    [Plugin] V-Ray Tools
    238 Posts 80 Posters 269.2k Views 80 Watching
    • broomstickB Offline
      broomstick
      I had a little time to do a simple photomatch:
      this is the photomatch scene:
      http://www.3dita.it/plugins/vraytools/scena1.JPG
      This is the recreated scene:
      http://www.3dita.it/plugins/vraytools/scena2.JPG
      This is what Vray comes up with:
      http://www.3dita.it/plugins/vraytools/scena3.JPG
      Any advice?
        Is the V-Ray camera set to zoom?
          broomstick
          The zoom value of the Vray camera is set to 1,0
          Do I have to look somewhere else?
            penumbra
            TT,
            Thanks for the awesomeness, this one is a beauty. Put another beer on the map if in Baltimore.
            I am experiencing some odd behavior, perhaps others are also. I have a simple studio scene set up. After running the plugin and applying aspect ratio I see the familiar safe frame bars on either side of the viewport just fine. If I orbit around the scene and then try to return the scene to its view point by hitting the scene tab, the bars disappear. The only way I can get them back is by clicking off the TT vray camera tools and then running the script again. not a big deal but wish it weren't so. Any thoughts?
            Attached are some pics if it helps.
            My office still runs version 1.48 on Windows 7 64 bit machine.
            Omar
            Desired Setup
            Orbiting around
            return to scene, bars gone
              Not sure what it is. But I've had some issues occationally myself. Trouble is that SU doesn't expose everything. Might be that.
              After you set the aspect ratio you need to Update the scene. (Right-click Scene Tab > Update)
                penumbra
                TT
                Thanks, sure enough that did the trick. Now i am embarrassed.
                O
                  broomstick
                  Thanks for taking the time to follow me through. Let's hope a new version of VfSU is on its way soon!
                  • SupumanS Offline
                    Supuman
                    Thanks!!!very useful!!!
                      sp33d1984
                      http://t2.pixhost.org/thumbs/4648/16531774_error.jpg
                        sezarx
                        Hello Thomas,
                        Thanks for the brilliant and very needed idea behind this plug-in!
                        I'm having a difficulty installing it (using windows 7 64x , SU8 and vray 1.49)
                        as it seems , all other plug-ins for sketchup have a folder that comes with the zip file , in the forum page here , I couldnt find anything more than the .rb file
                        am I missing something?
                        I'm really sure I copied the .rb file to the right location and still sketchup wont recognize any new plug-ins
                        sincerely.
                        Arch. Qais Tabib
                          Note that the file you down load here is an RBZ files - not just RB. Right above the download in the red box there is a link to instructions to how you install RBZ files.
                            Missy_X
                            Hmmm, does the on demand loader work for anyone with the new v-ray 1.6 beta ? Or did i do something wrong ? lol. I disabled v-ray from extensions, but when i reload sketchup and click "start v-ray" from this plugin, it says in bottom left that it's loading v-ray but nothing happens.
                              It has worked for me...
                              If you open the Ruby Console, do you get any errors?
                              Also, could you please fill your your profile information with SketchUp version and OS?
                                Missy_X
                                When i press "Start V-ray" i get :
                                Error: #<LoadError: no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/plugins/VRayForSketchup.rb.disabled>
                                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VRayToys/vr_loader.rb:101:in load' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VRayToys/vr_loader.rb:101:in load_vray'
                                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VRayToys/vr_loader.rb:37
                                When i press "Load V-Ray on demand" i get :
                                Toggle
                                activating...
                                Could not activate loader. File not found.
                                  Missy_X
                                  Whoops ok, i was still running an old version of V-Ray tools, installed last version and it works fine now !
                                    Yea - that error was an odd one. Glad it's working now. πŸ˜„
                                      macmac12
                                      Thanks for this plugin thom. I don't see your toolbar after installation, already check the toolbar in view menu but it's already enabled. Im using sketchup2013 do you have solutions for this?
                                        That's a bad bug in SketchUp 2013. The toolbar is there - it's just that it's hidden underneath your existing docked toolbars. Undock them and you should find it. In order to unstick it you must double-click it. I hope the SU team comes with a patch quickly.
                                          macmac12
                                          Thanks thom, it's all good now. thats a very nasty bug in su 2013.
                                            Aye. 😞
                                            • 11
                                            • 12
                                            • 9 / 12
