    [Plugin] CleanUp
    974 Posts 217 Posters 860.9k Views 217 Watching
      Piratestef
      I just need clean faces. With how the model now is it had all kinds of holes and gaps in the faces.
        Ahamd
        hi ,, i download cleanup up plugin but it's not working ???
          Need a lot more info than that. Error messages? Result not what you expected? No menus?
            That looks to be due to poor geometry in the model. Not something that can automatically fixed. When I opened the DWG in AutoCAD I got a warning I'd never seen before, it'd encountered 30 errors and wanted to abort loading the file.
              tomot
              I created a simple cube greeble ruby a while ago that draws an array of cubes in xy, xz, yz, or xyz planes. My idea was to carve out cubes from these arrays to create other 3d objects, retaining the basic cube module, much like the Voxel idea. Attached is 3d object file.
              I ran Cleanup on this file. but it was unable to delete the redundant interior faces.
              In addition is Cleanup able to remove the unnecessary exterior cube lines while retaining the integrity of the 3d object?
              Hilbert.skp
              my plugins
              tomot
                Cleanup does not remove internal faces. It's a very difficult thing to do - determining what is "inside" from code. Look at TIGs list of plugins, he have at least one that does that job.
                "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
                  Piratestef
                  Thanks for the help, I was working on a Solidworks file and wanted it as an sketchup file. So I made it a .dwg and there is the result.
                  Do you know a way to get a solidworks model into a sketchup file?
                    Afraid not, I've not used Solidworks - don't know it's export capabilities.
                      Have you looked at TIGs tools?
                        Solid Solver and Fix Solid should both do it - at least they where made to do so. Perhaps you have an edge case there.
                        • voljankoV Offline
                          voljanko
                          Hello,
                          I have checked the model it with SuSolid plugin and fixed the model with 1 button.
                          David
                          SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
                          • olisheaO Offline
                            olishea
                            @tomot said:
                            none of them perform interior face removal 😞
                            Have you tried Remove Inner Faces plugin?!
                            oli
                              tomot
                              @voljanko said:
                              Hello,
                              David
                              OK!..... please attach my file with you 1 button fix πŸ‘
                              my plugins
                              tomot
                                tomot
                                Where? there is no such name when searching at this forum or at the ruby library depot.😞
                                my plugins
                                tomot
                                  You find all of them in the Plugin Index: http://sketchucation.com/forums/viewtopic.php?p=250026 (Resources > Plugins)
                                  • voljankoV Offline
                                    voljanko
                                    No problem πŸ˜„
                                    Hilbert_all_solids.skp
                                      tomot
                                      Yes I included that thread also, visually I did not find anything. 😞
                                      my plugins
                                      tomot
                                        Use the browser's search feature to quickly find things. (Often F3 activates it)
                                        • mitcorbM Offline
                                          mitcorb
                                          Remove Inner Faces by wikii in the Plugins Index.
                                            tomot
                                            I have, in fact I have been trying to compile a Rubies folder on this subject, which is far from complete. Here is what I have so far.
                                            TIG solid solver
                                            TT cleanup
                                            Fix solid
                                            ky delete Interior faces
                                            wikii remove Inner Faces
                                            my plugins
                                            tomot
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 48
                                            • 49
                                            • 30 / 49
