    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.4k Views 172 Watching
      mvdv
      If anyone knows how to fix the Ivy plugin for Mac, a great number of people will be very thankful, as will I.
      My problem is, I see the dialog box, can change the parameters, but when I start clicking on a surface -> nothing happens. I can keep on clicking it, there will never be a red line. I also tried it on windows where it works just fine. There is also nothing happening in the ruby console.
      Can anyone help me out?
      Thanks,
      Michael
      • marcorigamonti74M Offline
        marcorigamonti74
        @gilles63 said:
        you are welcome , and myself i must thank Pierre for a great plugin . This textures can be improved, especially the roses, and i realise that some axis should be changed, the leaves tend to hang in the same direction, but i ll work on it and post a better version in the next days .
        @pierreden said:
        After playing with "An Ivy Generator"(found here) I thhought about how awesome it would be to be able to play with something like this directly in Sketchup. I therefore started to port the ivy generator to ruby and Sketchup. As i now have working code with regards to the main parts of the algorithm, collition detection, adhesion and the growing of the ivy branches, i decided to post a proof of concept.
        Usage
        -Select "Sketchup Ivy 0.5" in the Plugins sub-menu
        -Adjust Parameters in Menu
        -Every time you click your left mouse button, the ivy will grow
        -CTRL-Click for leafs (repeat as many times you want)
        -When you're happy with the ivy Shift-click to make it into actual volumes.
        http://i.imgur.com/qrOAJ.jpg
        VERSION 0.6
        UPDATE 12.05.2011
        -Tooltip
        -Minor bug fixes
        -Additional parameters.
        VERSION 0.5
        UPDATE 09.05.2011
        • Will now use components with "ivyleaf" in the name as leafs. 3 included by default.
        • Hopefully better mac support πŸ˜’
        • Small algorithm changes πŸ‘
        • ALT+click to make ivy grow towards pointer
          - Thea users: uncheck 'export as components' before exporting. (Thanks Solo)
          Fix 0.5.2
        • Tool startup fix (maybe?)
        VERSION 0.3
        UPDATE 05.05.2011
        • Simple gui. (More parameters to come)
        • Leaves
        • Speed and reliability
        • I know theres some issues with mac. As i haven't had the opportunity to debug on a mac, im not sure if its working now. Mac users with issues are very welcome to PM me or write here. (Guess this goes for everyone with issues, im sure there is lots πŸ˜’ ).
        VERSION 0.1.5
        UPDATE 28.04.2011
        [Uploaded buggy file !! Sorry]
        • Added Wind (comming from the position of the sun atm)
          -Bug fixes
        VERSION 0.1
        UPDATE 27.04.2011
        • Faster Preview
        • Better Ivy "Resolution"
        • Faster and more reliable volume generation (less buggsplats?)
        • Face normals should now be oriented correctly
        • More reliable collision detection
        • A few bugs in the force algorithms fixed.
        • Works as before. Edit the values in Plugins/SketchupIvy/setup.rb πŸ˜‰
        TO COME
        • Leaves as Components
        • More Parameters and grow patterns.
        • Other Plugins. Fur, Cloth and Tree.
        Notes
        • Never shift-click when there is more than 150 branches (information in the ruby console). This will often cause a bugsplat (seems like sketchup realy, realy, realy doesn't like programmaticaly adding of entities or seemingly infinit loops πŸ˜• )
        • For the adhesion to work, you have to be in the same scope (i made this to clearify (face.classify_point seems buggy)
        • This script has only been tested in SU8. As far as i know this script might cause bugsplat infernos and generally fuck shit up in other versions
        • If you find any bugs or problems please PM me πŸ˜‰ If you're extra awesome attach the error description from the ruby console.
        Any suggesions, comments or crits are very much welcome!
        Peace
        Pierre
        Hi, I Use sketchup with mac platform. I downloaded and installed the version Beta SketchupIvy.0.6.3.beta 16.45.45 but it doesn't generate anything. With the version Sketchup.0.5.4.rar it works. Could you solve this problem please.
        Thank's a lot!
        Marco
          Gordy_Z
          Thank you Pierreden for all the work you've put in on your ivy generator and thank you Gilles63 for providing different shaped leaves.
          In order to understand how the different variables affected the morphology of the ivy, I tested each variable on separate white walls. After doing this I modeled the ivy for the model I'm working on by choosing the best starting point for any variable by looking in the "ivy library" then exploring the nearby values of that variable on a test wall with my model's texture on it. I've uploaded the model that shows these first two steps so that you can see how the variables behave.
          Then I mixed and matched variables to get the final look for my model (not shown in the upload). I think mixing and matching gives unexpected results, so if you use the library, please use it only as a very general guide.
          It's an approximately 45 MB file, is at DropBox address https://dl.dropbox.com/u/79073930/Sketchup%20Ivy%200pt6pt3%20Tests.skp , and seems to work better with View/Face Style set to as simple a style as you can (you probably don't need to see the textures on my test walls). I tried to upload it here but couldn't, presumably because of the file size. If a file this size can be included here, let me know how and I'll do it. I hope it helps!
          Gordy_Z
          This image shows part of the Ivy Library.  There are more test walls and also an explanation section in the model.
          • OxerO Offline
            Oxer
            Thanks Gordy_Z for the information πŸ‘ !!
            • OxerO Offline
              Oxer
              Hi mvdv,
              I'm Mac's user, and Sketchup Ivy works on Mac but only with 0.6.0 version, see below. I have introduced the keys for Mac in the Use tab of the plugin window. If you want to see how use the plugin in Mac go to this link http://www.youtube.com/watch?v=RGV8jU9HK_Y
              Sketchup Ivy 0.6 for Mac
              • romboutR Offline
                rombout
                Wow thanks for the settings, great work!
                • Z Offline
                  zelimbo
                  hey all i'm new to the forum but not in sketchup world....i'm having problems trying to install the ivy pluggin.....this is what happens when i open sketchup :
                  Error Loading File LiveIvy.rb
                  no such file to load -- LiveIvy/LiveVector_coreError Loading File LiveIvy_node.rb
                  uninitialized constant LiveIvy::Node::PdnError Loading File LiveIvy_tool.rb
                  uninitialized constant Pdn
                  please if anyone can help me resolve this issue...since before i havent had this problem with anyother pluggin
                  cheers!
                  • KrisidiousK Offline
                    Krisidious
                    Do you have the liveivy .rb file in the plugins folder and your liveivy folder inside of the plugins folder as well?
                    You should delete all the liveivy and make sure you downloaded the 0.6.3 version.
                    By: Kristoff Rand
                    • Z Offline
                      zelimbo
                      emmm i have a folder which i named ivy with all the files it comes with....apart from that i copied the liveivy.rb file alone in the pluggins folder......should i eliminate one of them?? im kinda lost and really want this app
                      thanx!!
                        Krisidious
                        you should have a "LiveIvy.rb" in your plugins folder and a "LiveIvy" folder in your plugins folder.
                        names must remain the same.
                        By: Kristoff Rand
                        • Z Offline
                          zelimbo
                          thanks kristoff for taking your time with me did what you told me to and ended up wiht this:
                          can't convert nil into String
                            Krisidious
                            You get that when you load sketchup or when you load the plugin and try to use it?
                            By: Kristoff Rand
                            • Z Offline
                              zelimbo
                              i get that when i load sketchup
                                Krisidious
                                Here... Try mine.
                                (www.aboveallhouseplans.com)
                                it's like 37 megs. has more ivy in it.
                                if this doesn't work there is a conflict with another plugin.
                                By: Kristoff Rand
                                • Z Offline
                                  zelimbo
                                  thanx man!
                                    Krisidious
                                    Did that fix it?
                                    By: Kristoff Rand
                                    • F Offline
                                      fwolf21
                                      Great work.
                                      I have worked with the original ivy generator back in 2008-2009.
                                      Don't have any thing to say right now since just start using it.
                                      Ill keep you posted if anything comes up.
                                      Keep you the great work
                                        PHRodrigues
                                        awesome! thx man.
                                          technoshaman
                                          Thank you for this wonderful plug in. I was about to start modeling ivy by hand!!!! But this saved me so much time. THANK YOU
                                          • lele_poggiL Offline
                                            lele_poggi
                                            The plug-in doesn't work with the new version of Vray for Sketchup 1.6.
                                            Can be fixed this bug?
                                            Thank you
                                            gsa | Gabriele Sacchi architetto
                                            http://www.gs-a.it
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 36
                                            • 37
                                            • 13 / 37
