    Shape style bug
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    9 Posts 4 Posters 9.3k Views 4 Watching
    • FrederikF Offline
      Frederik
      I've tried searching to see if this bug already had been reported, but I can't seem to find anything similar, hence this post...
      Steps:
      1.) Draw 2 lines
      2.) Select the first line and use the Shape style to set the Dashes style to 2 x dash and 2 x dots.
      3.) Select the second line and set the Dashes style to 2 x dash and 3 x dots.
      4.) Export to pdf-document.
      As you will see the lines looks identical in the pdf-document showing 2 x dashes and 2 x dots... 😐
      In LO they appear correct...
      If you print from LO the lines are also being printed correct...
      I've attached a sample file...
      Can someone else please confirm if they experience the same in order to report this as a real bug to Trimble...
      Dash-dot.layout
      Dash-dot.pdf
      Cheers
      Kim Frederik
        JuanV.Soler
        yes**Kim** , that is correct , it happens to me also 😞
        • FrederikF Offline
          Frederik
          Thanks for confirming, Juan...! πŸ‘
          It's a very annoying bug, since I use this in P&ID's to indicate different directions of water flow... 😞
          Cheers
          Kim Frederik
            same here
            • FrederikF Offline
              Frederik
              Does anyone from Trimble see these bug posts or should I report it somewhere else...?
              Cheers
              Kim Frederik
                It's reported πŸ˜‰
                • FrederikF Offline
                  Frederik
                  Cheers, Rich...
                  Much appreciated... πŸ‘
                  Cheers
                  Kim Frederik
                    marcdurant
                    Hi Frederik-
                    I just investigated this bug - it's apparently a limitation in the PDF library that we're using on Windows. It only supports line styles up to four elements, and skips any additional elements! So, dash-dash-dot-dot-dot (five elements) gets truncated to dash-dash-dot-dot (four elements).
                    We're looking at possible workarounds now but I can't promise anything. Sorry for the bad news, but thanks for reporting the issue.
                    thanks,
                    Marc
                    • FrederikF Offline
                      Frederik
                      Thanks... Much appreciated... πŸ‘
                      Cheers
                      Kim Frederik
