    New(ish) HouseBuilder ruby?
    14 Posts 8 Posters 4.5k Views 8 Watching
    • T
      tim
      OK, I managed to debug (good grief, Ruby is horrible) the issue with the door frame being offset (silly arithmetic error, easily fixed once spotted) and the weird-things-with-two-doors stopped after replacing the wall.
      • T
        tim
        Aaaannd... now I've managed to remove a really stupid bug that made the system beep every time you click for a context menu and the selection is not a wall. SIgh.
        • GaieusG
          Ah, that's the infamous beep with housebuilder!
          πŸ˜„
          • W
            watkins
            Dear Tim,
            Perhaps you could release your de-bugged version. I am sure that it would be useful to some Forum members. What is the etiquette here?
            Kind regards,
            Bob
            • T
              tim
              I'm perfectly happy to do so; if anyone wants to package it up that's fine by me; I guess Didier is the best candidate.
              Here it is anyway - modified Housebuilder.rb with the door sizing fixed to compensate for the rough opening offset and the stupid beep fixed. There is still a huge amount that could be improved.
              modified by tim Rowledge to fix a couple of bugs
              • W
                watkins
                Dear Tim,
                Thank you for doing that. I'm sure that others will appreciate having a de-bugged version.
                Kind regards,
                Bob
                  mikeh
                  Hello all,
                  Tim, thanks for the bug fixes. I found this thread doing a search to get rid of the beep you described. I downloaded the new .rb file and put it in my Housebuilder subfolder under Plugins, replacing the one that was there. However, I'm still getting the beep anytime I select the EDIT menu as well as every time I right-click on a drawing. Was this the beep that was address and, if so, are there more steps I need to take?
                  Thanks,
                  -mike
                  • T
                    tim
                    Ah. Yes, you need to slap me upside the head to upload the correct file. I forgot that I altered the HousebuilderTool.rb as well. So here it is.
                    HouseBuilderTool.rb
                    • G
                      gladtobegrey
                      Thanks for this ... I wondered where that 'plink-plonk' appeared from (I don't always have sound on, so didn't immediately associate it with Housebuilder).
                      • E
                        egarstang
                        [attachment=0:1lxtvlte]<!-- ia0 -->HouseBuilderTool.rb<!-- ia0 -->[/attachment:1lxtvlte]
                        Hi Tim, huge thanks for the door size bug fix. I copied the two files you posed into Plugins/Housebuilder file - fixes the door problem perfectly but has also converted my metric version of Housebuilder into imperial. Any advice on how to get it back to metric?
                        • C
                          Caerwyn_Isabella
                          I downloaded HouseBuilder.rb. Should HouseBuilder_extension.rb be removed from the plugins folder?
