    Removing unused commands and shortening toolbars
    8 Posts 3 Posters 465 Views 3 Watching
    • U Offline
      unearthed
      Hi, Is there a way to shorten a toolbar, for instance I use ThomThom's LayerTools often - it's a great tool TT, thanks, although I only ever use five commands and so have removed the remainders associated button images:full width toolbar with images removed from folder
      The rest of the toolbar is 'wasted' screen space.
      Is their a way of reducing the toolbar length to equal the width of just the buttons in the folder so it looks like this?
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
      • TIGT Online
        Yes but you need to edit some .rb file... best to ask its author where/how - perhaps PM him... ?
        Where it is effectively saying "sometoolbar.add_item(command)" you put a # in front of it to disable that line of code and thereby stop that button being added to the toolbar... Of course any update to the files will lose your changes...
        • U Offline
          unearthed
          Thanks for that TIG, I'll go and poke around in the .rb before I bother the writer - I was wrong it was Didier (with help from you apparently, according to the help file).
          • U Offline
            unearthed
            Thanks TIG, that worked. Knowing almost nothing about ruby or coding in general I found I had to hash out all the lines concerning each icon e.g. (showing a modified and an unmodified commant set)
            *#Delete layer
            cmd1129 = UI::Command.new(("Delete layer")) { Sketchup.active_model.select_tool(DeleteClickedObjectLayer.new) }
            cmd1129.small_icon = "Layer Manager/lm_del_lay_16.png"
            cmd1129.large_icon = "Layer Manager/lm_del_lay_24.png"
            cmd1129.tooltip = "Delete layer"
            layertools_tb.add_item(cmd1129)
            #Lock layer
            cmd1229 = UI::Command.new(("Lock layer")) { Sketchup.active_model.select_tool(SetClickedObjectLayer.new("locked")) }
            cmd1229.small_icon = "Layer Manager/lm_set_locked_16.png"
            cmd1229.large_icon = "Layer Manager/lm_set_locked_24.png"
            cmd1229.tooltip = "Lock layer"
            layertools_tb.add_item(cmd1229)*
            and now I have a nice short toolbarshowing modified layer manager toolbar loaded.JPG.
            • TIGT Online
              Using
              **#** layertools_tb.add_item(cmd1129)
              alone will stop its command appearing in the toolbar.
              It might be a good idea to keep the other 'cmd1129' lines as defined - as they might be used in a 'menu' too ?
              By adding # in front of every line containing that 'cmd1129' you effectively stop the command getting created altogether...
              Your choice...
                That's not my plugin...
                • TIGT Online
                  I think it's Didier Bur's ?
                  The principal remains the same...
                  • U Offline
                    unearthed
                    Thanks TIG for the heads up on how to do that - so far I've only needed that small cmd set, and yes I've since realised it's Didiers' plugin not ThomThoms'.
