    ? about file size/polygon count
    25 Posts 5 Posters 3.4k Views 5 Watching
    • KrisidiousK
      Krisidious
      @rose123 said:
      Another one for Krisidious. I'm off to put some columns in it now...
      http://i83.photobucket.com/albums/j320/DrawMeAPicture/5-23-20135-57-51PM_zpsc7d6ac7f.png
      that looks challenging. and decrepit.
      By: Kristoff Rand
        Rose123
        Ok, one more question, if you don't mind! In the statistics I can see the number of edges, faces, etc. Is there a range for that in which a model should fall? Like what would be small vs large?
        • KrisidiousK
          Krisidious
          Well I would say that once you get past 100,000 faces you're going to star noticing... When you go to rotate around your model view you will notice at some point that SU will make your model into a ghost of itself to rotate more quickly and easily. This is the first clue you're getting too big.
          By: Kristoff Rand
            Rose123
            A ghost of itself? I just get a freeze and the message, "The program is not responding."
            • KrisidiousK
              Krisidious
              The entire model will change to a type of greyed out, simplistic version of itself often showing a bunch of group/component constraints.
              You get program not responding while rotating around the model? Or while performing a function?
              One thing about SU, at least the old version, is that while it's thinking you should not attempt to do anything within the software and you might consider not doing anything with your computer period, until it finishes thinking. some plugins that are doing critical calculations use the progressbar.rb to show you what's going on, some don't... You'll learn one indicator is what type of cursor you can see at the time. black for ready to work, white for thinking. Others might be able to shine more light on this for you.
              By: Kristoff Rand
                Rose123
                I think I have a different SketchUp, the low-rent version or something, lol. Don't know about old, I have 8. I've never gotten a different color cursor or a grayed out model. If the file (geometry, whatever) is too big, it just runs slow and then freezes up.
                • KrisidiousK
                  Krisidious
                  V8 is just the last version as of a day or so ago. V2013 is the latest.
                  You could share your model and we could look at it. You could try Goldilocks 2.0 to find what is so big... http://sketchucation.com/forums/viewtopic.php?p=281153#p281153
                  What are your system specs?
                  By: Kristoff Rand
                  • Alan FraserA
                    Alan Fraser
                    Normally, SU will go through a progressive series of display abbreviations as you attempt to navigate a complex model.
                    In that columns skp I posted earlier, when it's first opened, you will probably find the SU initially refuses to do anything at all for quite a few seconds. However, once it 'gets used to' the model you will most likely find that you can actually rotate it...but you'll lose shadows, all the texturing on the columns...and all the fine detail up top, like the acanthus leaves, is replaced with simple bounding boxes.
                    3D Figures
                      Rose123
                      Alan -oh, I understand now about the display abbreviations. Yes, I've seen that.
                      Krisidious -I wasn't referencing one model in particular, just in general. Re my system specs, just standard off the shelf. What I have noticed is the difference a specialized video card makes in display, screenshots and exports. At work we have GTX 6000 series cards. I mention this because I've seen past posts from people complaining that their exports look jagged, and answers that suggested plugins and other stuff, but not the video card.
                      • KrisidiousK
                        Krisidious
                        I have two GTX 470's running sli. I've never heard of the GTX 6000 do you mean a Quadro 6000? if so that's an impressive card and should handle anything you throw at it.
                        Try Goldilocks and report back on any file. you've got a bottleneck somewhere.
                        By: Kristoff Rand
                        • AdamBA
                          AdamB
                          Another way of looking at this is "Geometry Density". You want appropriate amounts of detail - with drag and drop of components from external sources, its very easy to add innocuous content that has far too much detail compared to the rest of the model. I've seen simple school room models with more faces in a single coat peg than in the rest of the model!
                          For this reason, I wrote a free plugin called Goldilocks which can help track down in your model, where you've got geometry objects which have more detail than the surroundings.
                          ERROR: The request could not be satisfied
                          (extensions.sketchup.com)
                          Adam
                          • 2 / 2
