    Export images to saved file location with file name
    15 Posts 4 Posters 764 Views 4 Watching
    • CadFatherC Offline
      CadFather
      hope it's making any 'copy/paste' sense
      what i'm trying to do is:
      1 - get a 'front' view, save the file into a folder called 'front' then export an image in the same folder ('front')
      2 - get a 'top' view, save the file to a folder called 'top' then export an image in the same folder ('top').
      and so on for any other view...
      now the saving to a new folder for each view has been basically done by TIG, but i want to add export the relative image too and i can't seem to set the path to be the same as the new saved file.
      am i too far off with this skillful code?
      model = Sketchup.active_model
      model_filename = File.basename(model.path)  #  i think i'm find out the models path
      view = model.active_view
      view.write_image( File.join(model_filename),600,600,true )
      thanks...
      • TIGT Online
        model.path is the path to the model's SKP, OR '' if the models has never been saved.
        model_filename = File.basename(model.path) is the name of the SKP 'xxx.skp'
        model_dirname = File.dirname(model.path) is the name of the folder containing the SKP 'C:/...../myskpsfolder/'
        The code I've given you previously shows how to make a new folder in that newfolder=Dir.mkdr(File.join(model_dirname, 'mynewfolder'))
        You meed to specify the image-name too...
        myimage=File.join(newfolder, 'myimagename.png') view.write_image( myimage, 600, 600, true )
        πŸ˜•
          CadFather
          thanks - i think i forgot to mention the image name has to be the same as the sketchup file just saved
          that's why i was trying: model_filename = File.basename(model.path)
          (i thought i was getting the name of the file in that particular folder)
          • TIGT Online
            To get the 'root' of the model name you can use
            title = model.title
            then to make the full image path...
            myimage=File.join(newfolder, title+'.png')
              CadFather
              ok TIG, thanks, i think i understand it - i shall look into it (won't take more than a few months) πŸ‘ πŸ˜„
                CadFather
                this does produce an image but the name is empty - only '.png'
                title = model.title
                myimage=File.join(dir2, title+'.png')
                anyway at least i know i'm on a better track now.
                  Aerilius
                  Did that happen in a new (unsaved) file? Then the model has no file name and the title is empty. You would then need to provide a fallback name like:
                  title = model.title title = "untitled" if title.empty?
                  Eventually we would hve to check if such a file already exists and iterate until the file name is unique.
                    CadFather
                    yes, it already has a name, this is what i'm running after making a directory and saving the file..
                    dir=Dir.mkdr(File.join(model_dirname, 'TEST'))
                    model.save(File.join(dir, File.basename(skp)))
                    imager=File.join(dir, model_filename+'.png')
                    view.write_image( imager, 600, 600, true )
                    • TIGT Online
                      BUT model.title and model.path etc are empty [''] UNLESS it's been saved.
                      Using the model.save() does NOT change the current model, it just saves a copy of it as it is...
                      So suspect you haven't saved the base SKP.
                      therefore the save you are doing is '.png', and the folder is probably not set wither
                      Therefore you need to do something to establish a 'title' some other way...
                      Tip, to see what is going on run with the Ruby console open and put a temporary ' p' in front of each reference you are setting to see what you get - e.g. p title=model.title should return "mymodelname" NOT "" - which shows it's not been saved...
                        CadFather
                        can't i just save it with the name of the copy then?
                          Aerilius
                          If you know that the file is saved to File.join(dir, File.basename(skp))),
                          you can also write the image to File.join(dir, File.basename(skp, ".skp")+".png"))
                          File.basename understands the second argument as an extension and strips it off; if the extension was unknown, we could obtain it with File.extname ("a_model.skp") or a regular expression.
                            CadFather
                            friends, let me say.. you are not from this planet...! (..but i'm very glad you landed!) πŸ’š
                            • TIGT Online
                              I recommend a minor adjustment
                              File.join(dir, File.basename(skp, **".*"**)+".png"))
                              • it is safer, because a file ending with '.SKP' would fail == not matching ".skp"...
                                CadFather
                                ok, TIG, i'll see what i can do. πŸ€“
                                this is what i'm getting towards: (and of course TIG has already done the biggest part)
                                i'll call it a batcher:
                                starts and asks for some options:
                                views to make = top, front, side, hi angle
                                delete all materials from model entities - on/off
                                shadows - on/off
                                fov value
                                layer name (to put the file contents into it)
                                when it starts, it opens a folder to choose and processes all files in it.
                                process does:
                                delete all guides,
                                purge all unused entities,
                                create a layer (named from previous options) and move everything in it,
                                set a custom style
                                go to the first view (ie. top) and save the model to a subfolder (top),
                                save a transparent png image of the same view and place it in the same subfolder (top),
                                then moves to the next file... 🀒
                                  bauhaustoourhouse
                                  I have run into an issue when I'm working on the same image on two different computers - when exporting the Sketchup image, the Width & Height are locked (when one is edited, the other automatically matches that computer's viewport ratio). I am trying to find a way to export an image with independently filled in Width and Height resolutions. This seems to be the closest Ruby I could find to fixing my issue. Is there any way to modify this to get what I'm looking for? I export so often that I would like to create a button on a new toolbar to keep at the top of the screen, instead of entering the Ruby Console every time. Is there any way to do this?
