    Flatten to 2d but keep its surface area
    4 Posts 2 Posters 549 Views 2 Watching
    • B
      bhbarchitects
      Morning
      How do i flatten a domed shape to 2d but keep its area?
      I have enclosed a rough shape.
      The reason is to be able to model a shape then flatten it so i can send it to a vinyl cutter which then cuts the correct dimensions.
      Cheers
      model showing rough shape
        Never used any of them, but:
        http://sketchuptips.blogspot.no/2007/08/plugin-unfoldrb.html
        http://www.pumpkinpirate.info/flattery/
        • B
          bhbarchitects
          Thom Thom
          Once again your knowledge seems to have saved the day. Early tests on unfold seem to work, will post if successful.
          Thanks again. 😍
          • B
            bhbarchitects
            Going to post this question here as it on the same subject.
            So 3d scanned a panel ready to unfold but currently the mesh is to complicated to unfold.
            Tried terrain reshaper but it does not seem to change.
            Trying to achieve a more consistent mesh which is not to time consuming to unfold.
            .skp is 8mb so put a share on dropbox
            https://www.dropbox.com/s/ur1su2eyv9eutyn/side%20panel.skp
            Multiple cookie or bottle of Scotch donation is someone can help!!
            image showing mesh
