    Help with adding extension to Trimble's Extension Warehouse.
    9 Posts 5 Posters 651 Views 5 Watching
    • renderizaR Offline
      renderiza
      Just recently got aproved for adding plugins to Extension Warehouse ๐Ÿ˜ but when I try adding one this error appears:
      RBZ Problem: Your extension must implement the SketchupExtension class.
      Can someone explain to me what is wrong with the following rbz found in this link?
      http://sketchucation.com/forums/viewtopic.php?f=323&t=52238
      Note: I have made the plugin to be an extension so that you can see it under Window > Preferences > Extensions.
      Any help will be appreciated! ๐Ÿ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        pballew
        Hi Renderiza,
        This error is because the SketchUp Extension Warehouse requires that you create and register your extension in your top-level .RB file, like this:
        my_extension = SketchupExtension.new("MyExtension", File.join("MyExtension", "loader.rb"))
        Set your name, description, version, creator, copyright properties here
        Sketchup.register_extension(my_extension, true)
        If you add that, your submission should work.
        Paul
          renderiza
          The problem was that I had a .rb named RND_0_Menu which was there to make some menus and then load the main .rb named RND_Animatex which then had all the code to register the extension. Sinse RND_Animatex wasn't the top-level .rb I was getting that error but I will fix that soon.
          Thank you for your help I really appreciate it!
            That won't work. ๐Ÿ˜’
            You need an RBZ file containing a rb and a subfolder.
            The 'extension_loader' rb that goes into the Plugins folder [and so it auto-loads] will be named say:
            xxxxxxxx.rb
            All that this particular file does is load/register your extension.
            And then a subfolder of rb/rbs files - which MUST also be called ' xxxxxxxx'.
            One of these files should be the 'menu_toolbar_loader' rb [with 'any name' allowed] which is loaded by xxxxxxxx.rb [potentially if its extension is 'checked'].
            In turn that file can also load all of the remaining main-code rb/bs files in its subfolder and also make its menus/toolbars/webdialogs etc... ๐Ÿ˜ฎ
            It's just some of the many EW rules... which can't be avoided. ๐Ÿ˜ž
              renderiza
              I could not make it so that every plugin I made will share same sub-menu under plugins. ๐Ÿ˜•
              Tried even registering both RND_0_Menu and RND_Animatex as extensions but seem you can't have two under same .rbz file.
              Upon realizing this I decided to not put every plugin under same sub-menu and everything now works smoothly. I am awaiting approval for the plugin so fingers crossed.
              Here is final RBZ file just in case someone is interest...
              RND_Animatex v1.0.6.rbz
              Finally thanks to everyone that was helping me on this! ๐Ÿ‘
                renderiza
                I did it! ๐Ÿ˜
                All my plugins will appear under "Renderiza Tools" in the Plugins Menu and still be compatible with Extension Warehouse Rules.
                I looked at some of Chris Fullmer plugins to see how he did it and then tried does techniques to my plugins and it worked so THANKS Chris Fullmer! ๐Ÿ‘
                • Chris FullmerC Offline
                  Not a problem, glad it worked. I finally remade my menu scheme so as to remove the only global variable I had been using, and wrapped all my menus into my own developer module. Much cleaner now. Thanks to Dan for his examples of how to nicely wrap up scripts into a single developer module. Hopefully I did it right ๐Ÿ˜„
                  • Dan RathbunD Offline
                    Dan Rathbun
                    ROFL
                    I remember a time when you got real testy about cleaning up your plugins. ๐Ÿ˜‰
                    Glad you've seen the light. ๐Ÿ’ญ
                    I'm not here much anymore.
                      I think we all have our shining moments, and I'm certainly no exception ๐Ÿ’š
