    Understand what encoding SketchUp 8?
    7 Posts 4 Posters 823 Views 4 Watching
      sahi
      SketchUp 5
      path = "C:\Users\Admin\Documents\моя модСль.skp"
      encode_to_utf-8 path
      model.save path -> works
      Sketchup.open_file path -> works
      SketchUp 8
      model.save path -> does not work
      What encoding supports Sketchup 8 to save the model?
      • yorik1984Y Offline
        yorik1984
        Maybe
        path = "C:\Users\Admin\Documents\моя\ модСль.skp"
        or 'C:\Users\Admin\Documents\моя модСль.skp'
        • jolranJ Offline
          jolran
          Maybe / ?
            sahi
            Problem in "Cyrillic"
            "Cyrillic" in utf-8
            Sketchup 5 and reads and stores
            Skutchup 6 7 8 only reads but does not save.
            Skutchup 6 7 8 reads "Cyrillic" in utf-8
            And when you save what encoding uses (cp1252 cp866??????)
              I wrote about SketchUp and Unicode a while back: http://sketchucation.com/forums/viewtopic.php?t=20657
              Summary:
              Ruby 1.8 does not understand Unicode strings - it treat each byte as a character.
              Ruby 1.8 under Windows cannot read/write, handle files with multi-byte characters. Needs to be ASCII characters. This is because Ruby calls the A (ASCII) versions of the file system function instead of the W (Wide characters - unicode) versions.
              Ruby 1.8 under OSX is able to open unicode files.
                Oh - you're using the open and save model functions of the API. Ah - now that is interesting. I'd expect, at least the recent version to use UTF-8.
                  sahi
                  I wrote this script to
                  Perhaps what is in it and is not correct.
                  But Ruby is well aware of it, let's
                  string = File.join (File.dirname (FILE), "Моя папка"))
                  string = encode_to_cp1251 (string)
                  Dir.mkdir (string) -> works fine
                  And as Sketchup 5 works great
                  A Sketchup 6 7 8 only read but can not green triangle icon
                  Encodes from cp1251 to utf-8
                  And a coding of utf-8 cp1251 (Cyrillic)
                  In SketchUp 5 everything works fine
                  encode_utf-8_cp1251
