    The real use of Sketchup to manage construction project
    11 Posts 7 Posters 2.9k Views 7 Watching
    • P
      pomtiff
      I have used Sketchup in the way that most people do not do. Because, I am in the construction industry, my work is to use Sketchup to promote collaboration between our clients (owners), my consulting team and our sub-contractors. The collaboration can be done in 3 ways
      Error 404 (Not Found)!!1
      (bimforwwt.blogspot.com)
      • HumpmetwiceH
        Humpmetwice
        I often catch myself doing the same thing with metal building manufacturing.
          mics_54
          I thought everyone did.
            raineysky
            Pomtiff,
            Thank You for sharing. I like your methods very much.
            • pbacotP
              Thanks Pomtiff. Always like to see your work and enthusiasm. Many of us use SU for design visualization with the client (as well as for construction drawings) and less as a costing and engineering tool for involvement with builders. This brings more of a construction management / BIM element to it. You seem to putting an integrated system together that others can plug into. Inspiring for those of us who work alone a lot of the time.
              The video is well done. Your english is not bad.
              • yorik1984Y
                yorik1984
                Humpmetwice, what plugins do you use fo this steel construction?
                • HumpmetwiceH
                  Humpmetwice
                  Yorik this is all I could find in the plugin folder. On mine it put a menu idem in the plugin menu "add beam". Works great for me, one of my favorite plugins but for the life of me I can't find anything else but the file I'm adding. Hope this works for you.
                  Beam tool.7z
                  • P
                    pomtiff
                    BOM and visualization power are geart in SKETCHUP as you are doing. But in my point of view, Sketchup could be more. I think it can make 4D and 5D for managing construction plan and resources and also cash flow, respectively. The true value of sketchup for construction industry should be done. in this way I guess.
                      jaysb
                      Really interested to see Sketchup used, outside of the usual areas of architecture/landscape design.
                      Had a quick flick to your web link to see how advanced you are taking this down the BIM route - where Autodesk are currently focused
                      • yorik1984Y
                        yorik1984
                        http://storage1.static.itmages.ru/i/13/0511/h_1368268723_9386135_5502febb8a.jpg
                        I use http://sketchucation.com/forums/viewtopic.php?t=35798 this plugin.
                        • P
                          pomtiff
                          See more
                          http://bimforwwt.blogspot.com/2013/05/biogas-system-presented-by-sketchup.html
