BIM
I typed "BIM" into the search bar and nothing came up, so I just wanted to ask whether anything is being done to address BIM in SU? I would imagine that it would be a big change if it was to be integrated and therefore a new SU version rather than a series of Rubys to bridge gaps bit by bit - but then again, I'm not sure if Trimble want to take SU down that path at all.
You may be aware that another Trimble owned company/software is Tekla Structures, which I think is a BIM application. Perhaps Trimble plans to integrate the Sketchup modeling process into this application in some way?
@grizzler said:
I typed "BIM" into the search bar and nothing came up...
Unfortunately the forum search engine does not "react" to anything that is 3 or less characters long.
I know it sucks. This is how the software is programmed however so we cannot do too much about it.
You needn't worry about that restriction Gaieus, as the rest of this forum is top notch!
I was not aware of that, but you can certain that I soon will be much more familiar with it
