    Grey Out Issue is back
    30 Posts 6 Posters 1.7k Views 6 Watching
      @Box
      I have six times more plugins loading that you - and no grey-out !! ๐Ÿ˜ฒ
      So some of yours must be suspect !
      Here's the differences I have spotted...
      **ae_ToolbarEditor.rb** Brighter3D.rb move_to_origin.rb move_to_origin_and_center.rb multi_face_scale_offset.rb Quick Lathe.rb **recurve.rb throw_to.rb Tile Grid.rb** **ToolbarBuilderFree.rb**
      You'll see that Rich has many different 'different ones'... so perhaps try disabling some of your common ones first ?
      But it doesn't mean that some others may be screwing up additionally... ๐Ÿ˜•
      • BoxB
        Recurve seems to be the only one we have in common, but I've been using that for a long time.
        Both Move to origins have had since I got off the ark.
        The toolbar ones and offset scale have only been installed very recently and the greyout was before that.
        Brighter3d, tile grid and quicklathe were about the same time.
        So I have removed a bunch and will see if it happens again.
        Be a shame if it is throw_to or recurve, use them both a lot.
          ae_ToolbarEditor.rb ?
            @Box
            The problem is not insolvable - if a tool is found to be make multiple commands it is possible to fix the code to avoid it...
            • BoxB
              I only installed that after having the greyout issues.
                @rich o brien said:
                I can't read that bold text
                Change the color
                What are you on about? All the items are in 'ruby' bbcode with bold for those.
                There's little difference... but there is some.
                  BUT it might have been the straw that breaks the proverbial... Maybe a few scripts are adding several extra commands, these then accumulate to the dangerous level ๐Ÿ˜ฎ
                  • soloS
                    I have one called !ae_LaunchUp.rb that I suspect may be the cause, what is it?
                      Aerilius Shortcut Tool
                        Well, my eye can't see the difference
                          Buy some glasses...
                          • soloS
                            I have only installed loaded LumenRT,Revizto, TT autosmooth, Tig splitdonut, clf components onto faces this year and prior to that I never had a grey out.
                            What is the plugin for Revizto called anyway, I cannot find it in plugin folder.
                              @Pete
                              If you disable those that you listed do the gray-outs stop ?
                                @tig said:
                                Buy some glasses...
                                ๐Ÿ‘
                                even with glasses I can't read it...
                                must be chrome or screen res
                                I can see it on my phone ok though
                                  I'm also noticing that box select is not selecting or click select.
                                  If i right click something it selects but the menu is greyed
                                  • 2 / 2
