    [REQ] layer attribute from geometry to group
    3 Posts 2 Posters 224 Views 2 Watching
      j_forrester
      I believe there was recently a post asking for the reverse of this. I have received a model which has all layer attributes assigned to the actual geometry (faces/edges). When i try and export this to an external program it does not pick up the layer information as the top most groups are all showing Layer 0.
      What i need is a script that recursively goes through all geometry and assigns the same layer attributes to the parent group(s) or components.
      Does anyone know of such a script or if it is not too difficult have a quick play and see what is achievable?
      Any help would be very much appreciated.
        Are all entities inside each group/component-definition on a single layer.
        It's unworkable if not...
        If they are.... you can use:
        m=Sketchup.active_model;ds=m.definitions;m.start_operation('x');ds.each{|d|d.instances.each{|i|i.layer=d.entities[0].layer}};m.commit_operation;
        copy+pasted into the Ruby Console + <enter>.
        It is one-step undo-able.
        If you want to give the group/instance the internal contents' layer AND also revert the faces/edges in it to Layer0, this alternative is what you need:
        m=Sketchup.active_model;ds=m.definitions;m.start_operation('x');ds.each{|d|d.instances.each{|i|i.layer=d.entities[0].layer};d.entities.grep(Sketchup;;Face).each{|e|e.layer=nil};d.entities.grep(Sketchup;;Edge).each{|e|e.layer=nil};};m.commit_operation;
        We can't try to revert everything to Layer0 because if you have nested groups they'll be all over the shop as their layer alters...
          j_forrester
          TIG,
          Thank you very much! That worked great.
