaniszakis
                        Thanks Gábor and jiminy-billy-bob I combined both scripts and now understand how to do it 😄
                        Does some one know how big(length) array ("v") I can send through ?
                          That would be limited by the URL scheme. I cannot remember the maximum size...
                            Gábor
                            Don't forget to urlencode/urldecode the variable if it contains special characters...
                              jiminy-billy-bob
                              http://stackoverflow.com/a/7725515
                              But big data like this you should go with POST instead of GET
