    Multiple dialog scope issue on the PC
    24 Posts 4 Posters 708 Views 4 Watching
      @honkinberry said:
      In fact, it is, without fail, the best recommended practice.
      In terms of a JS application?
      It's not in terms of website development - as then the href should be a working fallback in case of JS not being enabled. Which is why the onclick event should prevent bubbling.
      None the less - that's straying besides the point.
      Can you provide a complete working sample where your callbacks fail?
        @honkinberry said:
        But back to the issue at hand, if you have this in a WebDialog html:
        > <a href="javascript&#058;void(0)" onclick="window.location='skp;done'">Click Me!</a>
        That works on a Mac, but on a PC, scope returns to Ruby, but Ruby is unable to access any dialog box elements, the DOM is completely gone. The only thing I've been able to do with the dialog is to close it. You can keep clicking the link, and Ruby will still get focus, but get_element_value and execute_script fail without any error.
        I cannot reproduce this. (Windows 7, IE10)
        wd.rb
        <span class="syntaxdefault"></span><span class="syntaxcomment">#&nbsp;load&nbsp;'c;/wd.rb'<br />#&nbsp;Example.test_void<br /></span><span class="syntaxdefault">module&nbsp;Example<br />&nbsp;&nbsp;def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">test_void<br />&nbsp;&nbsp;&nbsp;&nbsp;path&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dirname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">dialog&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">.new()<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_file</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxstring">'sample.html'</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">show&nbsp;</span><span class="syntaxkeyword">{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;@</span><span class="syntaxdefault">dialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"done"</span><span class="syntaxkeyword">)&nbsp;{&nbsp;|</span><span class="syntaxdefault">wd</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">param</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">p&nbsp;param&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;}&nbsp;</span><span class="syntaxcomment">#&nbsp;show<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">dialog<br />&nbsp;&nbsp;end<br />end</span>
        sample.html
        <span class="syntaxdefault"></span><span class="syntaxkeyword"><!</span><span class="syntaxdefault">DOCTYPE&nbsp;html</span><span class="syntaxkeyword">><br /><</span><span class="syntaxdefault">html</span><span class="syntaxkeyword">><br /><</span><span class="syntaxdefault">body</span><span class="syntaxkeyword">><br /><br /><</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">><br />&nbsp;&nbsp;<</span><span class="syntaxdefault">a&nbsp;href</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"javascript;void(0)"&nbsp;</span><span class="syntaxdefault">onclick</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"window.location='skp;done@HelloWorld'"</span><span class="syntaxkeyword">></span><span class="syntaxdefault">Click&nbsp;Me</span><span class="syntaxkeyword">!</</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">><br /></</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">><br /><br /><</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">><br />&nbsp;&nbsp;<</span><span class="syntaxdefault">a&nbsp;href</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"#"&nbsp;</span><span class="syntaxdefault">onclick</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"alert(document.body.innerHTML)"</span><span class="syntaxkeyword">></span><span class="syntaxdefault">innerHtml</span><span class="syntaxkeyword"></</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">><br /></</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">><br /><br /></</span><span class="syntaxdefault">body</span><span class="syntaxkeyword">><br /></</span><span class="syntaxdefault">html</span><span class="syntaxkeyword">>&nbsp;</span><span class="syntaxdefault"></span>
          oh... wait... I didn't try get_element_value and execute_script.
            Have you considered setting and using an enduring @@dialog rather than the instance variable @dialog ?
            Untested, just a thought...
              Ah. Now I can reproduce it.
              Very strange indeed.
              However, I've never seen anyone using javascript&#058;void(0) instead of preventing the event from bubbling. First time I heard of this issue.
              If you don't use a framwork like jQuery you have to account for old IE's weirdness:
              http://www.quirksmode.org/js/events_order.html#link9
                Actually, you just need to return false from the onclick event.
                <span class="syntaxdefault"></span><span class="syntaxkeyword"><!</span><span class="syntaxdefault">DOCTYPE html</span><span class="syntaxkeyword">><br /><</span><span class="syntaxdefault">html</span><span class="syntaxkeyword">><br /><</span><span class="syntaxdefault">body</span><span class="syntaxkeyword">><br /><br /><</span><span class="syntaxdefault">input type</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"text"</span><span class="syntaxdefault"> id</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"cheese"</span><span class="syntaxdefault"> value</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"Foo Bar"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">><br /><br /><</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">><br /></span><span class="syntaxdefault">  </span><span class="syntaxkeyword"><</span><span class="syntaxdefault">a<br />    href</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"javascript;void(0)"<br /></span><span class="syntaxdefault">    onclick</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"window.location='skp;done@HelloWorld'; return false;"</span><span class="syntaxkeyword">><br /></span><span class="syntaxdefault">      Click Me</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword"></</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">><br /></</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">><br /><br /><</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">><br /></span><span class="syntaxdefault">  </span><span class="syntaxkeyword"><</span><span class="syntaxdefault">a href</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"#"</span><span class="syntaxdefault"> onclick</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"alert(document.body.innerHTML)"</span><span class="syntaxkeyword">></span><span class="syntaxdefault">innerHtml</span><span class="syntaxkeyword"></</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">><br /></</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">><br /><br /></</span><span class="syntaxdefault">body</span><span class="syntaxkeyword">><br /></</span><span class="syntaxdefault">html</span><span class="syntaxkeyword">></span><span class="syntaxdefault"></span>
                  Back tot the side topic of best practices:
                  It's generally considered best practice to separate content, layout and behaviour. That means all CSS in a .css file and all JS in a .js file.
                  And I've never heard of void(0) as best practice. I find it often in Bad Practices lists:
                  http://www.quirksmode.org/blog/archives/2005/06/three_javascrip_1.html#link3
                  "javascript:void(0);" vs "return false" vs "preventDefault()"
                  When I want some link to not do anything but only respond to JavaScript actions what is the best way to avoid the link scrolling to the top edge of the page? I know several ways of doing it, they all
                  Stack Overflow (stackoverflow.com)
                  • H Offline
                    honkinberry
                    Both of those links that you sent merely say it is bad form to put javascript into the href, which is true.
                    The javascript:void(0) is the recommended practice, indicating that the onclick handler is to take precedence.
                    In fact, the whole point of it is so that it onclick handler doesn't have to return false.
                    (See here: http://stackoverflow.com/questions/134845/href-attribute-for-javascript-links-or-javascriptvoid0)
                    But good to know that was the issue!
                    Many thanks for your tireless attention to detail on every conceivable issue.
                    --J
                      But when would you use void(0) in anything other than the HREF?
                      I still agree with with the this answer:
                      http://stackoverflow.com/a/134957/486990
                      There's a lot of information floating around which is lingering around from the older days. When going through best practices guides of well known web designers it's always to avoid inline JS. Which then removes void(0) from the equation completely.
                      No worries. I had some spare time while I was rendering. 😄
                      And the WebDialog has been a source of so much oddity that I felt a strong inclination to check it out myself. I reckon it's still worth reporting, so if you're heading into Boulder then give them a nudge. 😄
                      • Dan RathbunD Offline
                        Dan Rathbun
                        I disagreed 3 years ago when we discussed this issue, and still do.
                        Read my detailed explanation in this old thread: Webdialogs and Javascript void
                        Any more discussion on this offtopic, can be done in that thread, if you wish.
                        I'm not here much anymore.
                        • 2 / 2
