    Sketchup 2013 issues
    208 Posts 53 Posters 21.5k Views 53 Watching
      circus
      I am running on a mac OS X 10.6.8? Sketchup 2013 will not install? Does anyone know if there is a work around for this....for I havent the cash to purchase a new computer?
      P.
      • jeff hammondJ Offline
        P.
        what mac can run 10.6 that can't go to 10.7?
          circus
          ?? I am on a mac book pro, Processor 2.16GHz Intel Core 2 Duo Memory 4 GB, while I haven't tried to upgrade to 10.7 or later, and not being technically minded, I was lead to believe that I am unable to upgrade?
          p.
          • arail1A Offline
            arail1
            Toolbar question:
            Where are the toolbar icons stored?
            There is a tool on the Getting Started Toolbar (Send to Layout)that I tried to drag to another toolbar but I dropped it between toolbars accidentally and it disappeared. How can I get it back?
              Click on Reset in the toolbars window. That should put the button back.
              • Dan RathbunD Offline
                Dan Rathbun
                (1) Open the "Toolbars..." dialog.
                (2) Select the "Getting Started" toolbar.
                (3) Press the "Reset" button.
                (4) Hold the "CTRL" keyboard key when you drag buttons so they copy instead of move.
                I'm not here much anymore.
                • arail1A Offline
                  arail1
                  Thanks all. That works.
                  • kenK Offline
                    ken
                    I am surprised the number of toolbar icons that were 32x32 or 24x24 instead of 16x16 for small. It wasn't that visually apparent in Ver 8, however, it was apparent in Ver 2013.
                    I went though and changed all the icons that were not at 16x16 and now my toolbar displays looks OK if not great.
                    Ken
                    • arail1A Offline
                      arail1
                      Interesting to note that I got my first sales pitch from Trimble (for a laser level) - 1/2 day after giving up my info to purchase an upgrade.
                      • charly2008C Offline
                        charly2008
                        I have copied my plugins folder from Sketchup 8 into Sketchup 2013. So far no problems except for these two plugins. In Sketchup 8, this error message does not appear! I am a bit perplexed because these plugins are not available in the original folder of SketchUp 8.
                          It seems there isn't. I used Jim's custom toolbar plugin with some additional buttons for toggling hidden geometry, parallel and perspective camera, profiles, endpoints etc (which do not have toolbar buttons) but unfortunately that plugin does not seem to work in SU 2013.
                          • KrisidiousK Offline
                            Krisidious
                            So no way to add other native commands to a custom toolbar?
                            Google icons can't be moved to Sandbox bar?
                            By: Kristoff Rand
                              Krisidious
                              Well, at least this is good news for Jim and his custom toolbar plugin.
                              By: Kristoff Rand
                                Why would it be good news if it does not work?
                                  charly2008
                                  Hi Kristoff,
                                  it seems so!
                                    Krisidious
                                    Because it can easily be fixed and Trimble is not competing with his idea of customizable toolbars.
                                    By: Kristoff Rand
                                      Well, hopefully. Now I am afraid I'll need to memorize some further shortcuts. 😄
                                        Krisidious
                                        I have a post going about Jim's toolbar. Thom, Ray and TIG were looking so maybe we'll get a fix.
                                        By: Kristoff Rand
                                        • Chris FullmerC Offline
                                          Hi all, a few things here. It's true, OS 10.6 is no longer supported, you will need to upgrade to 10.7. Most plugins should load, but there will be those that do not. Charly, I think that first one is Aeriliius's, and he has a new version. So delete that one and go install his new one:
                                          http://extensions.sketchup.com/en/user/321/store
                                          And also, toolbar icons are customizable only on the default SU toolbars, not ruby toolbars. I realize it might not be that apparent which is which, but sandbox, DC's Advanced Camera Tools, True North, Shadow Strings are all ruby toolbars.
                                            Krisidious
                                            Thanks Chris...
                                            BTW... See all of those kool icons at the link you gave? I want every tool in sketchup, ruby or native to have the ability to make an icon and to put it on a toolbar that I made. every thing sketchup can do, I want to be able to put on a toolbar. Thanks and get on that.
                                            👍 Seriously thanks for the hard work. 👍 I know everyone is being a bit hard on the SU Dev Team right now. 👿 But we do love you guys. Well, I do. 😄
                                            I love Sketchup the way it is and I'm not really in need of too much more. Bug fixes yes, new tools are kool, but I can't think of anything I can't do without a plugin. So it's not like I was expecting something else and didn't get it. And I've really been needing these layout improvements since I started doing my Finals in it. But we must remember that POW's often exalt the stale bread they are given when starving. just kidding... kinda. 🤣
                                            By: Kristoff Rand
                                            • 11
                                            • 1 / 11
