    Square as base and circle as top face
    25 Posts 9 Posters 2.6k Views 9 Watching
    • newnoobN
      newnoob
      I've never dealt with plugins in SU and I've just tried to install the Plugin Store as olishea has recommended me in this thread to install then Curfiloft, but I already failed to install the Plugin Store.
      First I read this: http://sketchucation.com/resources/tutorials/37-beginner/108-installing-sketchup-plugins
      But it did not help me. Than I thought maybe I have to put the plugin file at first into the plugin folder of SU, to be able to select then the plugin in the "System preferences" window in SU. Well I did that but it is not displayed there.
      Then I saw the menu button "Plugins" but the plugin is not displaed not there either.
      ... so sad
        Verify if inside Sketchup Menu Windows / Preferences /extensions / Curviloft is enable!
        and Menu View ToolBars / Curviloft is enable
        If they are not existing
        Maybe I will use the old Method πŸ˜„
        Load the curviloft Plugin and the Library
        Curviloft 1.2d - 13 Apr 12.zip http://sketchucation.com/forums/download/file.php?id=86271
        Load LibFredo6 4.2 or higher http://forums.sketchucation.com/viewtopic.php?f=323&t=17947#p144178
        1. Download and Open the archive
        2. Select All (Ctrl A)
        3. Extract into the Sketchup Plugin Directory
        4. Answer Yes to overwrite former existing files if any
        The footprint in the SU Plugin Directory must be:
        C:\Program Files\Google\Google SketchUp 8\Plugins
        • LibFredo6.rb
        • LIBFREDO6_Dir_44 (or more recent)
        • CURVILOFT_Dir_12 (or more recent)
        • BoxB
          If you are still having problems installing the RBZ here's a little vid that shows you how.
          On a PC
          [screenr:2fz6h5rf]ptP7[/screenr:2fz6h5rf]
            Curviloft is like a programme itself! πŸ˜‰
            So good studies! β˜€
            • newnoobN
              newnoob
              THX you very much for your help.
              the "old method" has worked now Curviloft is displayd in SU under
              and a red juwel apperaed in SU when I opened it after I put the folders in the SU Plugin Directory
              maybe I have time to try out Curviloft in the evening, than I will post further errors πŸ‘Š
              • Jean LemireJ
                Jean Lemire
                [sub:2lt05k1e][/sub:2lt05k1e]Hi Alex, hi folks.
                If you want to practice using basic tools, before diving into the world of plugins, click in sequence on the scenes tabs of this sketchUp file for ideas. It is in V6 for Pilou.
                Square to round transition.skp
                • GaieusG
                  @jean lemire said:
                  [sub:3p4ysvc1][/sub:3p4ysvc1]Hi Alex, hi folks.
                  If you want to practice using basic tools, before plugin into the world of plugins, click in sequence on the scenes tabs of this SketchUp file for ideas...
                  Indeed it is best advised to understand how "geometry" works in SU first. Plugins are great to automate processes but unless (and until) you know what they are actually doing (and until you can do it yourself by hand any time - though obviously slower), you are mislead of your knowledge of SU.
                  This is particularly valid in this newbie forum, my friends! πŸ˜„
                  Do you guys want to learn here or just finish your job fast?
                  • newnoobN
                    newnoob
                    Jean thank you for your attachment, it made me understand how a transition from a square to a circle works and it remind that there actually is no "bent geometry", everything is done with "angled geometry".
                    But what I don't understand is why the move tool does not perform the "square to round" operation like in your attachment and instead produces a weird body like at the picture in my first post.
                      mrossk
                      Am I missing something or this Can be done with native tools and simply moving a circle vertically from on top of a square. One just needs to lock the vertical dimension when using the Move tool, no?Untitled.jpg
                      https://www.mkaplanfinefurniture.com/
                        For this time Jean makes a very complex creation! πŸ˜‰
                        It's just because the 2 figures don't start at the same place for the second click!
                        For that make like this πŸ˜‰ ( Whithout plugin! πŸ’š
                        Use the for the Square and the Circle!
                        (Of course you can increase the number of segments of the circle! )
                          mics_54
                          thanks pilou
                          I couldn't remember the alt key!
                          • newnoobN
                            newnoob
                            @ Pilou
                            Your answer was the answer! – so it does work and it can be done with the move tool, my two figures where just not centered correctly above each other.
                            THX you.
                            Phuu that was a long thread to get finally aware of that.
                            ..and I spend quite some time yesterday to build figures like in Jeans attachment, well I guess it was not pointless, maybe I've learned something thereby
                            ..hopefully πŸ˜•
                              It's always like that the first time, but the next time when you have well understood that will be like the light's speed! πŸ˜‰
                              • olisheaO
                                olishea
                                Sorry I didn't realize it was the Newbie section and would have answered accordingly.
                                Moving a circle upwards from a square seems to work fine for me, for this purpose. ❓
                                oli
                                  mics_54
                                  Guess I'm just not an ALT kinda guy.
