    Can a script fire another?
    23 Posts 8 Posters 2.2k Views 8 Watching
    • CadFatherC
      CadFather
      • Dan RathbunD
        Dan Rathbun
        @cadfather said:
        so there is no way to call a script ...
        YEs.. and I have a few dynamic buttons on MY edition of the Ruby Console toolbar, that can re-load a script FILE. This is for development purposes.
        Ordinarily.. SketchUp plugin functionality is event driven, and only loaded ONCE.
        The days of re-running a linear set of statements (re-loading a rb script file,) EVERY time you want to do some task,.. are over, and very inefficient.
        @cadfather said:
        ... like we do with the keyboard shortcuts?
        Keyboard accelerators (aka shortcuts,) do not run a script.
        The fire command procs, via their command ID.
        The main issue CF is that the API, does not create a getter method to access the proc of SOMEONE ELSE's UI::Command object.
        Most of the native tools and such are not a problem, as there is a good set of send action strings (and even more on PC, because the NATIVE command IDs do not change very often, if at all. So we actual DO have a list of command IDs for native tools and application actions.)
        OK.. so IF we can make a standard.. AND get coders to agree to register their procs into a "table" (probably a Hash,) then a user customizable toolbar editor is VERY feasible.
        But it will ONLY work for coders that FOLLOW the standard.
        IN addition.. the API does not give full access to user shortcuts.
        Sketchup::get_shortcuts() only returns an array of strings, being the text representation of the keys, and the name of the shortcut,... BUT not the actual command ID that the shortcut fires.
        πŸ€“
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          I am talking about a collection (be it Hash or whatever.)
          The "school of thought" is that shortcuts are USER settings, and Ruby scripts should not be setting or changing what the user wants and has set.
          There is a beta plugin called "Crysis" that massively changes user shortcuts to enable a popup "toolpage".
          But it has not been received very well. (An the author just cannot understand why,... and we cannot make him understand. He just gets T'ed off when we try.)
          πŸ’­
          • CadFatherC
            CadFather
            Thanks Dan - i actually understand what you wrote.. πŸ‘
            ok, so this standard should really be set by trimble so any developer HAS to follow course.
            • Dan RathbunD
              Dan Rathbun
              Well this is a "political" issue.
              Some plugin authors.. especially commercial guys.. may not want anyone else to access their command procs in any other way, then via THEIR menu and THEIR toolbar.
              They have a right to be possessive to prevent "re-branding" and other "un-niceties".
              Authors who do not care, can right now create references to a Proc and a getter method so other could use it. But there is no standard.. so it can be and is done in a number of ways... IE, the identifier can change from author to author.
              Now the API could be changed so that proc references are always created.
              But there are issues with some Pro-Only plugins that would be defeated (some of them are OEM extensions.)
              SO it's not an easy issue.
              • Dan RathbunD
                Dan Rathbun
                I am thinking about a "public" switch, that can only be set when a UI::Command is initialized, via it's new() constructor.
                If not explicity set public, then a call() method would return nil, instead of firing the proc.
                Example:
                @cmd = UI;;Command.new("Widget",true) {
                  # this block is converted into the command's proc
                def cmd()
                  @cmd
                So some other plugin / utility that has a reference, or gets it via:
                SomeAuthor::Widget.cmd
                can call the proc, and it would execute IF the public flag was set true.
                Ie:
                SomeAuthor::Widget.cmd.call()
                  Aerilius
                  This is a preview of how it could work.
                  I only need to connect the wires to the same backend that LaunchUp uses…
                  drag & drop interface
                  Oh, and I hope Trimble will not prevent it (as it could be interpreted as violation of unwritten rules). Rather I wish they add the UI::Command.proc that we have been lobbying for so long.
                  • CadFatherC
                    CadFather
                    WOW!!! 😍
                    Aerilius, that looks the ******** business! πŸ˜†
                    Edit: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                    Edit 2: of course let me know if there's anything i can help with.
                    • renderizaR
                      renderiza
                      Not gonna lie, that does look the ******** business! πŸ‘
                      Hope this becomes a reality so I can use it!
                      Cheers!
                      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                      • BoxB
                        I'll add my ********business to that. The ability to mix and match would be priceless.
                        I'd love to be able to select a set of tools and have them all in one box.
                        Sometimes you only need one button from a toolbar but you have to have the lot.
                        As an example, throw simple bezier button together with EEBR and Radial bend. Three very useful tools together, little landscape used, you can always go to plugins or tools etc if you need one of the others.
                          RickW
                          ToolbarBuilderDemo is now available on Smustard.com for creating custom Ruby toolbars. Pro version to follow, with ability to save and load your toolbars, plus additional features.
                          RickW
                          www.smustard.com
                          • CadFatherC
                            CadFather
                            cool...it'll be interesting to compare the two, if and when Aerilius produces his masterpiece... 😎
                              Aerilius
                              Sorry for being late πŸ˜‰
                              • CadFatherC
                                CadFather
                                that's quite alright.. i was taking my time anyway.. πŸ˜‰
