    Rotate copy multiple
    26 Posts 8 Posters 5.9k Views 8 Watching
    • L
      lapx
      Jeff,
      Im the crazy one. your post describes exaclty what i need. i cant belive SU does not have a command like this 😞
      Im exhausted using copy rotate and constantly having to go back and forth from the reference point center point to the point of placement:(
      Ruby Please πŸ˜„
      • GaieusG
        What exactly do you want to do here? Sorry, I do not understand. (maybe draw on that image)
          Seems remember that TIG has made a special Plug for that πŸ˜‰
          I will verify πŸ˜‰
          That was that πŸ‘
          Radial Lines fixed lenght by TIG πŸ˜‰
          Usage:
          Select one guide-point [cpoint] and some edges and/or faces
          then run Plugins menu 'Radial Lines Fixed Length' menu items...
          Enter a Length in the dialog [current units].
          Line 'rays' are drawn from the cpoint towards the selected vertices using
          that Length.
          So you will obtain your result asked without effort even it's not the same action! 😎
          So here same as a multiple rotate copy lines the 3D Space πŸ˜‰
          http://forums.sketchucation.com/download/file.php?id=55012
          • L
            lapx
            Gaieus,
            I want to copy rotate the supporting brackets to all the verticle joint locations.
            Hope this is clear,
            BTW there are about 30 brackets along the arc.
            Thanks,
              What is the problem?
              Find the center of the arc: Guide Tool by Thomthom
              You can now make a simple Copy Rotate between 3 little rectangles of the bracket πŸ˜„
              Select the 3 brackets
              Then make a copy of these 3 * X beteween column πŸ˜‰
              Not a big deal πŸ˜„
              • L
                lapx
                If anyone has used copy rotate in autocad they will get what i'm trying to do. When I copy rotate in su I always have to grab the center point of the radius for each copy. This is more time consuming than autocad's way. in autocad once you have your center point you can manully pick the points to copy to with out starting over.
                The supporting bracket in the image needs to be copied to each vertical joint. The joints are not all equally spaced, so I cannot simply used "3x" method to copy.
                http://ltunlimited.typepad.com/my_weblog/2010/03/multiple-rotate-and-copy.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+LtUnlimited+%28LT+Unlimited%29
                • L
                  lapx
                  Is it posible with ruby to place a component perpendicular to a point on an a face or curved surface just by selecting the point on the face? The component axis would of course have to be relative.
                    Ah damned πŸ˜„
                    are not equally spaced
                    So before a better little trick (or plug forgotten) 😳
                    you can make that
                    As above draw the "Radial Lines Lenght" (TIG) (automatic)
                    from the center guide arc circle given by the Thomthom plug
                    You can now make a copy rotate of the bracket
                    "one by one" because you have the good directions and angles!copy_rotate.jpg
                    • sbpronhS
                      sbpronh
                      Hello!
                      Is there a plugin that can do a multiple rotate and copie as shown in this film:
                      http://www.youtube.com/watch?feature=player_embedded&v=0M0zruTjYPw
                      Regards!
                      Luis
                        Seems Radial Lenght by TIg makes that! πŸ˜‰
                        • 2 / 2
